[mapserver-commits] r12042 - branches/branch-6-0/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Thu Aug 11 18:14:32 EDT 2011
Author: jmckenna
Date: 2011-08-11 15:14:32 -0700 (Thu, 11 Aug 2011)
New Revision: 12042
branches/branch-6-0/docs/en/mapfile/index.txt
add important note that MapServer parses the mapfile from top to bottom; thanks to mdsmith for pointing that out
Modified: branches/branch-6-0/docs/en/mapfile/index.txt
--- branches/branch-6-0/docs/en/mapfile/index.txt 2011-08-11 19:56:40 UTC (rev 12041)
+++ branches/branch-6-0/docs/en/mapfile/index.txt 2011-08-11 22:14:32 UTC (rev 12042)
@@ -63,6 +63,10 @@
* The Mapfile is NOT case-sensitive.
+* The Mapfile is read from top to bottom by MapServer; this means that LAYERs
+ near the top of your Mapfile will be drawn before those near the bottom. Therefore
+ users commonly place background imagery and other layer types near the top of their
+ mapfile, and lines and points near the bottom of their mapfile.
* Strings containing non-alphanumeric characters or a MapServer keyword MUST
be quoted. It is recommended to put ALL strings in double-quotes.
* For MapServer versions < 5, there was a default maximum of 200 layers per
More information about the mapserver-commits
