[mapserver-commits] r12180 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:04:54 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:04:53 -0700 (Fri, 26 Aug 2011)
New Revision: 12180
Added:
trunk/mapserver/mapcache/src/source_gdal.c
trunk/mapserver/mapcache/Makefile.inc.in
trunk/mapserver/mapcache/configure
trunk/mapserver/mapcache/configure.in
trunk/mapserver/mapcache/include/errors.h
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/Makefile
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/source_wms.c
add lock around blank tile creation
fixes #19
thomas.bonfort | 2010-12-17 11:03:52 +0100 (Fri, 17 Dec 2010)
Modified: trunk/mapserver/mapcache/Makefile.inc.in
--- trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:04:53 UTC (rev 12180)
@@ -28,11 +28,16 @@
FCGI_INC=@FASTCGI_INC@
FCGI_LIB=@FASTCGI_LIB@
-GC_CFLAGS=$(CFLAGS) -I../include $(CURL_CFLAGS) $(XML2_CFLAGS) $(PNG_INC) $(JPEG_INC)
-GC_LIBS=$(CURL_LIBS) $(XML2_LIBS) $(PNG_LIB) $(JPEG_LIB)
+GDAL_INC=@GDAL_INC@
+GDAL_LIB=@GDAL_LIB@
+GDAL_ENABLED=@GDAL_ENABLED@
+GC_CFLAGS=$(CFLAGS) -I../include $(CURL_CFLAGS) $(XML2_CFLAGS) $(PNG_INC) $(JPEG_INC) $(GDAL_INC) $(GDAL_ENABLED)
+GC_LIBS=$(CURL_LIBS) $(XML2_LIBS) $(PNG_LIB) $(JPEG_LIB) $(GDAL_LIB)
OBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v geocache_seed.c | grep -v mod_geocache.c | grep -v fastcgi_geocache.c |sed "s/^\(.*\)\.c$$/\1.o/")
LOBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v geocache_seed.c | grep -v mod_geocache.c | grep -v fastcgi_geocache.c | sed "s/^\(.*\)\.c$$/\1.lo/")
APXS_WCFLAGS=$(shell for flag in $(GC_CFLAGS); do echo "-Wc,$$flag "; done)
+APXS_WLDFLAGS=$(shell for flag in $(GC_LIBS); do echo "-Wl,$$flag "; done)
Modified: trunk/mapserver/mapcache/configure
--- trunk/mapserver/mapcache/configure 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/configure 2011-08-26 11:04:53 UTC (rev 12180)
@@ -750,6 +750,10 @@
XML2_LIBS
XML2_CFLAGS
XML2CONFIG
+GDAL_LIB
+GDAL_INC
+GDAL_ENABLED
+GDAL_CONFIG
JPEG_LIB
JPEG_INC
PNG_LIB
@@ -857,6 +861,7 @@
with_apr_config
with_png
with_jpeg
+with_gdal
with_xml2_config
with_curl_config
@@ -1504,6 +1509,7 @@
--with-apr-config path to apr-config program
--with-png=DIR Specify where PNG is installed
--with-jpeg=DIR Specify where JPEG is installed
+ --with-gdal[=PATH] Include GDAL support (PATH is path to gdal-config)
--with-xml2-config=/path/to/xml2-config xml2-config tool location
--with-curl-config path to curl-config program
@@ -3804,13 +3810,13 @@
else
lt_cv_nm_interface="BSD nm"
echo "int some_variable = 0;" > conftest.$ac_ext
- (eval echo "\"\$as_me:3807: $ac_compile\"" >&5)
+ (eval echo "\"\$as_me:3813: $ac_compile\"" >&5)
(eval "$ac_compile" 2>conftest.err)
cat conftest.err >&5
- (eval echo "\"\$as_me:3810: $NM \\\"conftest.$ac_objext\\\"\"" >&5)
+ (eval echo "\"\$as_me:3816: $NM \\\"conftest.$ac_objext\\\"\"" >&5)
(eval "$NM \"conftest.$ac_objext\"" 2>conftest.err > conftest.out)
- (eval echo "\"\$as_me:3813: output\"" >&5)
+ (eval echo "\"\$as_me:3819: output\"" >&5)
cat conftest.out >&5
if $GREP 'External.*some_variable' conftest.out > /dev/null; then
lt_cv_nm_interface="MS dumpbin"
@@ -5016,7 +5022,7 @@
*-*-irix6*)
# Find out which ABI we are using.
- echo '#line 5019 "configure"' > conftest.$ac_ext
+ echo '#line 5025 "configure"' > conftest.$ac_ext
if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
(eval $ac_compile) 2>&5
ac_status=$?
@@ -6545,11 +6551,11 @@
-e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
-e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
-e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:6548: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:6554: $lt_compile\"" >&5)
(eval "$lt_compile" 2>conftest.err)
ac_status=$?
- echo "$as_me:6552: \$? = $ac_status" >&5
+ echo "$as_me:6558: \$? = $ac_status" >&5
if (exit $ac_status) && test -s "$ac_outfile"; then
# The compiler can only warn and ignore the option if not recognized
# So say no if there are warnings other than the usual output.
@@ -6884,11 +6890,11 @@
- (eval echo "\"\$as_me:6887: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:6893: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:6891: \$? = $ac_status" >&5
+ echo "$as_me:6897: \$? = $ac_status" >&5
@@ -6989,11 +6995,11 @@
- (eval echo "\"\$as_me:6992: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:6998: $lt_compile\"" >&5)
(eval "$lt_compile" 2>out/conftest.err)
ac_status=$?
cat out/conftest.err >&5
- echo "$as_me:6996: \$? = $ac_status" >&5
+ echo "$as_me:7002: \$? = $ac_status" >&5
if (exit $ac_status) && test -s out/conftest2.$ac_objext
then
@@ -7044,11 +7050,11 @@
- (eval echo "\"\$as_me:7047: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:7053: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:7051: \$? = $ac_status" >&5
+ echo "$as_me:7057: \$? = $ac_status" >&5
then
@@ -9428,7 +9434,7 @@
lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
lt_status=$lt_dlunknown
cat > conftest.$ac_ext <<_LT_EOF
-#line 9431 "configure"
+#line 9437 "configure"
#include "confdefs.h"
#if HAVE_DLFCN_H
@@ -9524,7 +9530,7 @@
-#line 9527 "configure"
+#line 9533 "configure"
#if HAVE_DLFCN_H
@@ -10323,6 +10329,8 @@
# Check whether --enable-debug was given.
if test "${enable_debug+set}" = set; then :
enableval=$enable_debug;
@@ -11042,6 +11050,113 @@
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if GDAL support requested" >&5
+$as_echo_n "checking if GDAL support requested... " >&6; }
+# Check whether --with-gdal was given.
+if test "${with_gdal+set}" = set; then :
+ withval=$with_gdal;
+fi
+if test "$with_gdal" = "yes" ; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
+ if test "`basename xx/$with_gdal`" = "gdal-config" ; then
+ GDAL_CONFIG="$with_gdal"
+ fi
+ if test -z "$GDAL_CONFIG" ; then
+ # Extract the first word of "gdal-config", so it can be a program name with args.
+set dummy gdal-config; ac_word=$2
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+$as_echo_n "checking for $ac_word... " >&6; }
+if test "${ac_cv_path_GDAL_CONFIG+set}" = set; then :
+ $as_echo_n "(cached) " >&6
+else
+ case $GDAL_CONFIG in
+ ac_cv_path_GDAL_CONFIG="$GDAL_CONFIG" # Let the user override the test with a path.
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+ IFS=$as_save_IFS
+ test -z "$as_dir" && as_dir=.
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+ ac_cv_path_GDAL_CONFIG="$as_dir/$ac_word$ac_exec_ext"
+ $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
+ break 2
+ fi
+done
+ done
+IFS=$as_save_IFS
+ test -z "$ac_cv_path_GDAL_CONFIG" && ac_cv_path_GDAL_CONFIG="no"
+esac
+fi
+GDAL_CONFIG=$ac_cv_path_GDAL_CONFIG
+if test -n "$GDAL_CONFIG"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $GDAL_CONFIG" >&5
+$as_echo "$GDAL_CONFIG" >&6; }
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
+fi
+ fi
+ if test "$GDAL_CONFIG" = "no" ; then
+ as_fn_error $? "couldn't find gdal-config" "$LINENO" 5
+ fi
+ GDAL_ENABLED=-DUSE_GDAL
+elif test -n "$with_gdal" -a "$with_gdal" != "no" ; then
+ GDAL_CONFIG=$with_gdal
+ if test -f "$GDAL_CONFIG" -a -x "$GDAL_CONFIG" ; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes, user supplied gdal-config ($GDAL_CONFIG)" >&5
+$as_echo "yes, user supplied gdal-config ($GDAL_CONFIG)" >&6; }
+ else
+ as_fn_error $? "'$GDAL_CONFIG' is not an executable. Make sure you use --with-gdal=/path/to/gdal-config" "$LINENO" 5
+ fi
+else
+fi
+if test -n "$GDAL_ENABLED" -o "$OGR_ENABLED"; then
+ GDAL_LIB=`$GDAL_CONFIG --libs`' '`$GDAL_CONFIG --dep-libs`
+ GDAL_INC=`$GDAL_CONFIG --cflags`
+fi
+GDAL_ENABLED=$GDAL_ENABLED
+GDAL_INC=$GDAL_INC
+GDAL_LIB=$GDAL_LIB
#PKGCONFIG_CHECK
#CAIRO_CHECK
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/configure.in 2011-08-26 11:04:53 UTC (rev 12180)
@@ -422,6 +422,67 @@
AC_SUBST(JPEG_LIB,$JPEG_LIB)
+AC_DEFUN(GDAL_CHECK,[
+AC_MSG_CHECKING(if GDAL support requested)
+AC_ARG_WITH(gdal,
+[ --with-gdal[[=PATH]] Include GDAL support (PATH is path to gdal-config)],,)
+ AC_MSG_RESULT([yes])
+ fi
+ AC_PATH_PROG(GDAL_CONFIG, gdal-config, no)
+ fi
+ AC_MSG_ERROR([couldn't find gdal-config])
+ fi
+ AC_MSG_RESULT([yes, user supplied gdal-config ($GDAL_CONFIG)])
+ else
+ AC_MSG_ERROR(['$GDAL_CONFIG' is not an executable. Make sure you use --with-gdal=/path/to/gdal-config])
+ fi
+else
+ AC_MSG_RESULT([no])
+fi
+dnl
+dnl GDAL_LIB and GDAL_INC are used for both GDAL and OGR
+dnl
+fi
+AC_SUBST(GDAL_ENABLED,$GDAL_ENABLED)
+AC_SUBST(GDAL_INC, $GDAL_INC)
+AC_SUBST(GDAL_LIB, $GDAL_LIB)
DEBUG_CHECK
AC_ARG_ENABLE(module,
@@ -463,7 +524,7 @@
PNG_CHECK
JPEG_CHECK
+GDAL_CHECK
#PKGCONFIG_CHECK
#CAIRO_CHECK
Modified: trunk/mapserver/mapcache/include/errors.h
--- trunk/mapserver/mapcache/include/errors.h 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/include/errors.h 2011-08-26 11:04:53 UTC (rev 12180)
@@ -25,6 +25,7 @@
GEOCACHE_HTTP_ERROR,
GEOCACHE_IMAGE_ERROR,
GEOCACHE_SOURCE_WMS_ERROR,
+GEOCACHE_SOURCE_GDAL_ERROR,
GEOCACHE_TILESET_ERROR,
GEOCACHE_MUTEX_ERROR,
GEOCACHE_REQUEST_ERROR
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:04:53 UTC (rev 12180)
@@ -28,6 +28,10 @@
#include <libxml/tree.h>
#include "util.h"
#include "errors.h"
+#ifdef USE_GDAL
+#include <gdal.h>
+#include <cpl_conv.h>
+#endif
#include <assert.h>
#include <apr_time.h>
@@ -56,6 +60,7 @@
typedef struct geocache_tile geocache_tile;
typedef struct geocache_metatile geocache_metatile;
typedef struct geocache_source_wms geocache_source_wms;
+typedef struct geocache_source_gdal geocache_source_gdal;
typedef struct geocache_cache_disk geocache_cache_disk;
typedef struct geocache_request geocache_request;
typedef struct geocache_service geocache_service;
@@ -182,7 +187,8 @@
typedef enum {
- GEOCACHE_SOURCE_WMS
+ GEOCACHE_SOURCE_WMS,
+ GEOCACHE_SOURCE_GDAL
} geocache_source_type;
/**\interface geocache_source
@@ -195,13 +201,6 @@
geocache_source_type type;
int supports_metatiling;
- * \brief get the data for the tile
- * sets the geocache_tile::data for the given tile
- * \deprecated
- void (*render_tile)(geocache_context *ctx, geocache_tile * tile);
* \brief get the data for the metatile
* sets the geocache_metatile::tile::data for the given tile
@@ -222,6 +221,18 @@
apr_table_t *wms_params; /**< WMS parameters specified in configuration */
+#ifdef USE_GDAL
+/**\class geocache_source_gdal
+ * \brief GDAL geocache_source
+ * \implements geocache_source
+struct geocache_source_gdal {
+ geocache_source source;
+ char *datastr; /**< the gdal source string*/
+ apr_table_t *gdal_params; /**< GDAL parameters specified in configuration */
+ GDALDatasetH *poDataset;
+#endif
@@ -496,6 +507,11 @@
void geocache_source_init(geocache_context *ctx, geocache_source *source);
+ * \memberof geocache_source_gdal
+geocache_source* geocache_source_gdal_create(geocache_context *ctx);
* \memberof geocache_source_wms
geocache_source* geocache_source_wms_create(geocache_context *ctx);
Modified: trunk/mapserver/mapcache/src/Makefile
--- trunk/mapserver/mapcache/src/Makefile 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/src/Makefile 2011-08-26 11:04:53 UTC (rev 12180)
@@ -18,7 +18,7 @@
mod_geocache.la: mod_geocache.o
mod_geocache.o: mod_geocache.c $(OBJS)
- $(APXS) $(APXS_WCFLAGS) $(GC_LIBS) -c mod_geocache.c $(LOBJS)
+ $(APXS) $(APXS_WCFLAGS) $(APXS_WLDFLAGS) -c mod_geocache.c $(LOBJS)
geocache.fcgi: fastcgi_geocache.c $(OBJS)
$(LIBTOOL) --mode=link $(CC) -o geocache.fcgi $(GC_CFLAGS) $(APR_CFLAGS) $(FCGI_INC) fastcgi_geocache.c $(LOBJS) $(GC_LIBS) $(APR_LIBS) $(FCGI_LIB)
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:04:53 UTC (rev 12180)
@@ -125,6 +125,8 @@
geocache_source *source = NULL;
if(!strcmp(type,"wms")) {
source = geocache_source_wms_create(ctx);
+ } else if(!strcmp(type,"gdal")) {
+ source = geocache_source_gdal_create(ctx);
} else {
ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "unknown source type %s for source \"%s\"", type, name);
return;
Added: trunk/mapserver/mapcache/src/source_gdal.c
--- trunk/mapserver/mapcache/src/source_gdal.c (rev 0)
+++ trunk/mapserver/mapcache/src/source_gdal.c 2011-08-26 11:04:53 UTC (rev 12180)
@@ -0,0 +1,108 @@
+ * Copyright 2010 Thomas Bonfort
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#include "geocache.h"
+#include <libxml/tree.h>
+#include <apr_tables.h>
+#include <apr_strings.h>
+#ifdef USE_GDAL
+ * \private \memberof geocache_source_gdal
+ * \sa geocache_source::render_metatile()
+void _geocache_source_gdal_render_metatile(geocache_context *ctx, geocache_metatile *tile) {
+ geocache_source_gdal *gdal = (geocache_source_gdal*)tile->tile.tileset->source;
+ tile->tile.data = geocache_buffer_create(30000,ctx->pool);
+ GC_CHECK_ERROR(ctx);
+ if(!geocache_imageio_is_valid_format(ctx,tile->tile.data)) {
+ char *returned_data = apr_pstrndup(ctx->pool,(char*)tile->tile.data->buf,tile->tile.data->size);
+ ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL_ERROR, "gdal request for tileset %s: %d %d %d returned an unsupported format:\n%s",
+ tile->tile.tileset->name, tile->tile.x, tile->tile.y, tile->tile.z, returned_data);
+ * \sa geocache_source::configuration_parse()
+void _geocache_source_gdal_configuration_parse(geocache_context *ctx, xmlNode *xml, geocache_source *source) {
+ xmlNode *cur_node;
+ geocache_source_gdal *src = (geocache_source_gdal*)source;
+ for(cur_node = xml->children; cur_node; cur_node = cur_node->next) {
+ if(cur_node->type != XML_ELEMENT_NODE) continue;
+ if(!xmlStrcmp(cur_node->name, BAD_CAST "data")) {
+ char* value = (char*)xmlNodeGetContent(cur_node);
+ src->datastr = value;
+ } else if(!xmlStrcmp(cur_node->name, BAD_CAST "gdalparams")) {
+ xmlNode *param_node;
+ for(param_node = cur_node->children; param_node; param_node = param_node->next) {
+ char *key,*value;
+ if(param_node->type != XML_ELEMENT_NODE) continue;
+ value = (char*)xmlNodeGetContent(param_node);
+ key = apr_pstrdup(ctx->pool, (char*)param_node->name);
+ apr_table_setn(src->gdal_params, key, value);
+ * \sa geocache_source::configuration_check()
+void _geocache_source_gdal_configuration_check(geocache_context *ctx, geocache_source *source) {
+ /* check all required parameters are configured */
+ if(!strlen(src->datastr)) {
+ ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL_ERROR, "gdal source %s has no data",source->name);
+ return;
+ src->poDataset = (GDALDatasetH*)GDALOpen(src->datastr,GA_ReadOnly);
+ if( src->poDataset == NULL ) {
+ ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL_ERROR, "gdalOpen failed on data %s", src->datastr);
+ return;
+#endif //USE_GDAL
+geocache_source* geocache_source_gdal_create(geocache_context *ctx) {
+#ifdef USE_GDAL
+ GDALAllRegister();
+ geocache_source_gdal *source = apr_pcalloc(ctx->pool, sizeof(geocache_source_gdal));
+ if(!source) {
+ ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "failed to allocate gdal source");
+ return NULL;
+ geocache_source_init(ctx, &(source->source));
+ source->source.type = GEOCACHE_SOURCE_GDAL;
+ source->source.supports_metatiling = 1;
+ source->source.render_metatile = _geocache_source_gdal_render_metatile;
+ source->source.configuration_check = _geocache_source_gdal_configuration_check;
+ source->source.configuration_parse = _geocache_source_gdal_configuration_parse;
+ source->gdal_params = apr_table_make(ctx->pool,4);
+ return (geocache_source*)source;
+#else
+ ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL_ERROR, "failed to create gdal source, GDAL support is not compiled in this version");
+ return NULL;
+#endif
Modified: trunk/mapserver/mapcache/src/source_wms.c
--- trunk/mapserver/mapcache/src/source_wms.c 2011-08-26 11:04:45 UTC (rev 12179)
+++ trunk/mapserver/mapcache/src/source_wms.c 2011-08-26 11:04:53 UTC (rev 12180)
@@ -21,27 +21,6 @@
* \private \memberof geocache_source_wms
- * \sa geocache_source::render_tile()
-void _geocache_source_wms_render_tile(geocache_context *ctx, geocache_tile *tile) {
- geocache_source_wms *wms = (geocache_source_wms*)tile->tileset->source;
- apr_table_t *params = apr_table_clone(ctx->pool,wms->wms_default_params);
- double bbox[4];
- geocache_tileset_tile_bbox(tile,bbox);
- apr_table_setn(params,"BBOX",apr_psprintf(ctx->pool,"%f,%f,%f,%f",bbox[0],bbox[1],bbox[2],bbox[3]));
- apr_table_setn(params,"WIDTH",apr_psprintf(ctx->pool,"%d",tile->sx));
- apr_table_setn(params,"HEIGHT",apr_psprintf(ctx->pool,"%d",tile->sy));
- apr_table_setn(params,"FORMAT","image/png");
- apr_table_setn(params,"SRS",tile->tileset->srs);
- apr_table_overlap(params,wms->wms_params,0);
- tile->data = geocache_buffer_create(1000,ctx->pool);
- geocache_http_request_url_with_params(ctx,wms->url,params,tile->data);
- * \private \memberof geocache_source_wms
void _geocache_source_wms_render_metatile(geocache_context *ctx, geocache_metatile *tile) {
@@ -116,7 +95,6 @@
source->source.type = GEOCACHE_SOURCE_WMS;
- source->source.render_tile = _geocache_source_wms_render_tile;
source->source.render_metatile = _geocache_source_wms_render_metatile;
source->source.configuration_check = _geocache_source_wms_configuration_check;
source->source.configuration_parse = _geocache_source_wms_configuration_parse;
More information about the mapserver-commits
