[mapserver-commits] r12155 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:02:34 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:02:34 -0700 (Fri, 26 Aug 2011)
New Revision: 12155
trunk/mapserver/mapcache/Makefile.inc.in
trunk/mapserver/mapcache/configure
trunk/mapserver/mapcache/configure.in
fix a compiler warning
thomas.bonfort | 2010-11-05 16:51:30 +0100 (Fri, 05 Nov 2010)
Modified: trunk/mapserver/mapcache/Makefile.inc.in
--- trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:02:30 UTC (rev 12154)
+++ trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:02:34 UTC (rev 12155)
@@ -5,7 +5,7 @@
CURLCONFIG=@CURLCONFIG@
XML2CONFIG=@XML2CONFIG@
-APXS_CFLAGS=@APXS_CFLAGS@ @APXS_INCLUDEDIR@
+APXS_CFLAGS=@APXS_INC@
APXS_LIBS=@APXS_LIBS@
APXS_LDFLAGS=@APXS_LDFLAGS@
@@ -27,7 +27,7 @@
FCGI_INC=@FASTCGI_INC@
FCGI_LIB=@FASTCGI_LIB@
-ALL_CFLAGS=-fPIC -I../include $(APXS_CFLAGS) $(APR_CFLAGS) $(CURL_CFLAGS) $(XML2_CFLAGS) $(PNG_INC) $(JPEG_INC)
+ALL_CFLAGS=$(CFLAGS) -fPIC -I../include $(APXS_CFLAGS) $(APR_CFLAGS) $(CURL_CFLAGS) $(XML2_CFLAGS) $(PNG_INC) $(JPEG_INC)
ALL_LIBS=$(CURL_LIBS) $(APR_LIBS) $(XML2_LIBS) $(PNG_LIB) $(JPEG_LIB)
Modified: trunk/mapserver/mapcache/configure
--- trunk/mapserver/mapcache/configure 2011-08-26 11:02:30 UTC (rev 12154)
+++ trunk/mapserver/mapcache/configure 2011-08-26 11:02:34 UTC (rev 12155)
@@ -1,6 +1,6 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.67 for mod_mapcache 0.1.
+# Generated by GNU Autoconf 2.67 for mod_geocache 0.1.
# Report bugs to <tbonfort at terriscope.fr>.
@@ -550,10 +550,10 @@
MAKEFLAGS=
# Identity of this package.
-PACKAGE_NAME='mod_mapcache'
-PACKAGE_TARNAME='mod_mapcache'
+PACKAGE_NAME='mod_geocache'
+PACKAGE_TARNAME='mod_geocache'
PACKAGE_VERSION='0.1'
-PACKAGE_STRING='mod_mapcache 0.1'
+PACKAGE_STRING='mod_geocache 0.1'
PACKAGE_BUGREPORT='tbonfort at terriscope.fr'
PACKAGE_URL=''
@@ -615,8 +615,7 @@
APRCONFIG
APXS_LDFLAGS
APXS_LIBS
-APXS_INCLUDEDIR
-APXS_CFLAGS
+APXS_INC
APACHECTL
APACHE_SBINDIR
APXS
@@ -1228,7 +1227,7 @@
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures mod_mapcache 0.1 to adapt to many kinds of systems.
+\`configure' configures mod_geocache 0.1 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1276,7 +1275,7 @@
--infodir=DIR info documentation [DATAROOTDIR/info]
--localedir=DIR locale-dependent data [DATAROOTDIR/locale]
--mandir=DIR man documentation [DATAROOTDIR/man]
- --docdir=DIR documentation root [DATAROOTDIR/doc/mod_mapcache]
+ --docdir=DIR documentation root [DATAROOTDIR/doc/mod_geocache]
--htmldir=DIR html documentation [DOCDIR]
--dvidir=DIR dvi documentation [DOCDIR]
--pdfdir=DIR pdf documentation [DOCDIR]
@@ -1289,7 +1288,7 @@
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of mod_mapcache 0.1:";;
+ short | recursive ) echo "Configuration of mod_geocache 0.1:";;
esac
cat <<\_ACEOF
@@ -1386,7 +1385,7 @@
test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
-mod_mapcache configure 0.1
+mod_geocache configure 0.1
generated by GNU Autoconf 2.67
Copyright (C) 2010 Free Software Foundation, Inc.
@@ -1688,7 +1687,7 @@
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by mod_mapcache $as_me 0.1, which was
+It was created by mod_geocache $as_me 0.1, which was
generated by GNU Autoconf 2.67. Invocation command line was
$ $0 $@
@@ -2038,7 +2037,7 @@
# don't let AC_PROG_CC force "-g -O2"
-: ${CFLAGS="-Wall"}
+#: ${CFLAGS="-Wall"}
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
@@ -2831,8 +2830,8 @@
ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CFLAGS=$CFLAGS
# macro that is used to parse a --with-xml2-config parameter
@@ -2872,7 +2871,7 @@
if test "$enable_debug" == "yes"; then
CFLAGS="$CFLAGS -g -O0 -DDEBUG"
else
- CFLAGS="-O2 -DNDEBUG"
+ CFLAGS="$CFLAGS -O2 -DNDEBUG"
fi
CFLAGS=$CFLAGS
@@ -3097,10 +3096,8 @@
$as_echo "$APACHECTL" >&6; }
fi
- APXS_CFLAGS=`$APXS -q CFLAGS`
+ APXS_INC=-I`$APXS -q INCLUDEDIR`
- APXS_INCLUDEDIR=-I`$APXS -q INCLUDEDIR`
APXS_LIBS=`$APXS -q LIBS`
APXS_LDFLAGS=`$APXS -q LDFLAGS`
@@ -4646,7 +4643,7 @@
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
-This file was extended by mod_mapcache $as_me 0.1, which was
+This file was extended by mod_geocache $as_me 0.1, which was
CONFIG_FILES = $CONFIG_FILES
@@ -4699,7 +4696,7 @@
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
-mod_mapcache config.status 0.1
+mod_geocache config.status 0.1
configured by $0, generated by GNU Autoconf 2.67,
with options \\"\$ac_cs_config\\"
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2011-08-26 11:02:30 UTC (rev 12154)
+++ trunk/mapserver/mapcache/configure.in 2011-08-26 11:02:34 UTC (rev 12155)
@@ -1,13 +1,13 @@
# Required initializer
-AC_INIT(mod_mapcache,0.1,tbonfort at terriscope.fr)
+AC_INIT(mod_geocache,0.1,tbonfort at terriscope.fr)
AC_PROG_CC
+CFLAGS=$CFLAGS
AC_DEFUN([XML2_CHECK],[
AC_SUBST(XML2CONFIG)
@@ -95,8 +95,7 @@
AC_MSG_RESULT([$APACHECTL])
fi
AC_SUBST(APACHECTL)
- AC_SUBST(APXS_CFLAGS,`$APXS -q CFLAGS`)
- AC_SUBST(APXS_INCLUDEDIR,-I`$APXS -q INCLUDEDIR`)
+ AC_SUBST(APXS_INC,-I`$APXS -q INCLUDEDIR`)
AC_SUBST(APXS_LIBS,`$APXS -q LIBS`)
AC_SUBST(APXS_LDFLAGS,`$APXS -q LDFLAGS`)
@@ -238,7 +237,7 @@
else
fi
AC_SUBST(CFLAGS,$CFLAGS)
More information about the mapserver-commits
