[mapserver-commits] r12227 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:08:51 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:08:51 -0700 (Fri, 26 Aug 2011)
New Revision: 12227
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/mod_geocache.c
add MFLAGS
thomas.bonfort | 2011-01-10 09:26:51 +0100 (Mon, 10 Jan 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:08:46 UTC (rev 12226)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:08:51 UTC (rev 12227)
@@ -554,6 +554,7 @@
 struct geocache_server_cfg {
     apr_global_mutex_t *mutex;
+    char *mutex_name;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:08:46 UTC (rev 12226)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:08:51 UTC (rev 12227)
@@ -35,8 +35,6 @@
 module AP_MODULE_DECLARE_DATA geocache_module;
-static char* geocache_mutex_name = "geocache_mutex";
 typedef struct geocache_context_apache geocache_context_apache;
 typedef struct geocache_context_apache_request geocache_context_apache_request;
 typedef struct geocache_context_apache_server geocache_context_apache_server;
@@ -281,8 +279,6 @@
    apr_status_t rc;
    geocache_server_cfg* cfg = ap_get_module_config(s->module_config, &geocache_module);
    apr_lockmech_e lock_type = APR_LOCK_DEFAULT;
-   char *mutex_unique_name = apr_psprintf(p,"%s-%d",geocache_mutex_name,getpid());
-   ap_log_error(APLOG_MARK, APLOG_DEBUG, 0, s, "mutex name is %s",mutex_unique_name);
    if(!cfg) {
       ap_log_error(APLOG_MARK, APLOG_CRIT, 0, s, "configuration not found in server context");
@@ -292,15 +288,15 @@
 #if APR_HAS_PROC_PTHREAD_SERIALIZE
    lock_type = APR_LOCK_PROC_PTHREAD;
 #endif
-   rc = apr_global_mutex_create(&cfg->mutex,mutex_unique_name,lock_type,p);
+   rc = apr_global_mutex_create(&cfg->mutex,cfg->mutex_name,lock_type,p);
    if(rc != APR_SUCCESS) {
-      ap_log_error(APLOG_MARK, APLOG_CRIT, rc, s, "Could not create global parent mutex %s", geocache_mutex_name);
+      ap_log_error(APLOG_MARK, APLOG_CRIT, rc, s, "Could not create global parent mutex %s", cfg->mutex_name);
       return rc;
 #ifdef AP_NEED_SET_MUTEX_PERMS
    rc = unixd_set_global_mutex_perms(cfg->mutex);
-      ap_log_error(APLOG_MARK, APLOG_CRIT, rc, s, "Could not set permissions on global parent mutex %s", geocache_mutex_name);
+      ap_log_error(APLOG_MARK, APLOG_CRIT, rc, s, "Could not set permissions on global parent mutex %s", cfg->mutex_name);
       return rc;
 #endif
@@ -311,7 +307,7 @@
 static void mod_geocache_child_init(apr_pool_t *pool, server_rec *s) {
-   apr_global_mutex_child_init(&(cfg->mutex),geocache_mutex_name, pool);
+   apr_global_mutex_child_init(&(cfg->mutex),cfg->mutex_name, pool);
 static void mod_geocache_register_hooks(apr_pool_t *p) {
@@ -328,11 +324,20 @@
 static void* mod_geocache_create_server_conf(apr_pool_t *pool, server_rec *s) {
    geocache_server_cfg *cfg = apr_pcalloc(pool, sizeof(geocache_server_cfg));
+   char *mutex_unique_name = apr_psprintf(pool,"geocachemutex-%d",getpid());
+   cfg->mutex_name = ap_server_root_relative(pool, mutex_unique_name);
    return cfg;
+static void *mod_geocache_merge_server_conf(apr_pool_t *p, void *base_, void *vhost_)
+   return base_;
 static const char* geocache_set_config_file(cmd_parms *cmd, void *cfg, const char *val) {
    geocache_cfg *config = (geocache_cfg*)cfg;
    geocache_context *ctx = (geocache_context*)apache_server_context_create(cmd->server,cmd->pool);
@@ -357,7 +362,7 @@
       mod_geocache_create_dir_conf,
       NULL,
       mod_geocache_create_server_conf,
-      NULL,
+      mod_geocache_merge_server_conf,
       mod_geocache_cmds,
