[mapserver-commits] r12246 - in trunk/mapserver/mapcache: . src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:10:36 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:10:36 -0700 (Fri, 26 Aug 2011)
New Revision: 12246
trunk/mapserver/mapcache/configure.in
trunk/mapserver/mapcache/src/cache_disk.c
add WMTS Restful parser
thomas.bonfort | 2011-01-13 17:11:07 +0100 (Thu, 13 Jan 2011)
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2011-08-26 11:10:32 UTC (rev 12245)
+++ trunk/mapserver/mapcache/configure.in 2011-08-26 11:10:36 UTC (rev 12246)
@@ -16,6 +16,8 @@
dnl ---------------------------------------------------------------------
CFLAGS="$CFLAGS -fPIC"
+AC_CHECK_FUNC(symlink,[CFLAGS="$CFLAGS -DHAVE_SYMLINK"])
TARGETS=
# macro that is used to parse a --with-apxs parameter
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:10:32 UTC (rev 12245)
+++ trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:10:36 UTC (rev 12246)
@@ -18,7 +18,13 @@
#include <apr_file_info.h>
#include <apr_strings.h>
#include <apr_file_io.h>
+#include <string.h>
+#include <errno.h>
+#ifdef HAVE_SYMLINK
+#include <unistd.h>
+#endif
void _geocache_cache_disk_blank_tile_key(geocache_context *ctx, geocache_tile *tile, unsigned char *color, char **path) {
*path = apr_psprintf(ctx->pool,"%s/%s/%s/blanks/%02X%02X%02X%02X.%s",
((geocache_cache_disk*)tile->tileset->cache)->base_directory,
@@ -173,7 +179,8 @@
return;
*hackptr2 = '/';
if(((geocache_cache_disk*)tile->tileset->cache)->symlink_blank) {
geocache_image *image = geocache_imageio_decode(ctx, tile->data);
GC_CHECK_ERROR(ctx);
@@ -217,8 +224,7 @@
#endif
ctx->global_lock_release(ctx);
- int errno;
- if(errno = apr_file_link(blankname,filename) != GEOCACHE_SUCCESS) {
+ if(symlink(blankname,filename) != 0) {
ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to link tile %s to %s: %s",filename, blankname, strerror(errno));
return; /* we could not create the file */
@@ -228,6 +234,7 @@
return;
+#endif /*HAVE_SYMLINK*/
/* go the normal way: either we haven't configured blank tile detection, or the tile was not blank */
if(apr_file_open(&f, filename,
@@ -258,8 +265,14 @@
if ((cur_node = ezxml_child(node,"symlink_blank")) != NULL) {
- if(strcasecmp(cur_node->txt,"false"))
+ if(strcasecmp(cur_node->txt,"false")){
dcache->symlink_blank = 1;
+#else
+ ctx->set_error(ctx,GEOCACHE_DISK_ERROR,"cache %s: host system does not support file symbolic linking",cache->name);
+ return;
+#endif
@@ -281,14 +294,6 @@
ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create directory %s for cache %s",dcache->base_directory,dcache->cache.name );
return;
- /*win32 isn't buildable yet, but put this check in now for reminders*/
-#ifdef _WIN32
- if(dcache->symlink_blank) {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "linking blank tiles isn't supported on WIN32 due to platform limitations");
-#endif
return;
More information about the mapserver-commits
