[mapserver-commits] r12174 - in trunk/mapserver/mapcache: include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:04:25 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:04:25 -0700 (Fri, 26 Aug 2011)
New Revision: 12174
trunk/mapserver/mapcache/include/errors.h
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/mod_geocache.c
trunk/mapserver/mapcache/src/services.c
trunk/mapserver/mapcache/src/source_wms.c
add comparative bench image
thomas.bonfort | 2010-12-10 15:03:10 +0100 (Fri, 10 Dec 2010)
Modified: trunk/mapserver/mapcache/include/errors.h
--- trunk/mapserver/mapcache/include/errors.h 2011-08-26 11:04:18 UTC (rev 12173)
+++ trunk/mapserver/mapcache/include/errors.h 2011-08-26 11:04:25 UTC (rev 12174)
@@ -37,4 +37,10 @@
GEOCACHE_ERROR
} geocache_log_level;
+typedef enum {
+ GEOCACHE_REPORT_LOG,
+ GEOCACHE_REPORT_MSG,
+ GEOCACHE_REPORT_IMG
+} geocache_error_reporting;
#endif /* ERRORS_H_ */
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:04:18 UTC (rev 12173)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:04:25 UTC (rev 12174)
@@ -134,6 +134,7 @@
apr_pool_t *pool;
char *_errmsg;
geocache_error_code _errcode;
+ geocache_cfg *config;
void geocache_context_init(geocache_context *ctx);
@@ -463,6 +464,11 @@
* directory where we store file locks
char *lockdir;
+ * how should error messages be reported to the user
+ geocache_error_reporting reporting;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:04:18 UTC (rev 12173)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:04:25 UTC (rev 12174)
@@ -41,6 +41,7 @@
"JPEG");
cfg->merge_format = geocache_configuration_get_image_format(cfg,"PNG");
cfg->lockdir = "/tmp/geocache_locks";
+ cfg->reporting = GEOCACHE_REPORT_MSG;
return cfg;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:04:18 UTC (rev 12173)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:04:25 UTC (rev 12174)
@@ -54,6 +54,23 @@
request_rec *request;
+int report_error(int code, geocache_context_apache_request *apache_ctx) {
+ geocache_context *ctx= (geocache_context*)apache_ctx;
+ ctx->log(ctx,GEOCACHE_INFO,ctx->get_error_message(ctx));
+ if(ctx->config && ctx->config->reporting == GEOCACHE_REPORT_MSG) {
+ apache_ctx->request->status = code;
+ ap_set_content_type(apache_ctx->request, "text/plain");
+ if(GC_HAS_ERROR(ctx)) {
+ ap_rprintf(apache_ctx->request,"error: %s",ctx->get_error_message(ctx));
+ } else {
+ ap_rprintf(apache_ctx->request,"unspecified error");
+ return OK;
+ } else {
+ return code;
void apache_context_server_log(geocache_context *c, geocache_log_level level, char *message, ...) {
geocache_context_apache_server *ctx = (geocache_context_apache_server*)c;
va_list args;
@@ -64,10 +81,12 @@
void apache_context_request_log(geocache_context *c, geocache_log_level level, char *message, ...) {
geocache_context_apache_request *ctx = (geocache_context_apache_request*)c;
+ c->global_lock_aquire(c,0);
va_list args;
va_start(args,message);
ap_log_rerror(APLOG_MARK, APLOG_INFO, 0, ctx->request,"%s",apr_pvsprintf(ctx->ctx.ctx.pool,message,args));
va_end(args);
+ c->global_lock_release(c);
void geocache_util_mutex_aquire(geocache_context *gctx, int nonblocking) {
@@ -89,8 +108,8 @@
ret = apr_global_mutex_unlock(cfg->mutex);
if(ret != APR_SUCCESS) {
gctx->set_error(gctx,GEOCACHE_MUTEX_ERROR,"failed to unlock mutex");
- return;
+ apr_pool_cleanup_kill(gctx->pool, cfg->mutex, (void*)apr_global_mutex_unlock);
void init_apache_request_context(geocache_context_apache_request *ctx) {
@@ -110,6 +129,7 @@
static geocache_context_apache_request* apache_request_context_create(request_rec *r) {
geocache_context_apache_request *ctx = apr_pcalloc(r->pool, sizeof(geocache_context_apache_request));
ctx->ctx.ctx.pool = r->pool;
+ ctx->ctx.ctx.config = ap_get_module_config(r->per_dir_config, &geocache_module);
ctx->request = r;
init_apache_request_context(ctx);
return ctx;
@@ -118,6 +138,7 @@
static geocache_context_apache_server* apache_server_context_create(server_rec *s, apr_pool_t *pool) {
geocache_context_apache_server *ctx = apr_pcalloc(pool, sizeof(geocache_context_apache_server));
ctx->ctx.ctx.pool = pool;
+ ctx->ctx.ctx.config = NULL;
ctx->server = s;
init_apache_server_context(ctx);
return ctx;
@@ -158,8 +179,8 @@
else if(t == GC_JPEG)
ap_set_content_type(r, "image/jpeg");
else {
- ap_log_rerror(APLOG_MARK, APLOG_ERR, 0, r, "unrecognized image format");
- return HTTP_INTERNAL_SERVER_ERROR;
+ ctx->ctx.ctx.set_error((geocache_context*)ctx, GEOCACHE_IMAGE_ERROR, "unrecognized image format");
+ return report_error(HTTP_INTERNAL_SERVER_ERROR, ctx);
ap_rwrite((void*)tile->data->buf, tile->data->size, r);
@@ -192,11 +213,11 @@
if(!service) continue;
request = service->parse_request(global_ctx,r->path_info,params,config);
/* the service has recognized the request if it returns a non NULL value */
- if(request)
+ if(request || GC_HAS_ERROR(global_ctx))
break;
- if(!request || !request->ntiles) {
- return HTTP_BAD_REQUEST;
+ if(!request || !request->ntiles || GC_HAS_ERROR(global_ctx)) {
+ return report_error(HTTP_BAD_REQUEST, apache_ctx);
@@ -204,8 +225,7 @@
geocache_tile *tile = request->tiles[i];
geocache_tileset_tile_get(global_ctx, tile);
if(GC_HAS_ERROR(global_ctx)) {
- global_ctx->log(global_ctx,GEOCACHE_INFO,global_ctx->get_error_message(global_ctx));
- return HTTP_NOT_FOUND;
+ return report_error(HTTP_INTERNAL_SERVER_ERROR, apache_ctx);
if(request->ntiles == 1) {
@@ -213,9 +233,8 @@
} else {
/* TODO: individual check on tiles if merging is allowed */
tile = (geocache_tile*)geocache_image_merge_tiles(global_ctx,config->merge_format,request->tiles,request->ntiles);
- if(!tile) {
- ap_log_rerror(APLOG_MARK, APLOG_ERR, 0, r, "tile merging failed to return data");
+ if(!tile || GC_HAS_ERROR(global_ctx)) {
tile->tileset = request->tiles[0]->tileset;
Modified: trunk/mapserver/mapcache/src/services.c
--- trunk/mapserver/mapcache/src/services.c 2011-08-26 11:04:18 UTC (rev 12173)
+++ trunk/mapserver/mapcache/src/services.c 2011-08-26 11:04:25 UTC (rev 12174)
@@ -30,11 +30,19 @@
char *str = NULL;
double *bbox;
geocache_request *request = NULL;
+ str = (char*)apr_table_get(params,"SERVICE");
+ if(!str)
+ str = (char*)apr_table_get(params,"service");
+ if(!str || strcasecmp(str,"wms")) {
+ return NULL;
str = (char*)apr_table_get(params,"REQUEST");
if(!str)
str = (char*)apr_table_get(params,"request");
if(!str || strcasecmp(str,"getmap")) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request that wasn't a getmap: %s", str);
return NULL;
Modified: trunk/mapserver/mapcache/src/source_wms.c
--- trunk/mapserver/mapcache/src/source_wms.c 2011-08-26 11:04:18 UTC (rev 12173)
+++ trunk/mapserver/mapcache/src/source_wms.c 2011-08-26 11:04:25 UTC (rev 12174)
@@ -61,8 +61,9 @@
GC_CHECK_ERROR(ctx);
if(!geocache_imageio_is_valid_format(ctx,tile->tile.data)) {
- ctx->set_error(ctx, GEOCACHE_SOURCE_WMS_ERROR, "wms request failed for tileset %s: %d %d %d returned an unsupported format",
- tile->tile.tileset->name, tile->tile.x, tile->tile.y, tile->tile.z);
+ char *returned_data = apr_pstrndup(ctx->pool,(char*)tile->tile.data->buf,tile->tile.data->size);
+ ctx->set_error(ctx, GEOCACHE_SOURCE_WMS_ERROR, "wms request for tileset %s: %d %d %d returned an unsupported format:\n%s",
+ tile->tile.tileset->name, tile->tile.x, tile->tile.y, tile->tile.z, returned_data);
More information about the mapserver-commits
