[mapserver-commits] r12107 - branches/branch-6-0/docs/en/mapfile branches/branch-6-0/docs/en/mapfile/symbology trunk/docs/en/mapfile trunk/docs/en/mapfile/symbology
Tue Aug 23 19:12:44 EDT 2011
Author: havatv
Date: 2011-08-23 16:12:44 -0700 (Tue, 23 Aug 2011)
New Revision: 12107
   branches/branch-6-0/docs/en/mapfile/expressions.txt
   branches/branch-6-0/docs/en/mapfile/labelencoding.txt
   branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
   branches/branch-6-0/docs/en/mapfile/symbology/examples.txt
   branches/branch-6-0/docs/en/mapfile/template.txt
   branches/branch-6-0/docs/en/mapfile/union.txt
   branches/branch-6-0/docs/en/mapfile/variable_sub.txt
   trunk/docs/en/mapfile/expressions.txt
   trunk/docs/en/mapfile/labelencoding.txt
   trunk/docs/en/mapfile/symbology/construction.txt
   trunk/docs/en/mapfile/symbology/examples.txt
   trunk/docs/en/mapfile/template.txt
   trunk/docs/en/mapfile/union.txt
   trunk/docs/en/mapfile/variable_sub.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/expressions.txt
--- branches/branch-6-0/docs/en/mapfile/expressions.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/expressions.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,6 +1,9 @@
 .. _expressions:
+.. index::
+   single: Expressions
  Expressions
@@ -32,6 +35,10 @@
 * In :ref:`STYLE` `GEOMTRANSFORM`.
+.. index::
+   single: String quotation
 String quotation
@@ -42,6 +49,9 @@
    'This is a string'
    "And this is also a string"
+.. index::
+   single: Quotes escaping
 Quotes escaping in strings
@@ -79,6 +89,9 @@
     "National 'hero' statue"
+.. index::
+   pair: Expressions; Attributes
 Using attributes
@@ -123,6 +136,9 @@
+.. index::
+   single: Expression types
 Expression Types
@@ -139,6 +155,9 @@
 * Logical "MapServer expressions": One or more attributes are compared
   using logical expressions.
+.. index::
+   pair: Expressions; String comparison
 String comparison (equality)
@@ -188,6 +207,9 @@
 .. index:: Regular expressions
+.. index::
+   pair: Expressions; Regular expression comparison
@@ -284,6 +306,9 @@
     editing the build files of some of the components, however.
+.. index::
+   pair: Expressions; Mapserver expressions
@@ -296,6 +321,9 @@
 To be able to use a MapServer expression for a FILTER or EXPRESSION
 value, the expression has to finally become a logical value.
+.. index::
+   pair: Expressions; Logical expressions
 Logical expressions
@@ -325,6 +353,9 @@
   returns true when Expression1 is false.
+.. index::
+   pair: Expressions; String expressions
 String expressions that return a logical value
@@ -397,6 +428,9 @@
    (case insensitive). This operation is identical to the regular
    expression matching described earlier.
+.. index::
+   pair: Expressions; Arithmetic expressions
 Arithmetic expressions that return a logical value
@@ -446,6 +480,9 @@
    returns true when n1 is equal to one of the given numbers.
+.. index::
+   pair: Expressions; Spatial expressions
 Spatial expressions that return a logical value (GEOS)
@@ -492,6 +529,9 @@
    is greater than 0
+.. index::
+   pair: Expressions; String operations
 String operations that return a string
@@ -515,6 +555,9 @@
    more readable
+.. index::
+   pair: Expressions; String functions
 String functions that return a number
@@ -523,6 +566,9 @@
    returns the number of characters of "String1"
+.. index::
+   pair: Expressions; Arithmetic operations
 Arithmetic operations and functions that return a number
@@ -574,6 +620,9 @@
     would return false.
+.. index::
+   pair: Expressions; Spatial functions
 Spatial functions that return a number (GEOS)
@@ -604,6 +653,9 @@
    shape1 and shape2 is subtracted from shape1
+.. index::
+   pair: Expressions; Temporal expressions
Modified: branches/branch-6-0/docs/en/mapfile/labelencoding.txt
--- branches/branch-6-0/docs/en/mapfile/labelencoding.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/labelencoding.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _labelencoding:
+.. index::
+   single: International characters
  Display of International Characters in MapServer
@@ -87,6 +90,9 @@
 libiconv installed to get the complete list of supported encodings on
 that specific system.
+.. index::
+   pair: LABEL; ENCODING
 Step 3: Add ENCODING Parameter to your LABEL Object
Modified: branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _sym_construction:
+.. index::
+   single: Symbol construction
  Cartographical Symbol Construction with MapServer
@@ -17,9 +20,6 @@
     :depth: 3
     :backlinks: top
-.. index:
-    single: Symbol Construction;
 Abstract
@@ -104,6 +104,9 @@
 to achieve transparency (making lower symbols "shine" through upper
 symbols).
+.. index::
+   single: Symbol scaling
 Symbol Scaling
@@ -125,6 +128,9 @@
 :ref:`layer`.
+.. index::
+   single: Symbol specification
 Mapserver and symbol specification
@@ -204,6 +210,9 @@
+.. index::
+   single: Cartographical symbols
 Using Cartographical Symbols in MapServer
@@ -237,6 +246,9 @@
 Dimensions can be specified using decimals.
+.. index::
+   single: Scaling of symbols
 Scaling of Symbols
@@ -268,6 +280,9 @@
 be coordinated to produce a good map.
+.. index::
+   single: Point symbols
 Construction of Point Symbols
@@ -284,7 +299,12 @@
 All point symbols can be rotated using the `ANGLE` parameter.
+.. index::
+   single: Ellipse symbols
+.. index::
+   single: Vector symbols
 Symbols of `TYPE` `vector` and `ellipse`
@@ -321,6 +341,9 @@
 a circle, let X and Y have the same value.
+.. index::
+   single: Truetype symbols
 Symbols of `TYPE` `truetype`
@@ -365,6 +388,9 @@
 position relative to the geometric origin of the geometry.
+.. index::
+   single: Pixmap symbols
 Symbols of `TYPE` `pixmap`
@@ -634,6 +660,9 @@
     END # CLASS
   END # LAYER
+.. index::
+   single: Combining symbols
 Combining symbols
@@ -661,6 +690,8 @@
+.. index::
+   single: Line symbols
 Construction of Line Symbols
@@ -672,6 +703,9 @@
 result.  The `LINECAP`, `LINEJOIN` and `LINEJOINMAXSIZE` parameters
 are used to specify how line ends and corners are to be rendered.
+.. index::
+   single: Line symbol overlay
 Overlaying lines
@@ -686,6 +720,12 @@
 numbered widths.
+.. index::
+   single: GAP
+.. index::
+   single: PATTERN
 Use of the `PATTERN` and `GAP` parameters
@@ -1053,6 +1093,9 @@
     END # CLASS
   END # LAYER
+.. index::
+   pair: STYLE; LINECAP
 `LINECAP`
@@ -1066,6 +1109,9 @@
 default.
+.. index::
+   pair: STYLE; LINEJOIN
 `LINEJOIN`
@@ -1080,6 +1126,9 @@
    Different kinds of linejoins
+.. index::
+   pair: STYLE; LINEJOINMAXSIZE
 `LINEJOINMAXSIZE` (only relevant for `LINEJOIN` `miter`\)
@@ -1101,6 +1150,8 @@
 If *m* > *m_max*, then the connection length will be set to m_max.
+.. index::
+   pair: STYLE; OFFSET
 Use of the `OFFSET` parameter
@@ -1173,6 +1224,9 @@
   |  END # LAYER                                        	 |
+.. index::
+   single: Assymetrical line styling
 Asymmetrical line styling with point symbols
@@ -1189,6 +1243,9 @@
 placed far away from the line.
+.. index::
+   single: Area symbols
 Area Symbols
@@ -1208,6 +1265,9 @@
 The AGG renderer uses anti-aliasing by default, so edge effects around
 the symbols can occure.
+.. index::
+   single: Hatch polygon fill
 Hatch fill
@@ -1306,6 +1366,9 @@
+.. index::
+   single: Pixmap polygon fill
 Polygon fills with symbols of `TYPE` `pixmap`
@@ -1442,6 +1505,9 @@
    Polygon fill - hatch
+.. index::
+   single: Vector polygon fill
 Polygon fills with symbols of `TYPE` `vector`
@@ -2133,6 +2199,9 @@
 Tricks
+.. index::
+   single: Symbol center
 Changing the center of a point symbol
Modified: branches/branch-6-0/docs/en/mapfile/symbology/examples.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/examples.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/symbology/examples.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _sym_examples:
+.. index::
+   single: Symbology examples
  Symbology Examples
Modified: branches/branch-6-0/docs/en/mapfile/template.txt
--- branches/branch-6-0/docs/en/mapfile/template.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/template.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _template:
+.. index::
+   single: Templating
  Templating
Modified: branches/branch-6-0/docs/en/mapfile/union.txt
--- branches/branch-6-0/docs/en/mapfile/union.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/union.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _union:
+.. index::
+   single: Union layer
  Union Layer
@@ -24,19 +27,21 @@
 Requirements
-This is a native MapServer option that doesn't use any external libraries to support it.
+This is a native MapServer option that doesn't use any external
+libraries to support it.
 Mapfile Configuration
 * The CONNECTIONTYPE parameter must be set to UNION.
-* The CONNECTION parameter must contain a comma separated list of the source layer names.
-* All of the source layers and the union layer must be the same TYPE (e.g. all must be TYPE
-  POINT, or all TYPE POLYGON etc.)
+* The CONNECTION parameter must contain a comma separated list of the
+  source layer names.
+* All of the source layers and the union layer must be the same TYPE
+  (e.g. all must be TYPE POINT, or all TYPE POLYGON etc.)
 .. note::
-    You may wish to disable the visibility (change their STATUS) of the source layers
-    to avoid displaying the features twice.
+    You may wish to disable the visibility (change their STATUS) of
+    the source layers to avoid displaying the features twice.
 For example:
@@ -79,31 +84,37 @@
 Feature attributes
-In the LAYER definition you may refer to any attributes supported by each of the source layers.
-In addition to the source layer attributes the union layer provides the following additional attributes:
+In the LAYER definition you may refer to any attributes supported by
+each of the source layers.
+In addition to the source layer attributes the union layer provides
+the following additional attributes:
 1) Combine:SourceLayerName - The name of the source layer the feature belongs to
 2) Combine:SourceLayerGroup - The group of the source layer the feature belongs to
-During the selection / feature query operations only the 'Combine:SourceLayerName' and 'Combine:SourceLayerGroup'
-attributes are provided by default. The set of the provided attributes can manually be overridden
-(and further attributes can be exposed) by using the ITEMS processing option (refer to the example above).
+During the selection / feature query operations only the
+'Combine:SourceLayerName' and 'Combine:SourceLayerGroup' attributes
+are provided by default. The set of the provided attributes can
+manually be overridden (and further attributes can be exposed) by
+using the ITEMS processing option (refer to the example above).
 Classes and Styles
-We can define the symbology and labelling for the union layers in the same way as for
-any other layer by specifying the classes and styles. In addition the STYLEITEM AUTO
-option is also supported for the union layer, which provides to display
-the features as specified at the source layers. The source layers
-may also use the STYLEITEM AUTO setting if the underlying data source provides that.
+We can define the symbology and labelling for the union layers in the
+same way as for any other layer by specifying the classes and
+styles. In addition the STYLEITEM AUTO option is also supported for
+the union layer, which provides to display the features as specified
+at the source layers. The source layers may also use the STYLEITEM
+AUTO setting if the underlying data source provides that.
 Projections
-For speed, it is recommended to always use the same projection for the union layer and source layers. However
-MapServer will reproject the source layers to the union layer if requested.  (for more information on projections
-in MapServer refer to :ref:`PROJECTION`)
+For speed, it is recommended to always use the same projection for the
+union layer and source layers. However MapServer will reproject the
+source layers to the union layer if requested.  (for more information
+on projections in MapServer refer to :ref:`PROJECTION`)
 Examples
@@ -111,10 +122,11 @@
 Mapfile Example
-The follow example contains 3 source layers in different formats, and one layer (yellow)
-in a different projection.  The union layer uses the **STYLEITEM "AUTO"** parameter to
-draw the styles from the source layers.  (in this case MapServer will reproject the yellow
-features, in EPSG:4326, for the union layer, which is in EPSG:3978).
+The follow example contains 3 source layers in different formats, and
+one layer (yellow) in a different projection.  The union layer uses
+the **STYLEITEM "AUTO"** parameter to draw the styles from the source
+layers.  (in this case MapServer will reproject the yellow features,
+in EPSG:4326, for the union layer, which is in EPSG:3978).
 .. image:: ../images/union.png
@@ -214,4 +226,4 @@
   $oClass = ms_newClassObj($oLayer);
\ No newline at end of file
Modified: branches/branch-6-0/docs/en/mapfile/variable_sub.txt
--- branches/branch-6-0/docs/en/mapfile/variable_sub.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ branches/branch-6-0/docs/en/mapfile/variable_sub.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _variable_sub:
+.. index::
+   single: Variable substitution
  Variable Substitution
@@ -29,4 +32,4 @@
 This feature is only available in the CGI version of MapServer through a
 mapfile pre-processor. If you are using MapScript, you will have to code
 the substitution logic into your application yourself (By writing your
-own pre-processor).
+own pre-processor).
Modified: trunk/docs/en/mapfile/expressions.txt
--- trunk/docs/en/mapfile/expressions.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/expressions.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,6 +1,9 @@
 .. _expressions:
+.. index::
  Expressions
@@ -32,6 +35,10 @@
+.. index::
 String quotation
@@ -42,6 +49,9 @@
    'This is a string'
+.. index::
@@ -79,6 +89,9 @@
+.. index::
 Using attributes
@@ -123,6 +136,9 @@
+.. index::
 Expression Types
@@ -139,6 +155,9 @@
+.. index::
@@ -188,6 +207,9 @@
+.. index::
@@ -284,6 +306,9 @@
+.. index::
@@ -296,6 +321,9 @@
+.. index::
 Logical expressions
@@ -325,6 +353,9 @@
+.. index::
@@ -397,6 +428,9 @@
+.. index::
@@ -446,6 +480,9 @@
+.. index::
@@ -492,6 +529,9 @@
    is greater than 0
+.. index::
@@ -515,6 +555,9 @@
    more readable
+.. index::
@@ -523,6 +566,9 @@
+.. index::
@@ -574,6 +620,9 @@
     would return false.
+.. index::
@@ -604,6 +653,9 @@
+.. index::
Modified: trunk/docs/en/mapfile/labelencoding.txt
--- trunk/docs/en/mapfile/labelencoding.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/labelencoding.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _labelencoding:
+.. index::
@@ -87,6 +90,9 @@
+.. index::
Modified: trunk/docs/en/mapfile/symbology/construction.txt
--- trunk/docs/en/mapfile/symbology/construction.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/symbology/construction.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
+.. index::
@@ -17,9 +20,6 @@
     :depth: 3
     :backlinks: top
-.. index:
 Abstract
@@ -104,6 +104,9 @@
 symbols).
+.. index::
 Symbol Scaling
@@ -125,6 +128,9 @@
 :ref:`layer`.
+.. index::
@@ -204,6 +210,9 @@
+.. index::
@@ -237,6 +246,9 @@
+.. index::
 Scaling of Symbols
@@ -268,6 +280,9 @@
+.. index::
+.. index::
+.. index::
@@ -321,6 +341,9 @@
+.. index::
@@ -365,6 +388,9 @@
+.. index::
@@ -634,6 +660,9 @@
     END # CLASS
   END # LAYER
+.. index::
 Combining symbols
@@ -661,6 +690,8 @@
+.. index::
@@ -672,6 +703,9 @@
+.. index::
 Overlaying lines
 numbered widths.
+.. index::
+   single: GAP
+.. index::
+   single: PATTERN
     END # CLASS
   END # LAYER
+.. index::
 `LINECAP`
 default.
+.. index::
 `LINEJOIN`
+.. index::
+.. index::
   |  END # LAYER                                        	 |
+.. index::
+.. index::
 Area Symbols
+.. index::
 Hatch fill
+.. index::
+.. index::
 Tricks
+.. index::
Modified: trunk/docs/en/mapfile/symbology/examples.txt
--- trunk/docs/en/mapfile/symbology/examples.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/symbology/examples.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _sym_examples:
+.. index::
  Symbology Examples
Modified: trunk/docs/en/mapfile/template.txt
--- trunk/docs/en/mapfile/template.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/template.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _template:
+.. index::
  Templating
Modified: trunk/docs/en/mapfile/union.txt
--- trunk/docs/en/mapfile/union.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/union.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _union:
+.. index::
  Union Layer
@@ -24,19 +27,21 @@
 Requirements
 .. note::
 For example:
@@ -79,31 +84,37 @@
 Feature attributes
 Classes and Styles
 Projections
 Examples
 Mapfile Example
@@ -214,4 +226,4 @@
Modified: trunk/docs/en/mapfile/variable_sub.txt
--- trunk/docs/en/mapfile/variable_sub.txt	2011-08-23 22:23:45 UTC (rev 12106)
+++ trunk/docs/en/mapfile/variable_sub.txt	2011-08-23 23:12:44 UTC (rev 12107)
@@ -1,5 +1,8 @@
 .. _variable_sub:
+.. index::
@@ -29,4 +32,4 @@
