[mapserver-commits] r12234 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:09:25 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:09:25 -0700 (Fri, 26 Aug 2011)
New Revision: 12234
trunk/mapserver/mapcache/src/lock.c
use symbolic links for blank tiles
closes issue 16.
thomas.bonfort | 2011-01-11 15:38:57 +0100 (Tue, 11 Jan 2011)
Modified: trunk/mapserver/mapcache/src/lock.c
--- trunk/mapserver/mapcache/src/lock.c 2011-08-26 11:09:21 UTC (rev 12233)
+++ trunk/mapserver/mapcache/src/lock.c 2011-08-26 11:09:25 UTC (rev 12234)
@@ -41,7 +41,7 @@
char *lockname = geocache_tileset_tile_lock_key(ctx,tile);
sem_t *lock;
if ((lock = sem_open(lockname, O_CREAT|O_EXCL, 0644, 1)) == SEM_FAILED) {
- ctx->set_error(ctx,GEOCACHE_MUTEX_ERROR, "failed to create pthread semaphore %s",lockname);
+ ctx->set_error(ctx,GEOCACHE_MUTEX_ERROR, "failed to create posix semaphore %s: %s",lockname, strerror(errno));
return;
sem_wait(lock);
@@ -67,12 +67,10 @@
sem_post(lock);
/*check if the semaphore is held by others*/
sem_getvalue(lock,&semvalue);
+ sem_close(lock);
if(semvalue>0) {
/*no one is using the lock, delete it*/
sem_unlink(lockname);
- } else {
- /*just close it as others are using it*/
- sem_close(lock);
tile->lock = NULL;
@@ -134,10 +132,9 @@
sem_wait(lock);
sem_post(lock);
+ sem_close(lock);
if(semvalue>0) {
- } else {
- sem_close(lock);
More information about the mapserver-commits
