[mapserver-commits] r12064 - branches/branch-6-0/docs/en/mapfile
Tue Aug 16 12:31:12 EDT 2011
Author: jmckenna
Date: 2011-08-16 09:31:11 -0700 (Tue, 16 Aug 2011)
New Revision: 12064
   branches/branch-6-0/docs/en/mapfile/layer.txt
use the text 'special characters' instead in NAME description
Modified: branches/branch-6-0/docs/en/mapfile/layer.txt
--- branches/branch-6-0/docs/en/mapfile/layer.txt	2011-08-16 16:30:55 UTC (rev 12063)
+++ branches/branch-6-0/docs/en/mapfile/layer.txt	2011-08-16 16:31:11 UTC (rev 12064)
@@ -372,7 +372,7 @@
     interfaces that refer to this name. They must be identical. The name should
     be unique, unless one layer replaces another at different scales. Use the
     GROUP option to associate layers with each other.  It is recommended that
-    the name not contain spaces, invalid characters, or begin with a number (which
+    the name not contain spaces, special characters, or begin with a number (which
     could cause problems through interfaces such as OGC services).
 OFFSITE [r] [g] [b]
