[mapserver-commits] r12260 - in trunk/mapserver/mapcache: . src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:11:48 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:11:48 -0700 (Fri, 26 Aug 2011)
New Revision: 12260
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/src/service_wmts.c
shorten semaphore names
thomas.bonfort | 2011-01-17 21:41:21 +0100 (Mon, 17 Jan 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:11:43 UTC (rev 12259)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:11:48 UTC (rev 12260)
@@ -247,7 +247,7 @@
<wmsparams>
<FORMAT>image/png</FORMAT>
<LAYERS>default</LAYERS>
- <MAP>/home/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
+ <MAP>/Users/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
</wmsparams>
</source>
<source name="nexrad" type="wms">
Modified: trunk/mapserver/mapcache/src/service_wmts.c
--- trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:11:43 UTC (rev 12259)
+++ trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:11:48 UTC (rev 12260)
@@ -234,10 +234,11 @@
"%s"
" </TileMatrixSetLink>\n"
" <ResourceURL format=\"%s\" resourceType=\"tile\"\n"
- " template=\"%s/wmts/default/{TileMatrixSet}/{TileMatrix}/%s{TileRow}/{TileCol}.%s\"/>\n"
+ " template=\"%s/wmts/1.0.0/%s/default/{TileMatrixSet}/{TileMatrix}/%s{TileRow}/{TileCol}.%s\"/>\n"
" </Layer>\n",caps,title,abstract,
tileset->name,dimensions,tileset->format->mime_type,tmsets,
- tileset->format->mime_type,onlineresource,dimensionstemplate,tileset->format->extension);
+ tileset->format->mime_type,onlineresource,
+ tileset->name, dimensionstemplate,tileset->format->extension);
layer_index = apr_hash_next(layer_index);
caps = apr_pstrcat(ctx->pool,caps,"</Contents>\n</Capabilities>\n",NULL);
@@ -251,179 +252,262 @@
void _geocache_service_wmts_parse_request(geocache_context *ctx, geocache_request **request,
const char *pathinfo, apr_table_t *params, geocache_cfg *config) {
- const char *str, *layer, *matrixset, *matrix;
+ const char *str, *service = NULL, *style = NULL, *version = NULL, *layer = NULL, *matrixset = NULL,
+ *matrix = NULL, *tilecol = NULL, *tilerow = NULL;
+ apr_table_t *dimtable = NULL;
geocache_tileset *tileset;
int row,col,level;
- str = apr_table_get(params,"SERVICE");
- if(!str) {
- ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR,"received wmts request with no service param");
- return;
- if( strcasecmp(str,"wmts") ) {
- ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR,"received wmts request with invalid service param %s", str);
- return;
- str = apr_table_get(params,"REQUEST");
- if(!str) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no request");
- return;
- if( ! strcasecmp(str,"getcapabilities") ) {
- geocache_request_get_capabilities_wmts *req = (geocache_request_get_capabilities_wmts*)
- apr_pcalloc(ctx->pool,sizeof(geocache_request_get_capabilities_wmts));
- req->request.request.type = GEOCACHE_REQUEST_GET_CAPABILITIES;
- *request = (geocache_request*)req;
- return;
- } else if( strcasecmp(str,"gettile")) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid request %s",str);
- return;
- } else {
- geocache_grid *grid = NULL;
- str = apr_table_get(params,"TILEROW");
- if(!str) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILEROW");
+ service = apr_table_get(params,"SERVICE");
+ if(service) {
+ /*KVP Parsing*/
+ if( strcasecmp(service,"wmts") ) {
+ ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR,"received wmts request with invalid service param %s", str);
return;
- } else {
- char *endptr;
- row = (int)strtol(str,&endptr,10);
- if(*endptr != 0 || row < 0) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request with invalid TILEROW");
- return;
- str = apr_table_get(params,"TILECOL");
+ str = apr_table_get(params,"REQUEST");
if(!str) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILECOL");
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no request");
return;
- } else {
- char *endptr;
- col = (int)strtol(str,&endptr,10);
- if(*endptr != 0 || col < 0) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request with invalid TILECOL");
- return;
- layer = apr_table_get(params,"LAYER");
- if(!layer) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no layer");
+ if( ! strcasecmp(str,"getcapabilities") ) {
+ geocache_request_get_capabilities_wmts *req = (geocache_request_get_capabilities_wmts*)
+ apr_pcalloc(ctx->pool,sizeof(geocache_request_get_capabilities_wmts));
+ req->request.request.type = GEOCACHE_REQUEST_GET_CAPABILITIES;
+ *request = (geocache_request*)req;
return;
- } else {
- tileset = geocache_configuration_get_tileset(config,layer);
- if(!tileset) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid layer %s",layer);
+ } else if( ! strcasecmp(str,"gettile")) {
+ /* extract our wnated parameters, they will be validated later on */
+ tilerow = apr_table_get(params,"TILEROW");
+ tilecol = apr_table_get(params,"TILECOL");
+ layer = apr_table_get(params,"LAYER");
+ if(!layer) { /*we have to validate this now in order to be able to extract dimensions*/
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no layer");
return;
+ } else {
+ tileset = geocache_configuration_get_tileset(config,layer);
+ if(!tileset) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid layer %s",layer);
+ return;
- matrixset = apr_table_get(params,"TILEMATRIXSET");
- if(!matrixset) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILEMATRIXSET");
+ matrixset = apr_table_get(params,"TILEMATRIXSET");
+ matrix = apr_table_get(params,"TILEMATRIX");
+ if(tileset->dimensions) {
+ int i;
+ dimtable = apr_table_make(ctx->pool,tileset->dimensions->nelts);
+ for(i=0;i<tileset->dimensions->nelts;i++) {
+ geocache_dimension *dimension = APR_ARRAY_IDX(tileset->dimensions,i,geocache_dimension*);
+ const char *value;
+ if((value = apr_table_get(params,dimension->name)) != NULL) {
+ apr_table_set(dimtable,dimension->name,value);
+ } else {
+ apr_table_set(dimtable,dimension->name,dimension->default_value);
+ } else {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid request %s",str);
return;
- } else {
- int i;
- for(i=0;i<tileset->grids->nelts;i++) {
- geocache_grid *sgrid = APR_ARRAY_IDX(tileset->grids,i,geocache_grid*);
- if(strcmp(sgrid->name,matrixset)) continue;
- grid = sgrid;
- break;
- if(!grid) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid TILEMATRIXSET %s",matrixset);
- return;
- matrix = apr_table_get(params,"TILEMATRIX");
- if(!matrix) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILEMATRIX");
- return;
- } else {
- const char *levelptr=NULL,*key; /*ptr to the last part of tilematrix:level*/
- for(key=matrix;*key;key++) if(*key == ':') levelptr=key;
- if(!levelptr || !*(++levelptr)) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid TILEMATRIX %s", matrix);
- return;
- } else {
- char *endptr;
- level = (int)strtol(levelptr,&endptr,10);
- if(*endptr != 0 || level < 0 || level >= grid->levels) {
- ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request with invalid TILEMATRIX %s", matrix);
+ } else {
+ char *key, *last;
+ for (key = apr_strtok(apr_pstrdup(ctx->pool,pathinfo), "/", &last); key != NULL;
+ key = apr_strtok(NULL, "/", &last)) {
+ if(!version) {
+ version = key;
+ if(strcmp(version,"1.0.0")) {
+ ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR, "WMTS restful parser: missing VERSION");
return;
+ continue;
+ if(!layer) {
+ if(!strcmp(key,"WMTSCapabilities.xml")) {
+ return;
+ layer = key;
+ if(!tileset) {
+ return;
+ continue;
+ if(!style) {
+ style = key;
+ continue;
+ if(!matrixset) {
+ matrixset = key;
+ continue;
+ if(!matrix) {
+ matrix=key;
+ continue;
+ if(!dimtable)
+ int i = apr_table_elts(dimtable)->nelts;
+ if(i != tileset->dimensions->nelts) {
+ ctx->log(ctx,GEOCACHE_DEBUG,"add dim %s",key);
+ /*we still have some dimensions to parse*/
+ if(!strcmp(key,dimension->name)) {
+ /*we have found the key in the url, advance to next token*/
+ key = apr_strtok(NULL, "/", &last);
+ if(!key) {
+ ctx->set_error(ctx,GEOCACHE_PARSE_ERROR,"failed to parse value for dimension %s",dimension->name);
+ return;
+ apr_table_set(dimtable,dimension->name,key);
+ } else {
+ /*key wasn't included in the url*/
+ ctx->set_error(ctx,GEOCACHE_PARSE_ERROR,"dimension %s not found in request (got %s)",dimension->name, key);
+ return;
+ continue;
+ if(!tilerow) {
+ tilerow = key;
+ continue;
+ if(!tilecol) {
+ tilecol = key;
+ continue;
+ /*Restful Parsing*/
- geocache_request_get_tile *req = (geocache_request_get_tile*)apr_pcalloc(
- ctx->pool,sizeof(geocache_request_get_tile));
- req->request.type = GEOCACHE_REQUEST_GET_TILE;
- req->ntiles = 1;
- req->tiles = (geocache_tile**)apr_pcalloc(ctx->pool,sizeof(geocache_tile*));
- req->tiles[0] = geocache_tileset_tile_create(ctx->pool, tileset);
- if(!req->tiles[0]) {
- ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "failed to allocate tile");
+ geocache_grid *grid = NULL;
+ if(!tilerow) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILEROW");
+ return;
+ } else {
+ char *endptr;
+ row = (int)strtol(tilerow,&endptr,10);
+ if(*endptr != 0 || row < 0) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request with invalid TILEROW %s",tilerow);
return;
- req->tiles[0]->grid = grid;
- double unitheight = grid->tile_sy * grid->resolutions[level];
- double unitwidth = grid->tile_sx * grid->resolutions[level];
- int matrixheight = ceil((grid->extents[level][3]-grid->extents[level][1] - 0.01* unitheight)/unitheight);
- int matrixwidth = ceil((grid->extents[level][2]-grid->extents[level][0] - 0.01* unitwidth)/unitwidth);
- if(row >= matrixheight) {
- ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "tilerow %d to large for selected tilematrix (max is %d)",row,matrixheight);
+ if(!tilecol) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILECOL");
+ return;
+ } else {
+ char *endptr;
+ col = (int)strtol(tilecol,&endptr,10);
+ if(endptr == tilecol || col < 0) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request with invalid TILECOL");
return;
- if(col >= matrixwidth) {
- ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "tilecol %d to large for selected tilematrix (max is %d)",col,matrixwidth);
+ if(!matrixset) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILEMATRIXSET");
+ return;
+ } else {
+ int i;
+ for(i=0;i<tileset->grids->nelts;i++) {
+ geocache_grid *sgrid = APR_ARRAY_IDX(tileset->grids,i,geocache_grid*);
+ if(strcmp(sgrid->name,matrixset)) continue;
+ grid = sgrid;
+ break;
+ if(!grid) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid TILEMATRIXSET %s",matrixset);
return;
- row = matrixheight-row-1;
- /*look for dimensions*/
- if(tileset->dimensions) {
- int i;
- req->tiles[0]->dimensions = apr_table_make(ctx->pool,tileset->dimensions->nelts);
- for(i=0;i<tileset->dimensions->nelts;i++) {
- geocache_dimension *dimension = APR_ARRAY_IDX(tileset->dimensions,i,geocache_dimension*);
- const char *value;
- if((value = apr_table_get(params,dimension->name)) != NULL) {
- int ok = dimension->validate(ctx,dimension,value);
- GC_CHECK_ERROR(ctx);
- if(ok == GEOCACHE_SUCCESS)
- apr_table_setn(req->tiles[0]->dimensions,dimension->name,value);
- else {
- ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR,"dimension \"%s\" value \"%s\" fails to validate",
- dimension->name, value);
- return;
- } else {
- apr_table_setn(req->tiles[0]->dimensions,dimension->name,dimension->default_value);
+ if(!matrix) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with no TILEMATRIX");
+ return;
+ } else {
+ const char *levelptr=NULL,*key; /*ptr to the last part of tilematrix:level*/
+ for(key=matrix;*key;key++) if(*key == ':') levelptr=key;
+ if(!levelptr || !*(++levelptr)) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wmts request with invalid TILEMATRIX %s", matrix);
+ return;
+ } else {
+ char *endptr;
+ level = (int)strtol(levelptr,&endptr,10);
+ if(*endptr != 0 || level < 0 || level >= grid->levels) {
+ ctx->set_error(ctx, GEOCACHE_REQUEST_ERROR, "received wms request with invalid TILEMATRIX %s", matrix);
+ return;
- req->tiles[0]->x = col;
- req->tiles[0]->y = row;
- req->tiles[0]->z = level;
- geocache_tileset_tile_validate(ctx,req->tiles[0]);
+ geocache_request_get_tile *req = (geocache_request_get_tile*)apr_pcalloc(
+ ctx->pool,sizeof(geocache_request_get_tile));
+ req->request.type = GEOCACHE_REQUEST_GET_TILE;
+ req->ntiles = 1;
+ req->tiles = (geocache_tile**)apr_pcalloc(ctx->pool,sizeof(geocache_tile*));
+ req->tiles[0] = geocache_tileset_tile_create(ctx->pool, tileset);
+ if(!req->tiles[0]) {
+ ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "failed to allocate tile");
return;
+ /*validate dimensions*/
+ int i;
+ req->tiles[0]->dimensions = apr_table_make(ctx->pool,tileset->dimensions->nelts);
+ const char *value = apr_table_get(dimtable,dimension->name);
+ int ok = dimension->validate(ctx,dimension,value);
+ GC_CHECK_ERROR(ctx);
+ if(ok == GEOCACHE_SUCCESS)
+ apr_table_set(req->tiles[0]->dimensions,dimension->name,value);
+ else {
+ ctx->set_error(ctx,GEOCACHE_REQUEST_ERROR,"dimension \"%s\" value \"%s\" fails to validate",
+ dimension->name, value);
+ return;
+ req->tiles[0]->grid = grid;
+ double unitheight = grid->tile_sy * grid->resolutions[level];
+ double unitwidth = grid->tile_sx * grid->resolutions[level];
+ int matrixheight = ceil((grid->extents[level][3]-grid->extents[level][1] - 0.01* unitheight)/unitheight);
+ int matrixwidth = ceil((grid->extents[level][2]-grid->extents[level][0] - 0.01* unitwidth)/unitwidth);
+ if(row >= matrixheight) {
+ ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "tilerow %d to large for selected tilematrix (max is %d)",row,matrixheight);
+ return;
+ if(col >= matrixwidth) {
+ ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "tilecol %d to large for selected tilematrix (max is %d)",col,matrixwidth);
+ return;
+ row = matrixheight-row-1;
+ req->tiles[0]->x = col;
+ req->tiles[0]->y = row;
+ req->tiles[0]->z = level;
+ geocache_tileset_tile_validate(ctx,req->tiles[0]);
+ return;
geocache_service* geocache_service_wmts_create(geocache_context *ctx) {
More information about the mapserver-commits
