[mapserver-commits] r12136 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:00:50 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:00:50 -0700 (Fri, 26 Aug 2011)
New Revision: 12136
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/image.c
   trunk/mapserver/mapcache/src/mod_geocache.c
add an expires header and configuration option
closes issue 12.
thomas.bonfort | 2010-10-19 18:44:34 +0200 (Tue, 19 Oct 2010)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:00:44 UTC (rev 12135)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:00:50 UTC (rev 12136)
@@ -25,6 +25,7 @@
 #include <libxml/tree.h>
 #include "util.h"
 #include <assert.h>
+#include <apr_time.h>
 #define GEOCACHE_SUCCESS 0
@@ -63,6 +64,7 @@
    int sx,sy;
    geocache_buffer *data;
    void *lock;
+   apr_time_t mtime;
 } geocache_tile;
 typedef struct {
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:00:44 UTC (rev 12135)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:00:50 UTC (rev 12136)
@@ -165,7 +165,7 @@
    _geocache_cache_disk_tile_key(r, tile, &filename);
    if(apr_file_open(&f, filename, APR_FOPEN_READ|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
          APR_OS_DEFAULT, r->pool) == APR_SUCCESS) {
-      rv = apr_file_info_get(&finfo, APR_FINFO_SIZE, f);
+      rv = apr_file_info_get(&finfo, APR_FINFO_SIZE|APR_FINFO_MTIME, f);
       if(!finfo.size) {
          ap_log_rerror(APLOG_MARK, APLOG_ERR, rv, r, "tile %s has no data",filename);
          return GEOCACHE_FAILURE;
@@ -180,6 +180,7 @@
        * any error that might happen at this stage should only occur if the tile isn't already cached,
        * i.e. normally only once.
+      tile->mtime = finfo.mtime;
       tile->data = geocache_buffer_create(size,r->pool);
       //manually add the data to our buffer
       apr_file_read(f,(void*)tile->data->buf,&size);
Modified: trunk/mapserver/mapcache/src/image.c
--- trunk/mapserver/mapcache/src/image.c	2011-08-26 11:00:44 UTC (rev 12135)
+++ trunk/mapserver/mapcache/src/image.c	2011-08-26 11:00:50 UTC (rev 12136)
@@ -63,16 +63,18 @@
 geocache_tile* geocache_image_merge_tiles(request_rec *r, geocache_tile **tiles, int ntiles) {
    geocache_image *base,*overlay;
    int i;
-   geocache_tile *tile;
+   geocache_tile *tile = apr_pcalloc(r->pool,sizeof(geocache_tile));
+   tile->mtime = tiles[0]->mtime;
    base = geocache_imageio_decode(r, tiles[0]->data);
    if(!base) return NULL;
    for(i=1; i<ntiles; i++) {
       overlay = geocache_imageio_decode(r, tiles[i]->data);
+      if(tile->mtime < tiles[i]->mtime)
+         tile->mtime = tiles[i]->mtime;
       if(!overlay) return NULL;
       _geocache_image_merge(r, base, overlay);
-   tile = apr_pcalloc(r->pool,sizeof(geocache_tile));
    tile->data = geocache_imageio_encode(r,base, GEOCACHE_IMAGE_FORMAT_PNG);
    tile->sx = base->w;
    tile->sy = base->h;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:00:44 UTC (rev 12135)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:00:50 UTC (rev 12136)
@@ -22,7 +22,9 @@
 #include <httpd.h>
 #include <http_config.h>
 #include <http_protocol.h>
+#include <http_request.h>
 #include <apr_strings.h>
 #include <http_log.h>
 #include "geocache.h"
@@ -34,13 +36,17 @@
 static int geocache_write_tile(request_rec *r, geocache_tile *tile) {
+   int rc;
    if(tile->tileset->source->image_format == GEOCACHE_IMAGE_FORMAT_PNG)
       ap_set_content_type(r, "image/png");
    else
       ap_set_content_type(r, "image/jpeg");
+   ap_update_mtime(r, tile->mtime);
+   if((rc = ap_meets_conditions(r)) != OK) {
+      return rc;
+   ap_set_last_modified(r);
    ap_set_content_length(r,tile->data->size);
    ap_rwrite((void*)tile->data->buf, tile->data->size, r);
@@ -65,9 +71,11 @@
    config = ap_get_module_config(r->per_dir_config, &geocache_module);
    for(i=0;i<GEOCACHE_SERVICES_COUNT;i++) {
+      /* loop through the services that have been configured */
       geocache_service *service = config->services[i];
       if(!service) continue;
       request = service->parse_request(r,params,config);
+      /* the service has recognized the request if it returns a non NULL value */
       if(request)
          break;
@@ -82,14 +90,6 @@
       if(rv != GEOCACHE_SUCCESS) {
          return HTTP_NOT_FOUND;
-#ifdef MERGE_ENABLED
-      if(request->ntiles>1) {
-         if(tile->tileset->source->image_format != GEOCACHE_IMAGE_FORMAT_PNG) {
-            ap_rprintf(r,"tile merging only supports png source (requested source: %s",tile->tileset->source->name);
-            return HTTP_BAD_REQUEST;
-#endif
    if(request->ntiles == 1) {
       tile = request->tiles[0];
