[mapserver-commits] r12024 - trunk/docs/en/output
svn at osgeo.org
svn at osgeo.org
Sat Aug 6 11:45:49 EDT 2011
Author: warmerdam
Date: 2011-08-06 08:45:49 -0700 (Sat, 06 Aug 2011)
New Revision: 12024
trunk/docs/en/output/ogr_output.txt
add mention of 2.5D geomtype values (#3906)
Modified: trunk/docs/en/output/ogr_output.txt
--- trunk/docs/en/output/ogr_output.txt 2011-08-06 15:39:12 UTC (rev 12023)
+++ trunk/docs/en/output/ogr_output.txt 2011-08-06 15:45:49 UTC (rev 12024)
@@ -175,7 +175,9 @@
or "None". Most are fairly obvious, but "Geometry" can be used to represent
a mix of geometry types, and "None" is sometimes suitable for layers without
geometry. Note that layers which are a mix of polygon and multipolygon
- would normally have to be described as "Geometry".
+ would normally have to be described as "Geometry". To produce 2.5D output
+ append "25D" to the geometry type (ie. "Polygon25D"). Note that Z values
+ are only carried by MapServer if built with USE_POINT_Z_M support.
More information about the mapserver-commits
