[mapserver-commits] r12143 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:01:31 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:01:31 -0700 (Fri, 26 Aug 2011)
New Revision: 12143
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/mod_geocache.doxyfile
   trunk/mapserver/mapcache/src/imageio_png.c
   trunk/mapserver/mapcache/src/services.c
   trunk/mapserver/mapcache/src/tileset.c
small optimisation for image blending
fix bug when computing quantized image
thomas.bonfort | 2010-10-26 18:03:47 +0200 (Tue, 26 Oct 2010)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:01:25 UTC (rev 12142)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:01:31 UTC (rev 12143)
@@ -62,6 +62,7 @@
 typedef struct geocache_request geocache_request;
 typedef struct geocache_service  geocache_service;
 typedef struct geocache_service_wms geocache_service_wms;
+typedef struct geocache_service_wmts geocache_service_wmts;
 typedef struct geocache_service_tms geocache_service_tms;
 typedef struct geocache_server_cfg geocache_server_cfg;
 typedef struct geocache_image geocache_image;
@@ -238,10 +239,12 @@
 /** \defgroup services Services*/
-#define GEOCACHE_SERVICES_COUNT 2
+#define GEOCACHE_SERVICES_COUNT 3
-typedef enum {GEOCACHE_SERVICE_WMS=0, GEOCACHE_SERVICE_TMS} geocache_service_type;
+typedef enum {GEOCACHE_SERVICE_WMTS=0, GEOCACHE_SERVICE_TMS, GEOCACHE_SERVICE_WMS} geocache_service_type;
+typedef enum {GEOCACHE_UNIT_UNSET = 0, GEOCACHE_UNIT_METERS, GEOCACHE_UNIT_DEGREES, GEOCACHE_UNIT_FEET} geocache_unit;
 /** \interface geocache_service
  * \brief a standard service (eg WMS, TMS)
@@ -270,6 +273,14 @@
    geocache_service service;
+/**\class geocache_service_wmts
+ * \brief a WMTS service
+ * \implements geocache_service
+struct geocache_service_wmts {
+   geocache_service service;
  * \brief create and initialize a geocache_service_wms
  * \memberof geocache_service_wms
@@ -282,6 +293,12 @@
 geocache_service* geocache_service_tms_create(apr_pool_t *pool);
+ * \brief create and initialize a geocache_service_wmts
+ * \memberof geocache_service_wmms
+geocache_service* geocache_service_wmts_create(apr_pool_t *pool);
 /** \defgroup image Image Data Handling */
@@ -313,14 +330,17 @@
  \brief merge a set of tiles into a single image
  \param tiles the list of tiles to merge
+ \param ntiles the number of tiles in the list of tiles
  \param format the format to encode the resulting image
+ \param r the context
  \returns a new tile with the merged image
 geocache_tile* geocache_image_merge_tiles(request_rec *r, geocache_image_format *format, geocache_tile **tiles, int ntiles);
  * \brief split the given metatile into tiles
- * @param mt the metatile to split
+ * \param mt the metatile to split
+ * \param r the context
 int geocache_image_metatile_split(geocache_metatile *mt, request_rec *r);
@@ -473,6 +493,11 @@
     * the SRS of the tileset
    char *srs;
+    * the unit of measure of the tileset
+   geocache_unit units;
     * width of a tile in pixels
@@ -545,6 +570,19 @@
 int geocache_tileset_tile_lookup(geocache_tile *tile, double *bbox, request_rec *r);
+ * compute level for a given resolution
+ * computes the integer level for the given resolution. the input resolution will be set to the exact
+ * value configured for the tileset, to compensate for rounding errors that could creep in if using
+ * the resolution calculated from input parameters
+ * \returns GEOCACHE_TILESET_WRONG_RESOLUTION if the given resolution is't configured
+ * \returns GEOCACHE_SUCCESS if the level was found
+int geocache_tileset_get_level(geocache_tileset *tileset, double *resolution, int *level, request_rec *r);
 int geocache_tileset_tile_get(geocache_tile *tile, request_rec *r);
@@ -586,6 +624,15 @@
+ * compression strategy to apply
+typedef enum {
+    GEOCACHE_COMPRESSION_BEST, /**< best but slowest compression*/
+    GEOCACHE_COMPRESSION_FAST, /**< fast compression*/
+    GEOCACHE_COMPRESSION_DEFAULT /**< default compression*/
+} geocache_compression_type;
+/**\interface geocache_image_format
  * \brief an image format
  * \sa geocache_image_format_jpeg
  * \sa geocache_image_format_png
@@ -603,16 +650,7 @@
  * \ingroup imageio */
- * compression strategy to apply
-typedef enum {
-    GEOCACHE_COMPRESSION_BEST, /**< best but slowest compression*/
-    GEOCACHE_COMPRESSION_FAST, /**< fast compression*/
-    GEOCACHE_COMPRESSION_DEFAULT /**< default compression*/
-} geocache_compression_type;
+/**\class geocache_image_format_png
  * \brief PNG image format
  * \extends geocache_image_format
  * \sa geocache_image_format_png_q
@@ -622,7 +660,7 @@
    geocache_compression_type compression_level; /**< PNG compression level to apply */
+/**\class geocache_image_format_png_q
  * \brief Quantized PNG format
  * \extends geocache_image_format_png
@@ -641,7 +679,7 @@
  * \brief create a format capable of creating RGBA png
- * \memberof geocache_imageio_png_format
+ * \memberof geocache_image_format_png
  * @param pool
  * @param name
  * @param compression the ZLIB compression to apply
@@ -651,7 +689,7 @@
  * \brief create a format capable of creating quantized png
- * \memberof geocache_imageio_png_q_format
+ * \memberof geocache_image_format_png_q
  * @param pool
  * @param name
@@ -666,7 +704,7 @@
+/**\class geocache_image_format_jpeg
  * \brief JPEG image format
Modified: trunk/mapserver/mapcache/mod_geocache.doxyfile
--- trunk/mapserver/mapcache/mod_geocache.doxyfile	2011-08-26 11:01:25 UTC (rev 12142)
+++ trunk/mapserver/mapcache/mod_geocache.doxyfile	2011-08-26 11:01:31 UTC (rev 12143)
@@ -298,7 +298,7 @@
 # Private class members and static file members will be hidden unless
 # the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
-EXTRACT_ALL = YES
+EXTRACT_ALL = NO
 # If the EXTRACT_PRIVATE tag is set to YES all private members of a class
 # will be included in the documentation.
@@ -308,7 +308,7 @@
 # If the EXTRACT_STATIC tag is set to YES all static members of a file
-EXTRACT_STATIC = NO
+EXTRACT_STATIC = YES
 # If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
 # defined locally in source files will be included in the documentation.
@@ -337,14 +337,14 @@
 # various overviews, but no documentation section is generated.
 # This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_MEMBERS = NO
+HIDE_UNDOC_MEMBERS = YES
 # If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
 # undocumented classes that are normally visible in the class hierarchy.
 # If set to NO (the default) these classes will be included in the various
 # overviews. This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_CLASSES = NO
+HIDE_UNDOC_CLASSES = YES
 # If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
 # friend (class|struct|union) declarations.
@@ -1458,7 +1458,7 @@
 # this option also works with HAVE_DOT disabled, but it is recommended to
 # install and use dot, since it yields more powerful graphs.
-CLASS_DIAGRAMS = YES
+CLASS_DIAGRAMS = NO
 # You can define message sequence charts within doxygen comments using the \msc
 # command. Doxygen will then run the mscgen tool (see
@@ -1480,7 +1480,7 @@
 # toolkit from AT&T and Lucent Bell Labs. The other options in this section
 # have no effect if this option is set to NO (the default)
-HAVE_DOT = NO
+HAVE_DOT = YES
 # The DOT_NUM_THREADS specifies the number of dot invocations doxygen is
 # allowed to run in parallel. When set to 0 (the default) doxygen will
Modified: trunk/mapserver/mapcache/src/imageio_png.c
--- trunk/mapserver/mapcache/src/imageio_png.c	2011-08-26 11:01:25 UTC (rev 12142)
+++ trunk/mapserver/mapcache/src/imageio_png.c	2011-08-26 11:01:31 UTC (rev 12143)
@@ -188,6 +188,8 @@
    return buffer;
+/** \cond DONOTDOCUMENT */
  * derivations from pngquant and ppmquant
@@ -954,6 +956,8 @@
    free( (char*) acht );
+/** \endcond DONOTDOCUMENT */
 int _geocache_imageio_remap_palette(unsigned char *pixels, int npixels, rgbaPixel *palette, int numPaletteEntries, rgbPixel *rgb, unsigned char *a, int *num_a) {
    int bot_idx, top_idx, x;
    int remap[256];
Modified: trunk/mapserver/mapcache/src/services.c
--- trunk/mapserver/mapcache/src/services.c	2011-08-26 11:01:25 UTC (rev 12142)
+++ trunk/mapserver/mapcache/src/services.c	2011-08-26 11:01:31 UTC (rev 12143)
@@ -8,6 +8,7 @@
 #include "geocache.h"
 #include <http_log.h>
 #include <apr_strings.h>
+#include <math.h>
 /** \addtogroup services */
@@ -84,6 +85,91 @@
+geocache_request* _geocache_service_wmts_parse_request(request_rec *r, apr_table_t *params, geocache_cfg *config) {
+   char *str = NULL;
+   double scale,res;
+   int tilerow,tilecol;
+   char *endptr;
+   int maxY;
+   double geocache_meters_per_unit[] = {
+         -1, /*GEOCACHE_UNIT_UNSET*/
+         1.0, /*GEOCACHE_UNIT_METERS*/
+         111118.752, /*GEOCACHE_UNIT_DEGREES*/
+         0.3048 /*GEOCACHE_UNIT_FEET*/
+   geocache_request *request = NULL;
+   str = (char*)apr_table_get(params,"SCALE");
+   if(!str)
+      str = (char*)apr_table_get(params,"scale");
+   if(!str) {
+      return NULL;
+   } else {
+      scale = strtod(str,&endptr);
+      if(*endptr != 0) {
+         ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts request with invalid scale %s", str);
+         return NULL;
+   str = (char*)apr_table_get(params,"TILEROW");
+   if(!str)
+      str = (char*)apr_table_get(params,"tilerow");
+   if(!str) {
+      return NULL;
+   } else {
+      tilerow = strtol(str,&endptr,10);
+         ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts request with invalid tilerow %s", str);
+         return NULL;
+   str = (char*)apr_table_get(params,"TILECOL");
+   if(!str)
+      str = (char*)apr_table_get(params,"tilecol");
+   if(!str) {
+      return NULL;
+   } else {
+      tilecol = strtol(str,&endptr,10);
+         ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts request with invalid tilecol %s", str);
+         return NULL;
+   str = (char*)apr_table_get(params,"LAYER");
+   if(!str)
+      str = (char*)apr_table_get(params,"layer");
+   if(!str) {
+      ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts request with no layer");
+      return NULL;
+   } else {
+      geocache_tileset *tileset = geocache_configuration_get_tileset(config,str);
+      if(!tileset) {
+         ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts request with invalid layer %s",str);
+         return NULL;
+      if(tileset->units == GEOCACHE_UNIT_UNSET) {
+         ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts on layer %s that has no unit configured",str);
+         return NULL;
+      request = (geocache_request*)apr_pcalloc(r->pool,sizeof(geocache_request));
+      request->ntiles = 1;
+      request->tiles = (geocache_tile**)apr_pcalloc(r->pool,sizeof(geocache_tile*));
+      request->tiles[0] = geocache_tileset_tile_create(tileset,r->pool);
+      res = .00028 * scale / geocache_meters_per_unit[tileset->units];
+      if(GEOCACHE_SUCCESS != geocache_tileset_get_level(tileset, &res, &request->tiles[0]->z, r)) {
+         ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, r, "received wmts on layer %s with invalid resolution / level", tileset->name);
+         return NULL;
+      maxY = round((tileset->extent[3] - tileset->extent[1])/(res * tileset->tile_sy)) -1;
+      request->tiles[0]->x = tilecol;
+      request->tiles[0]->y = maxY - tilerow;
+      return request;
  * \brief parse a TMS request
  * \private \memberof geocache_service_tms
@@ -170,6 +256,13 @@
    return (geocache_service*)service;
+geocache_service* geocache_service_wmts_create(apr_pool_t *pool) {
+   geocache_service_wmts* service = (geocache_service_wmts*)apr_pcalloc(pool, sizeof(geocache_service_wmts));
+   service->service.type = GEOCACHE_SERVICE_WMTS;
+   service->service.parse_request = _geocache_service_wmts_parse_request;
+   return (geocache_service*)service;
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:01:25 UTC (rev 12142)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:01:31 UTC (rev 12143)
@@ -16,7 +16,7 @@
    return GEOCACHE_MAX(rx,ry);
-static int _geocache_tileset_get_level(geocache_tileset *tileset, double *resolution, int *level, request_rec *r) {
+int geocache_tileset_get_level(geocache_tileset *tileset, double *resolution, int *level, request_rec *r) {
    double max_diff = *resolution / (double)GEOCACHE_MAX(tileset->tile_sx, tileset->tile_sy);
    int i;
    for(i=0; i<tileset->levels; i++) {
@@ -38,7 +38,7 @@
 static int _geocache_tileset_tile_get_cell(geocache_tile *tile, double *bbox, request_rec *r) {
    int ret;
    double res = _geocache_tileset_get_resolution(tile->tileset,bbox);
-   ret = _geocache_tileset_get_level(tile->tileset,&res,&(tile->z),r);
+   ret = geocache_tileset_get_level(tile->tileset,&res,&(tile->z),r);
    if(ret != GEOCACHE_SUCCESS) return ret;
    /* TODO: strict mode
            if exact and self.extent_type == "strict" and not self.contains((minx, miny), res):
@@ -161,6 +161,7 @@
    geocache_tileset* tileset = (geocache_tileset*)apr_pcalloc(pool, sizeof(geocache_tileset));
    tileset->metasize_x = tileset->metasize_y = 1;
    tileset->metabuffer = 0;
+   tileset->units = GEOCACHE_UNIT_UNSET;
    tileset->expires = 0;
    tileset->tile_sx = tileset->tile_sy = 256;
    tileset->extent[0]=tileset->extent[1]=tileset->extent[2]=tileset->extent[3]=0;
