[mapserver-commits] r12276 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:13:09 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:13:09 -0700 (Fri, 26 Aug 2011)
New Revision: 12276
trunk/mapserver/mapcache/src/lock.c
comment unimplemented function
thomas.bonfort | 2011-01-21 08:39:01 +0100 (Fri, 21 Jan 2011)
Modified: trunk/mapserver/mapcache/src/lock.c
--- trunk/mapserver/mapcache/src/lock.c 2011-08-26 11:13:05 UTC (rev 12275)
+++ trunk/mapserver/mapcache/src/lock.c 2011-08-26 11:13:09 UTC (rev 12276)
@@ -30,8 +30,13 @@
static char* num_encode(apr_pool_t *pool, int num) {
int n = num,r;
- int i = 0;
- char *ret = apr_pcalloc(pool,10); /* allocate 10 chars, should be amply sufficient */
+ int i = 0
+ /* allocate 10 chars, should be amply sufficient:
+ * yes, this *really* should be amply sufficient:
+ * 10 chars, in 63 base = 10^63 different values.
+ * the earth is 40000km wide, which means we will start having
+ * a problem if a tile is less than 40000 * 1000 / 10^63 = 4e-56 meters wide*/;
+ char *ret = apr_pcalloc(pool,10);
while(1) {
r = n % encbase;
n = n / encbase;
More information about the mapserver-commits
