[mapserver-commits] r12054 - branches/branch-6-0/docs/en/ogc
trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Sun Aug 14 07:01:25 EDT 2011
Author: havatv
Date: 2011-08-14 04:01:25 -0700 (Sun, 14 Aug 2011)
New Revision: 12054
branches/branch-6-0/docs/en/ogc/sos_server.txt
branches/branch-6-0/docs/en/ogc/wcs_server.txt
branches/branch-6-0/docs/en/ogc/wfs_server.txt
branches/branch-6-0/docs/en/ogc/wms_server.txt
trunk/docs/en/ogc/sos_server.txt
trunk/docs/en/ogc/wcs_server.txt
trunk/docs/en/ogc/wfs_server.txt
trunk/docs/en/ogc/wms_server.txt
Updating OGC documentation (WMS, WFS, WCS, SOS) with enable_request (#3703). Also did some map file formatting.
Modified: branches/branch-6-0/docs/en/ogc/sos_server.txt
--- branches/branch-6-0/docs/en/ogc/sos_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ branches/branch-6-0/docs/en/ogc/sos_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -121,6 +121,7 @@
- sos_title
- sos_onlineresource
- sos_srs
+ - sos_enable_request
- see the `Reference Section`_ of this document for a full list of metadata and
descriptions
@@ -145,7 +146,7 @@
the GetCapabilities output. If sos_onlineresource is not provided then MapServer
will try to provide a default one using the script name and hostname, but you
shouldn't count on that too much. It is strongly recommended that you provide
-the wfs_onlineresource metadata.
+the sos_onlineresource metadata.
Here is a valid online resource URL:
@@ -188,14 +189,15 @@
IMAGETYPE png
WEB
- IMAGEPATH "/ms4w/tmp/ms_tmp/"
- IMAGEURL "/ms_tmp/"
+ IMAGEPATH "/ms4w/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
- METADATA
- "sos_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?map=D:/ms4w/apps/sos/sos_test.map" ## REQUIRED
- "sos_title" "My SOS Demo Server" ## Recommended
- "sos_srs" "EPSG:4326" ## REQUIRED
- END
+ METADATA
+ "sos_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?map=D:/ms4w/apps/sos/sos_test.map" ## REQUIRED
+ "sos_title" "My SOS Demo Server" ## Recommended
+ "sos_srs" "EPSG:4326" ## REQUIRED
+ "sos_enable_request" "*" # Necessary
+ END
END
PROJECTION
@@ -439,6 +441,29 @@
**sos_contactfacsimiletelephone**
- * Description: Optional contact facsimile telephone number.
+**sos_enable_request** (or **ows_enable_request**)
+- *Description:* Space separated list of requests to enable.
+ The default is none.
+ The following requests can be enabled:
+ `GetCapabilities`, `GetObservation` and `DescribeSensor`.
+ A "!" in front of a request will disable the request.
+ "*" enables all requests.
+- *Examples:*
+ To enable only `GetCapabilities` and `GetObservation`:
+ "sos_enable_request" "GetCapabilities GetObservation"
+ To enable all requests except `GetCapabilities`
+ "sos_enable_request" "* !GetCapabilities"
**sos_fees**
- *Description:* (Optional) Fees information. Use the reserved word "none" if there
@@ -476,7 +501,7 @@
**sos_maxfeatures**
-- *Description:* (Optional) The number of elements to be returned by the WFS server. If the not set all observations are returned
+- *Description:* (Optional) The number of elements to be returned by the SOS server. If the not set all observations are returned
**sos_encoding_blockSeparator**
@@ -512,6 +537,29 @@
- *Description:* (Optional) An associated unit of measure URN) for a component, that will be returned when executing a GetObservation request. Default is \"\urn:ogc:object:uom\"\
+- *Examples:*
**sos_observedproperty_id**
- *Description:* (Required) ID of observed property, possibly in number format.
Modified: branches/branch-6-0/docs/en/ogc/wcs_server.txt
--- branches/branch-6-0/docs/en/ogc/wcs_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ branches/branch-6-0/docs/en/ogc/wcs_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -72,6 +72,7 @@
- LAYER NAME must be set
- LAYER TYPE is set to RASTER
- LAYER DUMP parameter set to TRUE
+- WEB metadata "wcs_enable_request" must be set
- WEB metadata "wcs_label" must be set
- LAYER metadata "wcs_label" must be set
- LAYER metadata "wcs_rangeset_name" must be set
@@ -127,6 +128,7 @@
"wcs_contactvoicetelephone" "613-555-1234"
"wcs_contactfacimiletelephone" "613-555-1235"
"wcs_service_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?"
+ "wcs_enable_request "*"
END
END
@@ -767,6 +769,29 @@
- *Description:* (Optional) A description of the server.
+**wcs_enable_request** (or **ows_enable_request**)
+ `GetCapabilities`, `GetCoverage` and `DescribeCoverage`.
+- *Examples:*
+ To enable only `GetCapabilities` and `GetCoverage`:
+ "wcs_enable_request" "GetCapabilities GetCoverage"
+ "wcs_enable_request" "* !GetCapabilities"
**wcs_fees**
- *Description:* (Optional) A text string indicating any fees imposed by the service provider.
@@ -822,6 +847,29 @@
- *Description:* (Optional) A description of the layer.
+- *Examples:*
**wcs_extent**
- *Description:* (Optional) Bounding box of layer, which must be provided for tiled data. Comma-delimited, in the format of: minx,miny,maxx,maxy
Modified: branches/branch-6-0/docs/en/ogc/wfs_server.txt
--- branches/branch-6-0/docs/en/ogc/wfs_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ branches/branch-6-0/docs/en/ogc/wfs_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -125,6 +125,10 @@
Resource URL" section of the :ref:`WMS Server <online_resource_wms>`
document.
+- The "wfs_enable_request" metadata (see below).
Example WFS Server Mapfile
@@ -156,6 +160,7 @@
"wfs_onlineresource" "http://demo.mapserver.org/cgi-bin/wfs?" ## Recommended
"wfs_srs" "EPSG:4326 EPSG:4269 EPSG:3978 EPSG:3857" ## Recommended
"wfs_abstract" "This text describes my WFS service." ## Recommended
+ "wfs_enable_request" "*" # necessary
END
END
@@ -410,6 +415,29 @@
- *Description:* (Optional) Any fees imposed by the service provider
for usage of this service or for data retrieved from the WFS.
+**wfs_enable_request** (or **ows_enable_request**)
+ `GetCapabilities`, `GetFeature` and `DescribeFeatureType`.
+- *Examples:*
+ To enable only `GetCapabilities` and `GetFeature`:
+ "wfs_enable_request" "GetCapabilities GetFeature"
+ "wfs_enable_request" "* !GetCapabilities"
**wfs_getcapabilities_version**
- *Description:* (Optional) Default version to use for GetCapabilities
@@ -623,6 +651,29 @@
then it has priority and MapServer will NOT try to read the source
file's extents.
+- *Examples:*
**wfs_featureid**
- *Description:* (Required for MapServer 4.10) Field to be used for
Modified: branches/branch-6-0/docs/en/ogc/wms_server.txt
--- branches/branch-6-0/docs/en/ogc/wms_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ branches/branch-6-0/docs/en/ogc/wms_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -145,6 +145,7 @@
- wms_title
- wms_onlineresource
- wms_srs (unless PROJECTION object is defined using "init=epsg:...")
+ - wms_enable_request
**And for each LAYER:**
@@ -162,7 +163,7 @@
- Layer TEMPLATE (required for GetFeatureInfo requests)
- Layer DUMP TRUE (only required for GetFeatureInfo GML requests)
-Let's go through each of these paramters in more detail:
+Let's go through each of these parameters in more detail:
- **Map Name and wms_title:**
@@ -289,6 +290,12 @@
This is covered in more detail in the section "More About the Online Resource
URL" below.
+- **"wms_enable_request" metadata:**
+ Specify which requests to enable. If not specified, no requests
+ will be enabled! See the explanation below.
- **Configuring for GetFeatureInfo Requests:**
You must set the layer TEMPLATE parameter for the layer to be queryable by
@@ -787,6 +794,29 @@
- *Description:* Optional XML capabilities encoding type. The default is
ISO-8859-1.
+**wms_enable_request** (or **ows_enable_request**)
+ `GetCapabilities`, `GetMap`, `GetFeatureInfo` and
+ `GetLegendGraphic`. A "!" in front of a request will disable the
+ request. "*" enables all requests.
+- *Examples:*
+ To enable only `GetMap` and `GetFeatureInfo`:
+ "wms_enable_request" "GetMap GetFeatureInfo"
+ To enable all requests except `GetFeatureInfo`
+ "wms_enable_request" "* !GetFeatureInfo"
**wms_feature_info_mime_type**
- *WMS TAG Name:* Feature_info_mime_type
@@ -1065,6 +1095,29 @@
wms_dataurl_format must also be specified.
- refer to section 7.1.4.5.14 of the WMS 1.1.1 spec.
+- *Examples:*
**wms_extent**
- *WMS TAG Name:* BoundingBox (WMS1.1.1, sect. 6.5.6)
@@ -1275,6 +1328,7 @@
"wms_title" "WMS Demo Server" ##required
"wms_onlineresource" "http://yourpath/cgi-bin/mapserv.exe?" ##required
"wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326" ##recommended
+ "wms_enable_request" "*" ##necessary
END
END
@@ -1377,17 +1431,18 @@
.. code-block:: mapfile
- NAME "DEMO"
+ NAME "DEMO"
- WEB
- METADATA
+ WEB
+ METADATA
"wms_onlineresource" "http://my.host.com/cgi-bin/mapserv?map=wms.map&"
"wms_srs" "AUTO:42001 AUTO:42002"
- END
- END
+ END # METADATA
+ END # WEB
The above server advertises the first two auto projections.
Modified: trunk/docs/en/ogc/sos_server.txt
--- trunk/docs/en/ogc/sos_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ trunk/docs/en/ogc/sos_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -121,6 +121,7 @@
- sos_title
- sos_srs
descriptions
@@ -145,7 +146,7 @@
IMAGETYPE png
WEB
- METADATA
- END
+ METADATA
+ END
END
PROJECTION
+- *Examples:*
**sos_fees**
@@ -476,7 +501,7 @@
**sos_maxfeatures**
+- *Examples:*
Modified: trunk/docs/en/ogc/wcs_server.txt
--- trunk/docs/en/ogc/wcs_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ trunk/docs/en/ogc/wcs_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -72,6 +72,7 @@
@@ -127,6 +128,7 @@
END
END
+- *Examples:*
**wcs_fees**
+- *Examples:*
**wcs_extent**
Modified: trunk/docs/en/ogc/wfs_server.txt
--- trunk/docs/en/ogc/wfs_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ trunk/docs/en/ogc/wfs_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
document.
@@ -156,6 +160,7 @@
END
END
+- *Examples:*
file's extents.
+- *Examples:*
**wfs_featureid**
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt 2011-08-14 04:02:22 UTC (rev 12053)
+++ trunk/docs/en/ogc/wms_server.txt 2011-08-14 11:01:25 UTC (rev 12054)
@@ -145,6 +145,7 @@
- wms_title
@@ -162,7 +163,7 @@
URL" below.
ISO-8859-1.
+- *Examples:*
+- *Examples:*
**wms_extent**
END
END
- NAME "DEMO"
+ NAME "DEMO"
- WEB
- METADATA
+ WEB
+ METADATA
- END
- END
+ END # METADATA
+ END # WEB
More information about the mapserver-commits
