[mapserver-commits] r12252 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:11:12 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:11:12 -0700 (Fri, 26 Aug 2011)
New Revision: 12252
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/util.h
trunk/mapserver/mapcache/src/util.c
use / in front of semaphore name (thanks Chris J. Mutter)
dont use sem_getvalue as we dont need it. only the process/thread that
has created the semaphore needs to call sem_unlink on it.
thomas.bonfort | 2011-01-17 08:55:58 +0100 (Mon, 17 Jan 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:11:08 UTC (rev 12251)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:11:12 UTC (rev 12252)
@@ -242,7 +242,7 @@
<wmsparams>
<FORMAT>image/png</FORMAT>
<LAYERS>default</LAYERS>
- <MAP>/Users/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
+ <MAP>/home/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
</wmsparams>
</source>
<source name="nexrad" type="wms">
Modified: trunk/mapserver/mapcache/include/util.h
--- trunk/mapserver/mapcache/include/util.h 2011-08-26 11:11:08 UTC (rev 12251)
+++ trunk/mapserver/mapcache/include/util.h 2011-08-26 11:11:12 UTC (rev 12252)
@@ -39,19 +39,6 @@
#endif
-#if APR_MAJOR_VERSION < 2 && APR_MINOR_VERSION < 4
- * Create a hard link to the specified file.
- * @param from_path The full path to the original file (using / on all systems)
- * @param to_path The full path to the new file (using / on all systems)
- * @remark Both files must reside on the same device.
-APR_DECLARE(apr_status_t) apr_file_link(const char *from_path, const char *to_path);
-#endif
#endif /* UTIL_H_ */
/* vim: ai ts=3 sts=3 et sw=3
Modified: trunk/mapserver/mapcache/src/util.c
--- trunk/mapserver/mapcache/src/util.c 2011-08-26 11:11:08 UTC (rev 12251)
+++ trunk/mapserver/mapcache/src/util.c 2011-08-26 11:11:12 UTC (rev 12252)
@@ -75,19 +75,6 @@
return GEOCACHE_SUCCESS;
- const char *to_path)
- if (link(from_path, to_path) == -1) {
- return errno;
- return APR_SUCCESS;
-#endif
#if APR_MAJOR_VERSION < 2 && APR_MINOR_VERSION < 3
APR_DECLARE(apr_table_t *) apr_table_clone(apr_pool_t *p, const apr_table_t *t)
More information about the mapserver-commits
