[mapserver-commits] r12201 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:06:40 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:06:40 -0700 (Fri, 26 Aug 2011)
New Revision: 12201
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/fastcgi_geocache.c
   trunk/mapserver/mapcache/src/mod_geocache.c
   trunk/mapserver/mapcache/src/services.c
stop using epsg:900913 for google grid, use the official 3857
use grid resolutions from wmts spec for preconfigured grids
thomas.bonfort | 2011-01-05 18:56:53 +0100 (Wed, 05 Jan 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:06:34 UTC (rev 12200)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:06:40 UTC (rev 12201)
@@ -332,7 +332,7 @@
      * \returns a geocache_request corresponding to the parameters received
      * \returns NULL if the request does not correspond the the service
-    geocache_request * (*parse_request)(geocache_context *ctx, char *path_info, apr_table_t *params, geocache_cfg * config);
+    geocache_request * (*parse_request)(geocache_context *ctx, char *uri, char *path_info, apr_table_t *params, geocache_cfg * config);
 /**\class geocache_service_wms
Modified: trunk/mapserver/mapcache/src/fastcgi_geocache.c
--- trunk/mapserver/mapcache/src/fastcgi_geocache.c	2011-08-26 11:06:34 UTC (rev 12200)
+++ trunk/mapserver/mapcache/src/fastcgi_geocache.c	2011-08-26 11:06:40 UTC (rev 12201)
@@ -151,6 +151,13 @@
    return 200;
+static int geocache_write_capabilities(geocache_context_fcgi_request *ctx, geocache_request *request) {
+   FCGX_FPrintF(ctx->out,"Content-type: text/xml\r\n\r\n");
+   FCGX_PutStr(request->capabilities, strlen(request->capabilities),ctx->out);
+   return 200;
 int main(int argc, char **argv) {
    apr_pool_initialize();
@@ -179,7 +186,27 @@
       geocache_context *ctx = (geocache_context*) fcgi_context_request_create(globalctx,out,err);
       geocache_tile *tile;
       geocache_request *request = NULL;
+      char *host = FCGX_GetParam("SERVER_NAME",envp);
+      char *port = FCGX_GetParam("SERVER_PORT",envp);
+      char *fullhost;
+      if(FCGX_GetParam("HTTPS",envp)) {
+         if(!port || !strcmp(port,"443")) {
+            fullhost = apr_psprintf(ctx->pool,"https://%s",host);
+         } else {
+            fullhost = apr_psprintf(ctx->pool,"https://%s:%s",host,port);
+      } else {
+         if(!port || !strcmp(port,"80")) {
+            fullhost = apr_psprintf(ctx->pool,"http://%s",host);
+         } else {
+            fullhost = apr_psprintf(ctx->pool,"http://%s:%s",host,port);
       char *pathInfo = FCGX_GetParam("PATH_INFO",envp);
+      char *uri = apr_psprintf(ctx->pool,"%s%s",
+            fullhost,
+            FCGX_GetParam("SCRIPT_NAME",envp)
       int i;
@@ -189,41 +216,48 @@
       for(i=0;i<GEOCACHE_SERVICES_COUNT;i++) {
          geocache_service *service = cfg->services[i];
          if(!service) continue;
-         request = service->parse_request(ctx,pathInfo,params,cfg);
+         request = service->parse_request(ctx,uri,pathInfo,params,cfg);
          if(request)
             break;
-      if(!request || !request->ntiles) {
+      if(!request || GC_HAS_ERROR(ctx)) {
          FCGX_FPrintF(out,"Status: 404 Not Found\r\n\r\n");
          goto cleanup;
-      for(i=0;i<request->ntiles;i++) {
-         geocache_tile *tile = request->tiles[i];
-         geocache_tileset_tile_get(ctx,tile);
-         if(GC_HAS_ERROR(ctx)) {
-            ctx->log(ctx,GEOCACHE_DEBUG,ctx->get_error_message(ctx));
-            FCGX_FPrintF(out,"Status: 500 Internal Server Error\r\n\r\n");
+      if(request->type == GEOCACHE_REQUEST_GET_CAPABILITIES) {
+         geocache_write_capabilities((geocache_context_fcgi_request*)ctx,request);
+      } else {
+         if(!request->ntiles) {
+            FCGX_FPrintF(out,"Status: 404 Not Found\r\n\r\n");
             goto cleanup;
-      if(request->ntiles == 1) {
-         tile = request->tiles[0];
-      } else {
-         tile = geocache_image_merge_tiles(ctx,cfg->merge_format,request->tiles,request->ntiles);
-         if(!tile) {
-            ctx->log(ctx,GEOCACHE_ERROR, "tile merging failed to return data");
-            if(ctx->get_error(ctx)) {
-               ctx->log(ctx,GEOCACHE_ERROR,c->get_error_message(ctx));
+         for(i=0;i<request->ntiles;i++) {
+            geocache_tile *tile = request->tiles[i];
+            geocache_tileset_tile_get(ctx,tile);
+            if(GC_HAS_ERROR(ctx)) {
+               ctx->log(ctx,GEOCACHE_DEBUG,ctx->get_error_message(ctx));
                goto cleanup;
-            goto cleanup;
-         tile->tileset = request->tiles[0]->tileset;
+         if(request->ntiles == 1) {
+            tile = request->tiles[0];
+         } else {
+            tile = geocache_image_merge_tiles(ctx,cfg->merge_format,request->tiles,request->ntiles);
+            if(!tile) {
+               ctx->log(ctx,GEOCACHE_ERROR, "tile merging failed to return data");
+               if(ctx->get_error(ctx)) {
+                  ctx->log(ctx,GEOCACHE_ERROR,c->get_error_message(ctx));
+                  FCGX_FPrintF(out,"Status: 500 Internal Server Error\r\n\r\n");
+                  goto cleanup;
+               goto cleanup;
+            tile->tileset = request->tiles[0]->tileset;
+         geocache_write_tile((geocache_context_fcgi_request*)ctx,tile);
-      geocache_write_tile((geocache_context_fcgi_request*)ctx,tile);
 cleanup:
       apr_pool_destroy(ctx->pool);
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:06:34 UTC (rev 12200)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:06:40 UTC (rev 12201)
@@ -18,6 +18,7 @@
  * Include the core server components.
 #include <httpd.h>
+#include <http_core.h>
 #include <http_config.h>
 #include <http_protocol.h>
 #include <http_request.h>
@@ -205,7 +206,9 @@
    geocache_context_apache_request *apache_ctx = apache_request_context_create(r);
    geocache_context *global_ctx = (geocache_context*)apache_ctx;
+   request_rec *original;
    int i,ret;
+   char *uri;
    if (!r->handler || strcmp(r->handler, "geocache")) {
       return DECLINED;
@@ -216,12 +219,16 @@
    params = geocache_http_parse_param_string(global_ctx, r->args);
    config = ap_get_module_config(r->per_dir_config, &geocache_module);
+   if(r->main)
+      original = r->main;
+   else
+      original = r;
+   uri = ap_construct_url(r->pool,original->parsed_uri.path,original);
       /* loop through the services that have been configured */
       geocache_service *service = config->services[i];
-      request = service->parse_request(global_ctx,r->path_info,params,config);
+      request = service->parse_request(global_ctx,uri,original->path_info,params,config);
       /* the service has recognized the request if it returns a non NULL value */
       if(request || GC_HAS_ERROR(global_ctx))
          break;
Modified: trunk/mapserver/mapcache/src/services.c
--- trunk/mapserver/mapcache/src/services.c	2011-08-26 11:06:34 UTC (rev 12200)
+++ trunk/mapserver/mapcache/src/services.c	2011-08-26 11:06:40 UTC (rev 12201)
@@ -80,10 +80,10 @@
               "<BoundingBox srs=\"%s\" minx=\"%f\" miny=\"%f\" maxx=\"%f\" maxy=\"%f\" />\n"
             "</Layer>\n";
-geocache_request* _geocache_service_wms_capabilities(geocache_context *ctx, geocache_cfg *cfg) {
+geocache_request* _geocache_service_wms_capabilities(geocache_context *ctx, char *uri, geocache_cfg *cfg) {
    geocache_request *request = (geocache_request*)apr_pcalloc(ctx->pool,sizeof(geocache_request));
    request->type = GEOCACHE_REQUEST_GET_CAPABILITIES;
-   char *host = "http://foo?";
+   char *host = uri;
    char *caps = apr_psprintf(ctx->pool,wms_capabilities_preamble,host,host,host);
    apr_hash_index_t *tileindex_index = apr_hash_first(ctx->pool,cfg->tilesets);
@@ -145,7 +145,7 @@
  * \private \memberof geocache_service_wms
  * \sa geocache_service::parse_request()
-geocache_request* _geocache_service_wms_parse_request(geocache_context *ctx, char *pathinfo, apr_table_t *params, geocache_cfg *config) {
+geocache_request* _geocache_service_wms_parse_request(geocache_context *ctx, char *uri, char *pathinfo, apr_table_t *params, geocache_cfg *config) {
    char *str = NULL, *srs=NULL;
    int width=0, height=0;
    double *bbox;
@@ -166,7 +166,7 @@
       return NULL;
    if( ! strcasecmp(str,"getcapabilities") ) {
-      return _geocache_service_wms_capabilities(ctx, config);
+      return _geocache_service_wms_capabilities(ctx, uri, config);
    } else if( strcasecmp(str,"getmap")) {
       ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms with invalid request %s",str);
       return NULL;
@@ -290,7 +290,7 @@
  * \private \memberof geocache_service_tms
-geocache_request* _geocache_service_tms_parse_request(geocache_context *ctx, char *pathinfo, apr_table_t *params, geocache_cfg *config) {
+geocache_request* _geocache_service_tms_parse_request(geocache_context *ctx, char *uri, char *pathinfo, apr_table_t *params, geocache_cfg *config) {
    int index = 0;
    char *last, *key, *endptr;
    geocache_tileset *tileset = NULL;
