[mapserver-commits] r12220 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:08:22 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:08:21 -0700 (Fri, 26 Aug 2011)
New Revision: 12220
trunk/mapserver/mapcache/geocache.xml
add a few comments
thomas.bonfort | 2011-01-08 14:42:26 +0100 (Sat, 08 Jan 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:08:18 UTC (rev 12219)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:08:21 UTC (rev 12220)
@@ -3,114 +3,414 @@
<metadata>
<title>my geocache service</title>
<abstract>woot! this is a service abstract!</abstract>
- <!-- uncomment this if you need to provide another base url for
+ uncomment and modify this if you need to provide another base url for
getCapabilities requests (for the OnlineResource tags)
<url>http://mysuperhost/proxy/to/geocache</url>
</metadata>
+ a grid represents the layout of tiles: srs, extent, resolutions, and tile size
<grid name="testgrid">
<metadata>
<title>this is a custom grid I made up for an example</title>
+ OGC WMTS WellKnownScaleSet, if applicable
+ <WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
</metadata>
+ the spatial reference this tileset is in. a WMS client will need this for
+ getMap requests.
+ note that when configuring a tileset, its <grid> and <source> srs should match. If
+ they do not match you will be warned, but this is not an error, as there are cases
+ when this is needed (for example epsg:900913 and epsg:3857 are equivalent).
<srs>epsg:4326</srs>
+ width and height of tiles. 256x256 is the usual size
<size>256 256</size>
+ extent of the grid. the bottom left corner determines the origin of the tiles
+ this should match the maxExtent property if using openlayers.
<extent>-180 -90 180 90</extent>
+ array of resolutions for the tileset, in decreasing order
+ this should match the resolutions property if using openlayers
<resolutions>0.1 0.05 0.025 0.0125</resolutions>
</grid>
- <cache name="disk" type="disk">
- <base>/tmp</base>
- <symlink_blank/>
- </cache>
- <format name="PNGQ_FAST" type ="PNG">
- <compression>fast</compression>
- <colors>256</colors>
- </format>
- <format name="PNG_BEST" type ="PNG">
- <compression>best</compression>
- </format>
- <source name="vmap0" type="wms">
- <url>http://vmap0.tiles.osgeo.org/wms/vmap0</url>
- <srs>epsg:4326</srs>
- <wmsparams>
- <FORMAT>image/png</FORMAT>
- <LAYERS>basic</LAYERS>
- </wmsparams>
- </source>
- <source name="osm" type="wms">
- <url>http://localhost/cgi-bin/mapserv?</url>
- <srs>epsg:900913</srs>
- <wmsparams>
- <LAYERS>default</LAYERS>
- <MAP>/Users/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
- </wmsparams>
- </source>
- <source name="nexrad" type="wms">
- <url>http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi</url>
- <wmsparams>
- <LAYERS>nexrad_base_reflect</LAYERS>
- <TRANSPARENT>true</TRANSPARENT>
- </wmsparams>
- </source>
- <source name="basic" type="wms">
- <url>http://geoservices.brgm.fr/geologie?</url>
- <wmsparams>
- <LAYERS>GRAVI_BASE</LAYERS>
- </wmsparams>
- </source>
- <tileset name="test">
- <source>vmap0</source>
- <cache>disk</cache>
- <watermark>/Users/tbonfort/Documents/terriscope/logo-watermark.png</watermark>
- <grid>WGS84</grid>
- <expires>3600</expires>
- </tileset>
- <tileset name="test2">
- <source>nexrad</source>
- <format>PNG</format>
- </tileset>
- <tileset name="test3">
- <source>basic</source>
- <format>PNG8</format>
- <metatile>5 5</metatile>
- <metabuffer>30</metabuffer>
- </tileset>
- <tileset name="osm">
- <metadata>
- <title>osm mapserver served map of midi-pyrénées</title>
- <abstract>see http://mapserver-utils.googlecode.com</abstract>
- </metadata>
- <source>osm</source>
- <grid>google</grid>
- <metabuffer>10</metabuffer>
- </tileset>
- <merge_format>PNGQ_FAST</merge_format>
- <!-- this is the location where locks will be stored when a tile
- is not in the cache.
- this directory MUST exist, and be accessible for reading and
- writing by the user running apache (usually www-data or nobody)
- <lock_dir>/tmp/mylocks</lock_dir>
- <services>
- <wms>true</wms>
- <tms>true</tms>
- <wmts>true</wmts>
- <demo>true</demo>
- </services>
+ there are three preconfigured grids you can use in <tileset>s without having to
+ explicitely define them here:
+ <grid>
+ <name>WGS84</name>
+ <metadata>
+ <title>GoogleCRS84Quad</title>
+ <WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleCRS84Quad</WellKnownScaleSet>
+ </metadata>
+ <extent>-180 -90 180 90</extent>
+ <srs>epsg:4326</srs>
+ <size>256 256</size>
+ <resolutions>
+ 1.40625000000000
+ 0.703125000000000
+ 0.351562500000000
+ 0.175781250000000
+ 8.78906250000000e-2
+ 4.39453125000000e-2
+ 2.19726562500000e-2
+ 1.09863281250000e-2
+ 5.49316406250000e-3
+ 2.74658203125000e-3
+ 1.37329101562500e-3
+ 6.86645507812500e-4
+ 3.43322753906250e-4
+ 1.71661376953125e-4
+ 8.58306884765625e-5
+ 4.29153442382812e-5
+ 2.14576721191406e-5
+ 1.07288360595703e-5
+ 5.36441802978516e-6
+ </resolutions>
+ </grid>
+ <grid>
+ <name>google</name>
+ <metadata>
+ <title>GoogleMapsCompatible</title>
+ </metadata>
+ <extent>-20037508.34,-20037508.34,20037508.34,20037508.34</extent>
+ <srs>epsg:900913</srs>
+ <resolutions>
+ 156543.0339280410
+ 78271.51696402048
+ 39135.75848201023
+ 19567.87924100512
+ 9783.939620502561
+ 4891.969810251280
+ 2445.984905125640
+ 1222.992452562820
+ 611.4962262814100
+ 305.7481131407048
+ 152.8740565703525
+ 76.43702828517624
+ 38.21851414258813
+ 19.10925707129406
+ 9.554628535647032
+ 4.777314267823516
+ 2.388657133911758
+ 1.194328566955879
+ 0.5971642834779395
+ </resolutions>
+ </grid>
+ <grid>
+ <name>GoogleMapsCompatible</name>
+ <metadata>
+ </metadata>
+ <srs>epsg:3857</srs>
+ <resolutions>
+ 156543.0339280410
+ 78271.51696402048
+ 39135.75848201023
+ 19567.87924100512
+ 9783.939620502561
+ 4891.969810251280
+ 2445.984905125640
+ 1222.992452562820
+ 611.4962262814100
+ 305.7481131407048
+ 152.8740565703525
+ 76.43702828517624
+ 38.21851414258813
+ 19.10925707129406
+ 9.554628535647032
+ 4.777314267823516
+ 2.388657133911758
+ 1.194328566955879
+ </resolutions>
+ </grid>
+ a cache is where tiles are stored once they have been rendered
+ the only "type" available right now is "disk"
+ <cache name="disk" type="disk">
+ <!-- base
+ absolute filesystem path where the tile structure will be stored.
+ this directory needs to be readable and writable by the user running
+ apache
+ <base>/tmp</base>
+ <!-- symlink_blank
+ EXPERIMENTAL !!!
+ enable blank (i.e. uniform color) tile detection. blank tiles will be
+ detected at creation time and linked to a single blank tile on disk to
+ preserve disk space.
+ note that mod-geocache does not use "soft" links, and filesystems/OSes have
+ a limit on the number of links a file can accept. On linux this limit is around
+ 32000, which is probably not sufficient if you are creating a cache of large empty
+ areas.
+ this option should probably not be enabled on production platforms until this issue
+ is sorted out (probably by using soft links, but they are not portable)
+ <symlink_blank/>
+ </cache>
+ <!-- format
+ a format is an image algorithm used for compressing images
+ types can be "PNG" or "JPEG"
+ <format name="PNGQ_FAST" type ="PNG">
+ <!-- compression
+ png compression: best or fast
+ note that "best" compression is cpu intensive for little gain over the default
+ default compression is obtained by leving out this tag.
+ <compression>fast</compression>
+ <!-- colors
+ if supplied, this enables png quantization which reduces the number of colors
+ in an image to atain higher compression. this operation is destructive, and can
+ cause artifacts in the stored image.
+ the number of colors can be between 2 and 256
+ <colors>256</colors>
+ </format>
+ <format name="myjpeg" type ="JPEG">
+ <!-- quality
+ JPEG compression quality, ranging from 0 to 100
+ 95 produces high quality images with few visual artifacts
+ values under around 80 produce small images but with visible artifacts.
+ YMMV
+ <quality>95</quality>
+ </format>
+ <format name="PNG_BEST" type ="PNG">
+ <compression>best</compression>
+ </format>
+ <!-- source
+ the service to query for obtaining images if they are not in the cache
+ for now, type can only be "wms"
+ <source name="vmap0" type="wms">
+ <!-- url
+ url of the wms service, without any parameters
+ <url>http://vmap0.tiles.osgeo.org/wms/vmap0</url>
+ <!-- srs
+ srs that must be used for GetMap requests.
+ this should match the <grid> srs of the tileset, although there are some cases
+ where this isn't mandatory
+ <!-- wmsparams
+ extra parameters that will be added to the GetMap request. you can specify any
+ parameter here, e.g. VERSION if you want to override the version of the WMS
+ request.
+ the LAYERS parameter is mandatory.
+ usual parameters here are FORMAT , or MAP if using mapserver
+ <wmsparams>
+ <FORMAT>image/png</FORMAT>
+ <LAYERS>basic</LAYERS>
+ </wmsparams>
+ </source>
+ <source name="osm" type="wms">
+ <url>http://localhost/cgi-bin/mapserv?</url>
+ <wmsparams>
+ <LAYERS>default</LAYERS>
+ <MAP>/Users/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
+ </wmsparams>
+ </source>
+ <source name="nexrad" type="wms">
+ <url>http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi</url>
+ <wmsparams>
+ <LAYERS>nexrad_base_reflect</LAYERS>
+ <TRANSPARENT>true</TRANSPARENT>
+ </wmsparams>
+ </source>
+ <source name="basic" type="wms">
+ <url>http://geoservices.brgm.fr/geologie?</url>
+ <wmsparams>
+ <LAYERS>GRAVI_BASE</LAYERS>
+ </wmsparams>
+ </source>
+ <!-- tileset
+ a tileset regroups a <source>, <grid> and <cache>.
+ the "name" parameter is mandatory, and represents the key by which this tileset
+ will be requested by clients (e.g. in the WMS LAYERS parameter)
+ <tileset name="test">
+ <!-- source: the "name" attribute of a preconfigured <source> -->
+ <source>vmap0</source>
+ <!-- cache: the "name" attribute of a preconfigured <cache> -->
+ <cache>disk</cache>
+ <!-- grid: the "name" attribute of a preconfigured <grid> -->
+ <grid>WGS84</grid>
+ <!-- metadata
+ optional metadata tags used for responding to GetCapabilities request.
+ you can put anything in here, although only the title and abstract tags
+ are currently used to populate the GetCapabilities document.
+ <metadata>
+ <title>osm mapserver served map of midi-pyrénées</title>
+ <abstract>see http://mapserver-utils.googlecode.com</abstract>
+ </metadata>
+ <!-- watermark
+ optional tag to add a watermark to the tiles *before* storing them to cache
+ the supplied image MUST be exactly the same size as the size of the tiles
+ configured in the <grid>
+ the supplied image is read when the configuration is loaded.
+ if you make changes to the image, they will NOT be reflected on tiles already
+ stored in the cache, nor on newly stored tiles until the server is restarted
+ <watermark>/Users/tbonfort/Documents/terriscope/logo-watermark.png</watermark>
+ <!-- format
+ (optional) format to use when storing a tile. this should be a format with high
+ compression, eg. png with compression "best", as the compression operation is only
+ done once at creation time.
+ if left out, no recompression is applied to the image, mod-geocache will store the
+ exact image received from the <source>
+ note that the <format> tag is mandatory if metatile, metabuffer or watermark are
+ supplied, as in those cases a recompression has to be done.
+ <format>PNG</format>
+ <!-- metatile
+ number of columns and rows to use for metatiling, see http://geowebcache.org/docs/current/concepts/metatiles.html
+ <metatile>5 5</metatile>
+ <!-- metabuffer
+ area around the tile or metatile that will be cut off to prevent some edge artifacts.
+ if using this, the configured source must be instructed not to put any labels inside
+ this area, as otherwise this will result in truncated labels (for mapserver, this is
+ the "labelcache_map_edge_buffer" "-10" metadata entry, along with label PARTIALS FALSE
+ <metabuffer>10</metabuffer>
+ <!-- expires
+ optional expiration value in seconds for a tile. this is expressed in a number of seconds
+ after the creation date of the tile
+ <expires>3600</expires>
+ </tileset>
+ <tileset name="test2">
+ <source>nexrad</source>
+ </tileset>
+ <tileset name="test3">
+ <source>basic</source>
+ <format>PNG8</format>
+ <metabuffer>30</metabuffer>
+ </tileset>
+ <tileset name="osm">
+ <metadata>
+ </metadata>
+ <source>osm</source>
+ <grid>google</grid>
+ </tileset>
+ <!-- merge_format
+ format to use when a client asks for an image that is dynamically created from multiple
+ tiles from the cache.
+ note that using a png format with "best" compression is not recommended
+ here as it comes with a very compression overhead in terms of cpu processing. it is
+ recommended to use a png format with "fast"compression here, unless you have plenty
+ of server cpu power and or limited bandwidth
+ <merge_format>PNGQ_FAST</merge_format>
+ <!-- this is the location where locks will be stored when a tile
+ is not in the cache.
+ this directory MUST exist, and be accessible for reading and
+ writing by the user running apache (usually www-data or nobody)
+ <lock_dir>/tmp</lock_dir>
+ <!-- services
+ services that will be responded to by mod-geocache
+ each service is accessible at the url http://host/path/to/geocache/{service},
+ eg http://myhost/geocache/wms for OGC WMS.
+ <services>
+ <!-- OGC WMS -->
+ <wms>true</wms>
+ <!-- OSGEO TMS -->
+ <tms>true</tms>
+ <!-- OGC WMTS -->
+ <wmts>true</wmts>
+ <!-- demo
+ interface with a simple openlayers map serving the configured layers through WMS.
+ <demo>true</demo>
+ </services>
</geocache>
More information about the mapserver-commits
