[mapserver-commits] r12049 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Fri Aug 12 09:19:53 EDT 2011
Author: havatv
Date: 2011-08-12 06:19:53 -0700 (Fri, 12 Aug 2011)
New Revision: 12049
branches/branch-6-0/docs/en/mapfile/join.txt
trunk/docs/en/mapfile/join.txt
Updated the join document (#3144).
Modified: branches/branch-6-0/docs/en/mapfile/join.txt
--- branches/branch-6-0/docs/en/mapfile/join.txt 2011-08-12 12:21:54 UTC (rev 12048)
+++ branches/branch-6-0/docs/en/mapfile/join.txt 2011-08-12 13:19:53 UTC (rev 12049)
@@ -19,8 +19,7 @@
- DBF/XBase files
- CSV (comma delimited text file)
-- PostgreSQL and PostGIS tables
-- MySQL tables
+- PostgreSQL tables
Mapfile Parameters:
@@ -33,19 +32,12 @@
.. code-block:: mapfile
CONNECTION "host=127.0.0.1 port=5432 user=postgres password=postgres dbname=somename"
- CONNECTIONTYPE OGR
+ CONNECTIONTYPE POSTGRESQL
- The following is an example connection for MySQL:
+CONNECTIONTYPE [csv|postgresql]
+ Type of connection (not required for DBF joins). For PostgreSQL
+ use `postgresql`, for CSV use `csv`.
- .. code-block:: mapfile
- CONNECTION "MYSQL:mydbname,user=root,password=mysql,port=3306"
-CONNECTIONTYPE [string]
- Type of connection (not required for DBF or CSV joins). For PostgreSQL and
- MySQL connections use 'OGR'.
FOOTER [filename]
Template to use *after* a layer's set of results have been sent. In other
words, this header HTML will be displayed after the contents of the
@@ -64,8 +56,8 @@
TABLE [filename|tablename]
For file-based joins this is the name of XBase or comma delimited file
- (relative to the location of the mapfile) to join TO. For PostgreSQL and
- MySQL support this is the name of the PostgreSQL/MySQL table to join TO.
+ (relative to the location of the mapfile) to join TO. For PostgreSQL
+ support this is the name of the PostgreSQL table to join TO.
TEMPLATE [filename]
Template to use with one-to-many joins. The template is processed once
@@ -149,7 +141,10 @@
- <tr bgcolor="#EFEFEF"><td align="left">[NAME]</td><td align="left">[test_VAL]</td></tr>
+ <tr bgcolor="#EFEFEF">
+ <td align="left">[NAME]</td>
+ <td align="left">[test_VAL]</td>
+ </tr>
Example 2: Join from SHP file to PostgreSQL table
@@ -211,14 +206,12 @@
- <tr bgcolor="#EFEFEF"><td align="left">[NAME]</td><td align="left">[test_val]</td></tr>
+ <td align="left">[test_val]</td>
+ </tr>
-.. note::
- When testing with MapServer 4.10.0 on Windows this postgresql join caused a
- mapserv.exe crash. However when testing this with a MapServer build > 4.10.0
- the crash did not occur.
Example 3: Join from SHP file to CSV file
@@ -271,6 +264,14 @@
11,2
12,1
+.. note::
+ The CSV driver currently doesn't read column names from the first
+ row. It just uses indexes (1, 2, ... n) to reference the
+ columns. It's ok to leave column names as the first row since they
+ likely won't match anything but they aren't used. Typically you'd
+ see something like "TO '1'" in the JOIN block. Then in the template
+ you'd use [name_1], [name_2], etc...
Ogrinfo
@@ -293,68 +294,7 @@
-Example 4: Join from SHP file to MySQL table
-Mapfile Layer
-.. code-block:: mapfile
- LAYER
- NAME "prov_bound"
- TYPE POLYGON
- STATUS DEFAULT
- DATA "prov.shp"
- CLASS
- NAME "Province"
- STYLE
- OUTLINECOLOR 120 120 120
- COLOR 255 255 0
- END
- END
- TOLERANCE 20
- TEMPLATE "../htdocs/cgi-query-templates/prov.html"
- HEADER "../htdocs/cgi-query-templates/prov-header.html"
- FOOTER "../htdocs/cgi-query-templates/footer.html"
- JOIN
- NAME "test"
- CONNECTION "MYSQL:test,user=root,password=mysql,port=3306"
- CONNECTIONTYPE ogr
- TABLE "lookup"
- FROM "ID"
- TO "ident"
- TYPE ONE-TO-ONE
- END
- END # layer
-Ogrinfo
- >ogrinfo MYSQL:test,user=root,password=mysql,port=3306 lookup -summary
- INFO: Open of `MYSQL:test,user=root,password=mysql,port=3306'
- using driver `MySQL' successful.
- Layer name: lookup
- Geometry: None
- Feature Count: 48
- Layer SRS WKT:
- (unknown)
- FID Column = ident
- val: Integer (0.0)
-Template
-.. note::
- When testing with MapServer 5.6.5 and MySQL 5.1.49 on Windows this MySQL join caused a
+ </tr>
Modified: trunk/docs/en/mapfile/join.txt
--- trunk/docs/en/mapfile/join.txt 2011-08-12 12:21:54 UTC (rev 12048)
+++ trunk/docs/en/mapfile/join.txt 2011-08-12 13:19:53 UTC (rev 12049)
@@ -19,8 +19,7 @@
- DBF/XBase files
-- MySQL tables
Mapfile Parameters:
@@ -33,19 +32,12 @@
FOOTER [filename]
@@ -64,8 +56,8 @@
TEMPLATE [filename]
+ </tr>
+ </tr>
-.. note::
11,2
12,1
+.. note::
Ogrinfo
-Mapfile Layer
- LAYER
- NAME "prov_bound"
- TYPE POLYGON
- STATUS DEFAULT
- DATA "prov.shp"
- CLASS
- NAME "Province"
- STYLE
- COLOR 255 255 0
- END
- END
- TOLERANCE 20
- JOIN
- NAME "test"
- TABLE "lookup"
- FROM "ID"
- TO "ident"
- TYPE ONE-TO-ONE
- END
- END # layer
-Ogrinfo
- Geometry: None
- Feature Count: 48
- Layer SRS WKT:
- (unknown)
-Template
-.. note::
+ </tr>
More information about the mapserver-commits
