[mapserver-commits] r12060 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Aug 16 00:49:21 EDT 2011
Author: sdlime
Date: 2011-08-15 21:49:21 -0700 (Mon, 15 Aug 2011)
New Revision: 12060
trunk/mapserver/mapdraw.c
Added check to prevent caching of line layers if using multiple styles that define attribute bindings. (#3976)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2011-08-15 21:10:32 UTC (rev 12059)
+++ trunk/mapserver/mapdraw.c 2011-08-16 04:49:21 UTC (rev 12060)
@@ -848,58 +848,60 @@
nclasses = 0;
classgroup = NULL;
- if (layer->classgroup && layer->numclasses > 0)
- classgroup = msAllocateValidClassGroups(layer, &nclasses);
+ if(layer->classgroup && layer->numclasses > 0)
+ classgroup = msAllocateValidClassGroups(layer, &nclasses);
- if (layer->minfeaturesize > 0)
- minfeaturesize = Pix2LayerGeoref(map, layer, layer->minfeaturesize);
+ if(layer->minfeaturesize > 0)
+ minfeaturesize = Pix2LayerGeoref(map, layer, layer->minfeaturesize);
while((status = msLayerNextShape(layer, &shape)) == MS_SUCCESS) {
- /* Check if the shape size is ok to be drawn */
- if ((shape.type == MS_SHAPE_LINE || shape.type == MS_SHAPE_POLYGON) && (minfeaturesize > 0) &&
- (msShapeCheckSize(&shape, minfeaturesize) == MS_FALSE))
- if( layer->debug >= MS_DEBUGLEVEL_V )
- msDebug("msDrawVectorLayer(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
- msFreeShape(&shape);
- continue;
- shape.classindex = msShapeGetClass(layer, map, &shape, classgroup, nclasses);
- if((shape.classindex == -1) || (layer->class[shape.classindex]->status == MS_OFF)) {
+ /* Check if the shape size is ok to be drawn */
+ if((shape.type == MS_SHAPE_LINE || shape.type == MS_SHAPE_POLYGON) && (minfeaturesize > 0) && (msShapeCheckSize(&shape, minfeaturesize) == MS_FALSE)) {
+ if(layer->debug >= MS_DEBUGLEVEL_V)
+ msDebug("msDrawVectorLayer(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
continue;
+ shape.classindex = msShapeGetClass(layer, map, &shape, classgroup, nclasses);
+ if((shape.classindex == -1) || (layer->class[shape.classindex]->status == MS_OFF)) {
+ msFreeShape(&shape);
+ continue;
- if (maxfeatures >=0 && featuresdrawn >= maxfeatures)
- status = MS_DONE;
- break;
+ if(maxfeatures >=0 && featuresdrawn >= maxfeatures) {
+ status = MS_DONE;
+ break;
featuresdrawn++;
cache = MS_FALSE;
- if(layer->type == MS_LAYER_LINE && (layer->class[shape.classindex]->numstyles > 1 ||
- (layer->class[shape.classindex]->numstyles == 1 && layer->class[shape.classindex]->styles[0]->outlinewidth>0)))
+ if(layer->type == MS_LAYER_LINE && (layer->class[shape.classindex]->numstyles > 1 || (layer->class[shape.classindex]->numstyles == 1 && layer->class[shape.classindex]->styles[0]->outlinewidth > 0))) {
+ int i;
cache = MS_TRUE; /* only line layers with multiple styles need be cached (I don't think POLYLINE layers need caching - SDL) */
+ /* we can't handle caching with attribute binding other than for the first style (#3976) */
+ for(i=1;i<layer->class[shape.classindex]->numstyles; i++) {
+ if(layer->class[shape.classindex]->styles[i]->numbindings > 0) cache = MS_FALSE;
/* With 'STYLEITEM AUTO', we will have the datasource fill the class' */
/* style parameters for this shape. */
if(layer->styleitem) {
- if(strcasecmp(layer->styleitem, "AUTO") == 0) {
- if (msLayerGetAutoStyle(map, layer, layer->class[shape.classindex], &shape) != MS_SUCCESS) {
- retcode = MS_FAILURE;
- break;
+ if(strcasecmp(layer->styleitem, "AUTO") == 0) {
+ if(msLayerGetAutoStyle(map, layer, layer->class[shape.classindex], &shape) != MS_SUCCESS) {
+ retcode = MS_FAILURE;
+ break;
- else {
- /* Generic feature style handling as per RFC-61 */
- if (msLayerGetFeatureStyle(map, layer, layer->class[shape.classindex], &shape) != MS_SUCCESS) {
- break;
+ } else {
+ /* Generic feature style handling as per RFC-61 */
+ if(msLayerGetFeatureStyle(map, layer, layer->class[shape.classindex], &shape) != MS_SUCCESS) {
+ break;
/* __TODO__ For now, we can't cache features with 'AUTO' style */
cache = MS_FALSE;
@@ -908,7 +910,6 @@
if(annotate && (layer->class[shape.classindex]->text.string || layer->labelitem) && layer->class[shape.classindex]->label.size != -1)
shape.text = msShapeGetAnnotation(layer, &shape);
if (cache) {
styleObj *pStyle = layer->class[shape.classindex]->styles[0];
colorObj tmp;
@@ -1227,7 +1228,7 @@
if((curStyle->minscaledenom != -1) && (map->scaledenom < curStyle->minscaledenom))
continue;
- msDrawLineSymbol(&map->symbolset, image, ¤t->shape, (layer->class[current->shape.classindex]->styles[s]), layer->scalefactor);
+ msDrawLineSymbol(&map->symbolset, image, ¤t->shape, (layer->class[current->shape.classindex]->styles[s]), layer->scalefactor);
More information about the mapserver-commits
