[mapserver-commits] r12056 - branches/branch-6-0/docs/en/output trunk/docs/en/output
Sun Aug 14 18:13:13 EDT 2011
Author: havatv
Date: 2011-08-14 15:13:13 -0700 (Sun, 14 Aug 2011)
New Revision: 12056
   branches/branch-6-0/docs/en/output/flash.txt
   branches/branch-6-0/docs/en/output/pdf.txt
   branches/branch-6-0/docs/en/output/svg.txt
   trunk/docs/en/output/flash.txt
   trunk/docs/en/output/pdf.txt
   trunk/docs/en/output/svg.txt
Added notes on lacking documentation for svg and pdf, added note of no support for swf/flash documentation (#3918).
Modified: branches/branch-6-0/docs/en/output/flash.txt
--- branches/branch-6-0/docs/en/output/flash.txt	2011-08-14 21:30:59 UTC (rev 12055)
+++ branches/branch-6-0/docs/en/output/flash.txt	2011-08-14 22:13:13 UTC (rev 12056)
@@ -24,7 +24,10 @@
 "Shockwave Flash Format").  The following document outlines how to enable
 Flash output in MapServer.
+.. note::
+   SWF is no longer supported in version 6.0.
 Links to Flash-Related Information
Modified: branches/branch-6-0/docs/en/output/pdf.txt
--- branches/branch-6-0/docs/en/output/pdf.txt	2011-08-14 21:30:59 UTC (rev 12055)
+++ branches/branch-6-0/docs/en/output/pdf.txt	2011-08-14 22:13:13 UTC (rev 12056)
@@ -26,6 +26,11 @@
 specified in the mapfile using the :ref:`IMAGETYPE <imagetype>` or the :ref:`OUTPUTFORMAT` parameters in the
 mapfile.  Additionally, raster layers are now supported for pdf output.
+.. note::
+   From version 6.0, PDF output is supported through Cairo.  This is
+   not reflected in the current documentation.
 What is currently supported and not supported
Modified: branches/branch-6-0/docs/en/output/svg.txt
--- branches/branch-6-0/docs/en/output/svg.txt	2011-08-14 21:30:59 UTC (rev 12055)
+++ branches/branch-6-0/docs/en/output/svg.txt	2011-08-14 22:13:13 UTC (rev 12056)
@@ -26,6 +26,11 @@
 - MapServer application development and setting up map files.
+.. note::
+   From version 6.0, SVG output is supported through Cairo.  This is
 Links to SVG-Related Information
Modified: trunk/docs/en/output/flash.txt
--- trunk/docs/en/output/flash.txt	2011-08-14 21:30:59 UTC (rev 12055)
+++ trunk/docs/en/output/flash.txt	2011-08-14 22:13:13 UTC (rev 12056)
@@ -24,7 +24,10 @@
+.. note::
Modified: trunk/docs/en/output/pdf.txt
--- trunk/docs/en/output/pdf.txt	2011-08-14 21:30:59 UTC (rev 12055)
+++ trunk/docs/en/output/pdf.txt	2011-08-14 22:13:13 UTC (rev 12056)
@@ -26,6 +26,11 @@
+.. note::
Modified: trunk/docs/en/output/svg.txt
--- trunk/docs/en/output/svg.txt	2011-08-14 21:30:59 UTC (rev 12055)
+++ trunk/docs/en/output/svg.txt	2011-08-14 22:13:13 UTC (rev 12056)
@@ -26,6 +26,11 @@
+.. note::
