[mapserver-commits] r12031 - branches/branch-6-0/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Aug 9 02:04:04 EDT 2011
Author: sdlime
Date: 2011-08-08 23:04:04 -0700 (Mon, 08 Aug 2011)
New Revision: 12031
branches/branch-6-0/mapserver/mapsde.c
Tentative fix for SDE/query issues... (#3977)
Modified: branches/branch-6-0/mapserver/mapsde.c
--- branches/branch-6-0/mapserver/mapsde.c 2011-08-09 05:28:34 UTC (rev 12030)
+++ branches/branch-6-0/mapserver/mapsde.c 2011-08-09 06:04:04 UTC (rev 12031)
@@ -35,8 +35,6 @@
#include "maptime.h"
#include "mapthread.h"
#ifdef USE_SDE
#include <sdetype.h> /* ESRI SDE Client Includes */
#include <sdeerno.h>
@@ -96,16 +94,12 @@
int msSDELayerIsOpen(layerObj *layer) {
#ifdef USE_SDE
- if(layer->layerinfo)
- return(MS_TRUE);
- return MS_FALSE;
+ if(layer->layerinfo)
+ return(MS_TRUE);
+ return MS_FALSE;
#else
- msSetError(MS_MISCERR, "SDE support is not available.",
- "msSDELayerIsOpen()");
- return(MS_FALSE);
+ msSetError(MS_MISCERR, "SDE support is not available.", "msSDELayerIsOpen()");
+ return(MS_FALSE);
#endif
@@ -1395,17 +1389,14 @@
int msSDELayerClose(layerObj *layer) {
#ifdef USE_SDE
msSDELayerInfo *sde=NULL;
sde = layer->layerinfo;
/* Silently return if layer not opened. */
if (!msSDELayerIsOpen(layer)) return MS_SUCCESS;
if(layer->debug)
- msDebug("msSDELayerClose(): Closing layer %s.\n", layer->name);
+ msDebug("msSDELayerClose(): Closing layer %s.\n", layer->name);
if (sde->layerinfo) SE_layerinfo_free(sde->layerinfo);
if (sde->coordref) SE_coordref_free(sde->coordref);
@@ -1423,9 +1414,7 @@
return MS_SUCCESS;
#else
- msSetError( MS_MISCERR,
- "SDE support is not available.",
- "msSDELayerClose()");
+ msSetError( MS_MISCERR, "SDE support is not available.", "msSDELayerClose()");
return(MS_FALSE);
#endif
@@ -2081,65 +2070,45 @@
int msSDELayerGetItems(layerObj *layer) {
#ifdef USE_SDE
- int status;
- status = msSDELayerInitItemInfo(layer);
- if (status != MS_SUCCESS) {
- "Unable to create SDE column info",
- "msSDELayerGetItems()");
- return(MS_FAILURE);
- return (MS_SUCCESS);
+ int status;
+ status = msSDELayerInitItemInfo(layer);
+ if (status != MS_SUCCESS) {
+ msSetError( MS_MISCERR, "Unable to create SDE column info", "msSDELayerGetItems()");
+ return(MS_FAILURE);
+ return (MS_SUCCESS);
#else
+ msSetError( MS_MISCERR, "SDE support is not available.", "msSDELayerGetItems()");
#endif
/* msSDELayerFreeItemInfo */
-void msSDELayerFreeItemInfo(layerObj *layer)
+void msSDELayerFreeItemInfo(layerObj *layer) {
#ifdef USE_SDE
- msSDELayerInfo *sde = NULL;
- int i;
- if (!msSDELayerIsOpen(layer)) {
- msSetError( MS_SDEERR,
- "SDE layer has not been opened.",
- "msSDELayerFreeItemInfo()");
- sde = layer->layerinfo;
+ msSDELayerInfo *sde = NULL;
+ sde = layer->layerinfo;
+ if(sde) {
if (sde->basedefs) {
- SE_table_free_descriptions(sde->basedefs);
- sde->basedefs = NULL;
+ SE_table_free_descriptions(sde->basedefs);
+ sde->basedefs = NULL;
if (sde->joindefs) {
- SE_table_free_descriptions(sde->joindefs);
- sde->joindefs = NULL;
+ SE_table_free_descriptions(sde->joindefs);
+ sde->joindefs = NULL;
- if (layer->iteminfo) {
- msFree(layer->iteminfo);
- layer->iteminfo = NULL;
- if (layer->items) {
- for (i=0; i< layer->numitems; i++) {
- msFree(layer->items[i]);
- msFree(layer->items);
- layer->items = NULL;
- layer->numitems = 0;
+ if (layer->iteminfo) {
+ msFree(layer->iteminfo);
+ layer->iteminfo = NULL;
#else
+ msSetError( MS_MISCERR, "SDE support is not available.", "msSDELayerFreeItemInfo()");
+ return;
#endif
More information about the mapserver-commits
