[mapserver-commits] r12139 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:01:04 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:01:04 -0700 (Fri, 26 Aug 2011)
New Revision: 12139
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/image.c
trunk/mapserver/mapcache/src/mod_geocache.c
trunk/mapserver/mapcache/src/tileset.c
add documentation, split imageio into png and jpeg files
thomas.bonfort | 2010-10-25 10:45:47 +0200 (Mon, 25 Oct 2010)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:00:58 UTC (rev 12138)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:01:04 UTC (rev 12139)
@@ -39,6 +39,7 @@
<metatile>5 5</metatile>
<metabuffer>30</metabuffer>
<format>JPG</format>
+ <expires>3600</expires>
</tileset>
<tileset name="test2">
<source>nexrad</source>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:00:58 UTC (rev 12138)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:01:04 UTC (rev 12139)
@@ -65,6 +65,7 @@
geocache_buffer *data;
void *lock;
apr_time_t mtime;
+ int expires;
} geocache_tile;
typedef struct {
@@ -146,6 +147,7 @@
double *resolutions;
int metasize_x, metasize_y;
int metabuffer;
+ int expires;
geocache_image_format_type format;
geocache_cache *cache;
geocache_source *source;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:00:58 UTC (rev 12138)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:01:04 UTC (rev 12139)
@@ -252,17 +252,25 @@
tileset->metasize_x = values[0];
tileset->metasize_y = values[1];
xmlFree(value);
+ } else if(!xmlStrcmp(cur_node->name, BAD_CAST "expires")) {
+ value = (char*)xmlNodeGetContent(cur_node);
+ char *endptr;
+ tileset->expires = (int)strtol(value,&endptr,10);
+ if(*endptr != 0)
+ return apr_psprintf(pool,"failed to parse expires %s."
+ "(expecting an integer, "
+ "eg <expires>3600</expires>",
+ value);
+ xmlFree(value);
} else if(!xmlStrcmp(cur_node->name, BAD_CAST "metabuffer")) {
char *endptr;
tileset->metabuffer = (int)strtol(value,&endptr,10);
if(*endptr != 0)
return apr_psprintf(pool,"failed to parse metabuffer %s."
- "(expecting an integer integer, "
"eg <metabuffer>1</metabuffer>",
value);
xmlFree(value);
} else if(!xmlStrcmp(cur_node->name, BAD_CAST "format")) {
Modified: trunk/mapserver/mapcache/src/image.c
--- trunk/mapserver/mapcache/src/image.c 2011-08-26 11:00:58 UTC (rev 12138)
+++ trunk/mapserver/mapcache/src/image.c 2011-08-26 11:01:04 UTC (rev 12139)
@@ -65,12 +65,16 @@
int i;
geocache_tile *tile = apr_pcalloc(r->pool,sizeof(geocache_tile));
tile->mtime = tiles[0]->mtime;
+ tile->expires = tiles[0]->expires;
base = geocache_imageio_decode(r, tiles[0]->data);
if(!base) return NULL;
for(i=1; i<ntiles; i++) {
overlay = geocache_imageio_decode(r, tiles[i]->data);
if(tile->mtime < tiles[i]->mtime)
tile->mtime = tiles[i]->mtime;
+ if(tiles[i]->expires && ((tile->expires < tiles[i]->expires) || !tile->expires)) {
+ tile->expires = tiles[i]->expires;
if(!overlay) return NULL;
_geocache_image_merge(r, base, overlay);
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:00:58 UTC (rev 12138)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:01:04 UTC (rev 12139)
@@ -41,6 +41,16 @@
if((rc = ap_meets_conditions(r)) != OK) {
return rc;
+ if(tile->expires) {
+ apr_time_t now = apr_time_now();
+ apr_time_t additional = apr_time_from_sec(tile->expires);
+ apr_time_t expires = now + additional;
+ apr_table_mergen(r->headers_out, "Cache-Control",apr_psprintf(r->pool, "max-age=%d", tile->expires));
+ char *timestr = apr_palloc(r->pool, APR_RFC822_DATE_LEN);
+ apr_rfc822_date(timestr, expires);
+ apr_table_setn(r->headers_out, "Expires", timestr);
ap_set_last_modified(r);
ap_set_content_length(r,tile->data->size);
if(tile->tileset->source->image_format == GEOCACHE_IMAGE_FORMAT_PNG)
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:00:58 UTC (rev 12138)
+++ trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:01:04 UTC (rev 12139)
@@ -161,6 +161,7 @@
geocache_tileset* tileset = (geocache_tileset*)apr_pcalloc(pool, sizeof(geocache_tileset));
tileset->metasize_x = tileset->metasize_y = 1;
tileset->metabuffer = 0;
+ tileset->expires = 0;
tileset->tile_sx = tileset->tile_sy = 256;
tileset->extent[0]=tileset->extent[1]=tileset->extent[2]=tileset->extent[3]=0;
tileset->forwarded_params = apr_table_make(pool,1);
@@ -174,6 +175,7 @@
geocache_tile* geocache_tileset_tile_create(geocache_tileset *tileset, apr_pool_t *pool) {
geocache_tile *tile = (geocache_tile*)apr_pcalloc(pool, sizeof(geocache_tile));
tile->tileset = tileset;
+ tile->expires = tileset->expires;
tile->sx = tileset->tile_sx;
tile->sy = tileset->tile_sy;
return tile;
More information about the mapserver-commits
