[mapserver-commits] r12172 - trunk/mapserver/mapcache/src
Fri Aug 26 07:04:11 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:04:11 -0700 (Fri, 26 Aug 2011)
New Revision: 12172
Removed:
   trunk/mapserver/mapcache/src/source_gdal.c
wrap around 0 when computing a list of tiles for a metabuffered request (not sure if a negative value for a tile x or y is valid, but at least we wont overwrite a wrong tile)
thomas.bonfort | 2010-12-09 18:47:08 +0100 (Thu, 09 Dec 2010)
Deleted: trunk/mapserver/mapcache/src/source_gdal.c
--- trunk/mapserver/mapcache/src/source_gdal.c	2011-08-26 11:04:06 UTC (rev 12171)
+++ trunk/mapserver/mapcache/src/source_gdal.c	2011-08-26 11:04:11 UTC (rev 12172)
@@ -1,102 +0,0 @@
-#include "geocache.h"
-#include <libxml/tree.h>
-#include <apr_tables.h>
-#include <apr_strings.h>
- * \private \memberof geocache_source_gdal
- * \sa geocache_source::render_tile()
-void _geocache_source_gdal_render_tile(geocache_context *ctx, geocache_tile *tile) {
-   geocache_source_gdal *gdal = (geocache_source_gdal*)tile->tileset->source;
-   apr_table_t *params = apr_table_clone(ctx->pool,gdal->gdal_default_params);
-   double bbox[4];
-   geocache_tileset_tile_bbox(tile,bbox);
-   apr_table_setn(params,"BBOX",apr_psprintf(ctx->pool,"%f,%f,%f,%f",bbox[0],bbox[1],bbox[2],bbox[3]));
-   apr_table_setn(params,"WIDTH",apr_psprintf(ctx->pool,"%d",tile->sx));
-   apr_table_setn(params,"HEIGHT",apr_psprintf(ctx->pool,"%d",tile->sy));
-   apr_table_setn(params,"FORMAT","image/png");
-   apr_table_setn(params,"SRS",tile->tileset->srs);
-   apr_table_overlap(params,gdal->gdal_params,0);
-   tile->data = geocache_buffer_create(1000,ctx->pool);
-   geocache_http_request_url_with_params(ctx,gdal->url,params,tile->data);
- * \sa geocache_source::render_metatile()
-void _geocache_source_gdal_render_metatile(geocache_context *ctx, geocache_metatile *tile) {
-   geocache_source_gdal *gdal = (geocache_source_gdal*)tile->tile.tileset->source;
-   tile->tile.data = geocache_buffer_create(30000,ctx->pool);
-   geocache_http_request_url_with_params(ctx,gdal->url,params,tile->tile.data);
-   GC_CHECK_ERROR(ctx);
-   if(!geocache_imageio_is_valid_format(ctx,tile->tile.data)) {
-      ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL, "gdal request failed for tileset %s: %d %d %d returned an unsupported format",
-            tile->tile.tileset->name, tile->tile.x, tile->tile.y, tile->tile.z);
- * \sa geocache_source::configuration_parse()
-void _geocache_source_gdal_configuration_parse(geocache_context *ctx, xmlNode *xml, geocache_source *source) {
-   xmlNode *cur_node;
-   geocache_source_gdal *src = (geocache_source_gdal*)source;
-   for(cur_node = xml->children; cur_node; cur_node = cur_node->next) {
-      if(cur_node->type != XML_ELEMENT_NODE) continue;
-      if(!xmlStrcmp(cur_node->name, BAD_CAST "data")) {
-         char* value = (char*)xmlNodeGetContent(cur_node);
-         src->data = value;
-      } else if(!xmlStrcmp(cur_node->name, BAD_CAST "options")) {
-         xmlNode *param_node;
-         for(param_node = cur_node->children; param_node; param_node = param_node->next) {
-            char *key,*value;
-            if(param_node->type != XML_ELEMENT_NODE) continue;
-            value = (char*)xmlNodeGetContent(param_node);
-            key = apr_pstrdup(ctx->pool, (char*)param_node->name);
-            apr_table_setn(src->gdal_params, key, value);
- * \sa geocache_source::configuration_check()
-void _geocache_source_gdal_configuration_check(geocache_context *ctx, geocache_source *source) {
-   /* check all required parameters are configured */
-   if(!strlen(src->data)) {
-      ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL, "gdal source %s has no data",source->name);
-   /* TODO: open source and check it accepts given options */
-geocache_source* geocache_source_gdal_create(geocache_context *ctx) {
-   geocache_source_gdal *source = apr_pcalloc(ctx->pool, sizeof(geocache_source_gdal));
-   if(!source) {
-      ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "failed to allocate gdal source");
-      return NULL;
-   geocache_source_init(ctx, &(source->source));
-   source->source.type = GEOCACHE_SOURCE_GDAL;
-   source->source.supports_metatiling = 1;
-   source->source.render_tile = _geocache_source_gdal_render_tile;
-   source->source.render_metatile = _geocache_source_gdal_render_metatile;
-   source->source.configuration_check = _geocache_source_gdal_configuration_check;
-   source->source.configuration_parse = _geocache_source_gdal_configuration_parse;
-   source->options = apr_table_make(ctx->pool,4);
-   return (geocache_source*)source;
