[mapserver-commits] r12091 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Aug 23 08:33:34 EDT 2011
Author: havatv
Date: 2011-08-23 05:33:34 -0700 (Tue, 23 Aug 2011)
New Revision: 12091
branches/branch-6-0/docs/en/mapfile/map.txt
trunk/docs/en/mapfile/map.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/map.txt
--- branches/branch-6-0/docs/en/mapfile/map.txt 2011-08-23 12:24:06 UTC (rev 12090)
+++ branches/branch-6-0/docs/en/mapfile/map.txt 2011-08-23 12:33:34 UTC (rev 12091)
@@ -12,7 +12,7 @@
word `END`.
.. index::
- pair: ANGLE; MAP
+ pair: MAP; ANGLE
ANGLE [double]
Angle, given in degrees, to rotate the map. Default is 0. The
@@ -41,7 +41,7 @@
.. _`Wiki Page`: http://trac.osgeo.org/mapserver/wiki/MapRotation
.. index::
- pair: CONFIG; MAP
+ pair: MAP; CONFIG
CONFIG [key] [value]
This can be used to specify several values at run-time, for both
@@ -149,6 +149,9 @@
CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
+.. index::
+ pair: MAP; DATAPATTERN
.. _DATAPATTERN:
DATAPATTERN [regular expression]
@@ -161,7 +164,7 @@
TEMPLATEPATTERN_.
.. index::
- pair: DEBUG; MAP
+ pair: MAP; DEBUG
DEBUG [off|on|0|1|2|3|4|5]
Enables debugging of all of the layers in the current map.
@@ -233,7 +236,7 @@
option).
.. index::
- pair: DEFRESOLUTION; MAP
+ pair: MAP; DEFRESOLUTIONx
DEFRESOLUTION [int]
Sets the reference resolution (pixels per inch) used for
@@ -247,7 +250,7 @@
.. versionadded:: 5.6
.. index::
- pair: EXTENT; MAP
+ pair: MAP; EXTENT
EXTENT [minx] [miny] [maxx] [maxy]
The spatial extent of the map to be created. In most cases you
@@ -259,7 +262,7 @@
mapfile, or a full path.
.. index::
- pair: IMAGECOLOR; MAP
+ pair: MAP; IMAGECOLOR
IMAGECOLOR [r] [g] [b]
Color to initialize the map with (i.e. background color). When
@@ -280,7 +283,7 @@
.. _imagetype:
.. index::
- pair: IMAGETYPE; MAP
+ pair: MAP; IMAGETYPE
IMAGETYPE [gif|png|jpeg|wbmp|gtiff|swf|userdefined]
Output format to generate. See details in the :ref:`OUTPUTFORMAT`
@@ -296,19 +299,19 @@
.. deprecated:: 4.6
.. index::
- pair: LAYER; MAP
+ pair: MAP; LAYER
:ref:`LAYER`
Signals the start of a :ref:`LAYER` object.
.. index::
- pair: LEGEND; MAP
+ pair: MAP; LEGEND
:ref:`LEGEND`
Signals the start of a :ref:`LEGEND` object.
.. index::
- pair: MAXSIZE; MAP
+ pair: MAP; MAXSIZE
MAXSIZE [integer]
Sets the maximum size of the map image. This will override the
@@ -317,32 +320,32 @@
2048x2048). Default is 2048.
.. index::
- pair: NAME; MAP
+ pair: MAP; NAME
NAME [name]
Prefix attached to map, scalebar and legend GIF filenames created
using this mapfile. It should be kept short.
.. index::
- pair: PROJECTION; MAP
+ pair: MAP; PROJECTION
:ref:`PROJECTION`
Signals the start of a :ref:`PROJECTION` object.
.. index::
- pair: QUERYMAP; MAP
+ pair: MAP; QUERYMAP
:ref:`QUERYMAP`
Signals the start of a :ref:`QUERYMAP` object.
.. index::
- pair: REFERENCE; MAP
+ pair: MAP; REFERENCE
:ref:`REFERENCE`
Signals the start of a :ref:`REFERENCE` MAP object.
.. index::
- pair: RESOLUTION; MAP
+ pair: MAP; RESOLUTION
.. _resolution-parameter:
@@ -350,11 +353,8 @@
scale computations. Default is 72.
.. index::
- pair: SCALEDENOM; MAP
+ pair: MAP; SCALEDENOM
-.. index::
SCALEDENOM [double]
Computed scale of the map. Set most often by the application.
Scale is given as the denominator of the actual scale fraction,
@@ -376,33 +376,33 @@
.. deprecated:: 5.0
.. index::
- pair: SCALEBAR; MAP
+ pair: MAP; SCALEBAR
SCALEBAR
Signals the start of a :ref:`SCALEBAR` object.
.. index::
- pair: SHAPEPATH; MAP
+ pair: MAP; SHAPEPATH
SHAPEPATH [filename]
Path to the directory holding the shapefiles or tiles. There can
be further subdirectories under `SHAPEPATH`.
.. index::
- pair: SIZE; MAP
+ pair: MAP; SIZE
SIZE [x][y]
Size in pixels of the output image (i.e. the map).
.. index::
- pair: STATUS; MAP
+ pair: MAP; STATUS
STATUS [on|off]
Is the map active? Sometimes you may wish to turn this off to use
only the reference map or scale bar.
.. index::
- pair: SYMBOLSET; MAP
+ pair: MAP; SYMBOLSET
.. _SYMBOLSET:
@@ -418,11 +418,8 @@
Signals the start of a :ref:`SYMBOL` object.
.. index::
- pair: TEMPLATEPATTERN; MAP
+ pair: MAP; TEMPLATEPATTERN
-.. index::
.. _TEMPLATEPATTERN:
TEMPLATEPATTERN [regular expression]
@@ -442,14 +439,14 @@
declaration to specify if the output images should be transparent.
.. index::
- pair: UNITS; MAP
+ pair: MAP; UNITS
UNITS [feet|inches|kilometers|meters|miles|nauticalmiles|dd]
Units of the map coordinates. Used for scalebar and scale
computations. `Nauticalmiles` was added in MapServer 5.6.
.. index::
- pair: WEB; MAP
+ pair: MAP; WEB
:ref:`WEB`
Signals the start of a :ref:`WEB` object.
Modified: trunk/docs/en/mapfile/map.txt
--- trunk/docs/en/mapfile/map.txt 2011-08-23 12:24:06 UTC (rev 12090)
+++ trunk/docs/en/mapfile/map.txt 2011-08-23 12:33:34 UTC (rev 12091)
@@ -12,7 +12,7 @@
word `END`.
.. index::
- pair: ANGLE; MAP
+ pair: MAP; ANGLE
ANGLE [double]
@@ -41,7 +41,7 @@
.. index::
- pair: CONFIG; MAP
+ pair: MAP; CONFIG
@@ -149,6 +149,9 @@
+.. index::
.. _DATAPATTERN:
@@ -161,7 +164,7 @@
TEMPLATEPATTERN_.
.. index::
- pair: DEBUG; MAP
+ pair: MAP; DEBUG
@@ -233,7 +236,7 @@
option).
.. index::
DEFRESOLUTION [int]
@@ -247,7 +250,7 @@
.. index::
- pair: EXTENT; MAP
+ pair: MAP; EXTENT
@@ -259,7 +262,7 @@
.. index::
@@ -280,7 +283,7 @@
.. _imagetype:
.. index::
.. deprecated:: 4.6
.. index::
- pair: LAYER; MAP
+ pair: MAP; LAYER
:ref:`LAYER`
.. index::
- pair: LEGEND; MAP
+ pair: MAP; LEGEND
:ref:`LEGEND`
.. index::
MAXSIZE [integer]
.. index::
- pair: NAME; MAP
+ pair: MAP; NAME
NAME [name]
.. index::
:ref:`PROJECTION`
.. index::
:ref:`QUERYMAP`
.. index::
:ref:`REFERENCE`
.. index::
.. index::
-.. index::
SCALEDENOM [double]
.. deprecated:: 5.0
.. index::
SCALEBAR
.. index::
.. index::
- pair: SIZE; MAP
+ pair: MAP; SIZE
SIZE [x][y]
.. index::
- pair: STATUS; MAP
+ pair: MAP; STATUS
STATUS [on|off]
.. index::
.. _SYMBOLSET:
.. index::
-.. index::
.. index::
- pair: UNITS; MAP
+ pair: MAP; UNITS
.. index::
- pair: WEB; MAP
+ pair: MAP; WEB
:ref:`WEB`
More information about the mapserver-commits
