[mapserver-commits] r12152 - trunk/mapserver/mapcache/src
Fri Aug 26 07:02:16 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:02:16 -0700 (Fri, 26 Aug 2011)
New Revision: 12152
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/http.c
   trunk/mapserver/mapcache/src/tileset.c
dont use echo -n
thomas.bonfort | 2010-11-05 12:22:06 +0100 (Fri, 05 Nov 2010)
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:02:12 UTC (rev 12151)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:02:16 UTC (rev 12152)
@@ -198,7 +198,7 @@
    apr_file_t *f;
 #ifdef DEBUG
    if(tile->lock) {
-      r->errmsg = apr_psprintf(r->pool,  "### BUG ### waiting for a lock we have created ourself");
+      r->set_error(r,GEOCACHE_DISK_ERROR,  "### BUG ### waiting for a lock we have created ourself");
       return GEOCACHE_FAILURE;
 #endif
@@ -276,11 +276,11 @@
 #ifdef DEBUG
    /* all this should be checked at a higher level */
    if(!tile->data || !tile->data->size) {
-      r->errmsg = apr_psprintf(r->pool,  "attempting to write empty tile to disk");
+      r->set_error(r,GEOCACHE_DISK_ERROR,"attempting to write empty tile to disk");
    if(!tile->lock) {
-      r->errmsg = apr_psprintf(r->pool,  "attempting to write to an unlocked tile");
+      r->set_error(r,GEOCACHE_DISK_ERROR,"attempting to write to an unlocked tile");
 #endif
@@ -312,7 +312,7 @@
             apr_file_close(f);
 #ifdef DEBUG
-            ap_log_rerror(APLOG_MARK, APLOG_DEBUG, 0, r, "created blank tile %s",blankname);
+            r->log(r,GEOCACHE_DEBUG,"created blank tile %s",blankname);
 #endif
          if(apr_file_link(blankname,filename) != GEOCACHE_SUCCESS) {
@@ -320,7 +320,7 @@
             return GEOCACHE_FAILURE; /* we could not create the file */
 #ifdef DEBUG
-         r->errmsg = apr_psprintf(r->pool,  "linked blank tile %s to %s",filename,blankname);
+         r->log(r, GEOCACHE_DEBUG, "linked blank tile %s to %s",filename,blankname);
 #endif
          return GEOCACHE_SUCCESS;
Modified: trunk/mapserver/mapcache/src/http.c
--- trunk/mapserver/mapcache/src/http.c	2011-08-26 11:02:12 UTC (rev 12151)
+++ trunk/mapserver/mapcache/src/http.c	2011-08-26 11:02:16 UTC (rev 12152)
@@ -35,7 +35,7 @@
    /* specify URL to get */
    curl_easy_setopt(curl_handle, CURLOPT_URL, url);
 #ifdef DEBUG
-   r->log(r, GEOCACHE_LOG_DEBUG, "##### START #####\ncurl requesting url %s",url);
+   r->log(r, GEOCACHE_DEBUG, "##### START #####\ncurl requesting url %s",url);
 #endif
    /* send all data to this function  */
    curl_easy_setopt(curl_handle, CURLOPT_WRITEFUNCTION, _geocache_curl_memory_callback);
@@ -60,7 +60,7 @@
    /* cleanup curl stuff */
    curl_easy_cleanup(curl_handle);
 #ifdef DEBUG
-   r->log(r, GEOCACHE_LOG_DEBUG, "##### END #####\nrequested url %s",url);
+   r->log(r, GEOCACHE_DEBUG, "##### END #####\nrequested url %s",url);
 #endif
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:02:12 UTC (rev 12151)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:02:16 UTC (rev 12152)
@@ -245,14 +245,14 @@
       if(isLocked == GEOCACHE_TRUE) {
          /* another thread is rendering the tile, we should wait for it to finish */
 #ifdef DEBUG
-         r->log(r, GEOCACHE_LOGLEVEL_DEBUG, "cache wait: tileset %s - tile %d %d %d",
+         r->log(r, GEOCACHE_DEBUG, "cache wait: tileset %s - tile %d %d %d",
                tile->tileset->name,tile->x, tile->y,tile->z);
 #endif
          tile->tileset->cache->tile_lock_wait(tile,r);
       } else {
          /* no other thread is doing the rendering, do it ourselves */
 #ifdef DEBUG
-         r->log(r, GEOCACHE_LOGLEVEL_DEBUG, "cache miss: tileset %s - tile %d %d %d",
+         r->log(r, GEOCACHE_DEBUG, "cache miss: tileset %s - tile %d %d %d",
 #endif
          /* this will query the source to create the tiles, and save them to the cache */
