[mapserver-commits] r12278 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:13:19 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:13:19 -0700 (Fri, 26 Aug 2011)
New Revision: 12278
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/source_wms.c
initialize pathinfo
thomas.bonfort | 2011-01-21 10:43:27 +0100 (Fri, 21 Jan 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:13:14 UTC (rev 12277)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:13:19 UTC (rev 12278)
@@ -241,13 +241,46 @@
          <FORMAT>image/png</FORMAT>
          <LAYERS>basic</LAYERS>
       </wmsparams>
+      <!-- http
+         custom http parameters that will be used when making WMS requests
+      <http>
+         <!-- headers
+            http headers added to request. make sure you know what you are
+            doing when adding a header here, as they take precedence over any
+            default headers curl will be adding to the request.
+            typical headers that can be added here are User-Agent and Referer.
+            when adding a <key>value</key> element here, the request to the
+            wms source will contain the
+            key: value\r\n
+            HTTP header.
+         <headers>
+            <User-Agent>mod-geocache/r175</User-Agent>
+            <Referer>http://www.mysite.com?param=2&amp;par=4</Referer>
+         </headers>
+         <!-- TODO other http parameters
+              * PROXY
+              * AUTH
+      </http>
    </source>
    <source name="osm" type="wms">
       <url>http://localhost/cgi-bin/mapserv?</url>
       <wmsparams>
          <LAYERS>default</LAYERS>
-         <MAP>/Users/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
+         <MAP>/home/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
       </wmsparams>
    </source>
    <source name="nexrad" type="wms">
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:13:14 UTC (rev 12277)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:13:19 UTC (rev 12278)
@@ -47,7 +47,7 @@
 #define GEOCACHE_FILE_LOCKED 6
 #define GEOCACHE_VERSION "0.3-dev"
-#define GEOCACHE_USERAGENT "geocache/"GEOCACHE_VERSION
+#define GEOCACHE_USERAGENT "mod-geocache/"GEOCACHE_VERSION
@@ -231,6 +231,7 @@
     char *url; /**< the base WMS url */
     apr_table_t *wms_default_params; /**< default WMS parameters (SERVICE,REQUEST,STYLES,VERSION) */
     apr_table_t *wms_params; /**< WMS parameters specified in configuration */
+    apr_table_t *http_headers;
 #ifdef USE_GDAL
Modified: trunk/mapserver/mapcache/src/source_wms.c
--- trunk/mapserver/mapcache/src/source_wms.c	2011-08-26 11:13:14 UTC (rev 12277)
+++ trunk/mapserver/mapcache/src/source_wms.c	2011-08-26 11:13:19 UTC (rev 12278)
@@ -44,7 +44,7 @@
     tile->tile.data = geocache_buffer_create(30000,ctx->pool);
-    geocache_http_request_url_with_params(ctx,wms->url,params,NULL,tile->tile.data);
+    geocache_http_request_url_with_params(ctx,wms->url,params,wms->http_headers,tile->tile.data);
     GC_CHECK_ERROR(ctx);
     if(!geocache_imageio_is_valid_format(ctx,tile->tile.data)) {
@@ -71,6 +71,16 @@
          apr_table_set(src->wms_params, cur_node->name, cur_node->txt);
+   if ((cur_node = ezxml_child(node,"http")) != NULL) {
+      ezxml_t http_node;
+      if((http_node = ezxml_child(cur_node,"headers")) != NULL) {
+         ezxml_t header_node;
+         for(header_node = http_node->child; header_node; header_node = header_node->sibling) {
+            apr_table_set(src->http_headers, header_node->name, header_node->txt);
+      /* TODO: parse <proxy> and <auth> elements */
@@ -101,6 +111,7 @@
    source->source.configuration_parse = _geocache_source_wms_configuration_parse;
    source->wms_default_params = apr_table_make(ctx->pool,4);;
    source->wms_params = apr_table_make(ctx->pool,4);
+   source->http_headers = apr_table_make(ctx->pool,1);
    apr_table_add(source->wms_default_params,"VERSION","1.1.1");
    apr_table_add(source->wms_default_params,"REQUEST","GetMap");
    apr_table_add(source->wms_default_params,"SERVICE","WMS");
