[mapserver-commits] r12283 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:13:40 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:13:40 -0700 (Fri, 26 Aug 2011)
New Revision: 12283
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/lock.c
   trunk/mapserver/mapcache/src/tileset.c
tweak
thomas.bonfort | 2011-01-24 17:54:29 +0100 (Mon, 24 Jan 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:13:35 UTC (rev 12282)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:13:40 UTC (rev 12283)
@@ -674,8 +674,6 @@
      * \sa geocache_image_format
     geocache_buffer *data;
-    void *lock; /**< pointer to opaque structure set by a geocache_cache to reference a lock on the tile
-                \sa geocache_cache::tile_lock() */
     apr_time_t mtime; /**< last modification time */
     int expires; /**< time in seconds after which the tile should be rechecked for validity */
@@ -694,6 +692,7 @@
     int ntiles; /**< the number of geocache_metatile::tiles contained in this metatile */
     geocache_tile *tiles; /**< the list of geocache_tile s contained in this metatile */
     geocache_image *imdata;
+    void *lock; /**< pointer to opaque structure set by the locking mechanism */
@@ -859,24 +858,24 @@
  * lock the tile
-void geocache_tileset_tile_lock(geocache_context *ctx, geocache_tile *tile);
+void geocache_tileset_metatile_lock(geocache_context *ctx, geocache_metatile *tile);
  * unlock the tile
-void geocache_tileset_tile_unlock(geocache_context *ctx, geocache_tile *tile);
+void geocache_tileset_metatile_unlock(geocache_context *ctx, geocache_metatile *tile);
  * check if there is a lock on the tile (the lock will have been set by another process/thread)
  * \returns GEOCACHE_TRUE if the tile is locked by another process/thread
  * \returns GEOCACHE_FALSE if there is no lock on the tile
-int geocache_tileset_tile_lock_exists(geocache_context *ctx, geocache_tile *tile);
+int geocache_tileset_metatile_lock_exists(geocache_context *ctx, geocache_metatile *tile);
  * wait for the lock set on the tile (the lock will have been set by another process/thread)
-void geocache_tileset_tile_lock_wait(geocache_context *ctx, geocache_tile *tile);
+void geocache_tileset_metatile_lock_wait(geocache_context *ctx, geocache_metatile *tile);
Modified: trunk/mapserver/mapcache/src/lock.c
--- trunk/mapserver/mapcache/src/lock.c	2011-08-26 11:13:35 UTC (rev 12282)
+++ trunk/mapserver/mapcache/src/lock.c	2011-08-26 11:13:40 UTC (rev 12283)
@@ -47,16 +47,16 @@
    return ret;
-char *geocache_tileset_tile_lock_key(geocache_context *ctx, geocache_tile *tile) {
+char *geocache_tileset_metatile_lock_key(geocache_context *ctx, geocache_metatile *mt) {
    char *lockname = apr_psprintf(ctx->pool,
          "/%s-%s-%s%s", /*x,y,z,tilesetname*/
-         num_encode(ctx->pool,tile->x), num_encode(ctx->pool,tile->y),
-         num_encode(ctx->pool,tile->z), tile->tileset->name);
-   if(tile->tileset->grid_links->nelts > 1) {
-      lockname = apr_pstrcat(ctx->pool,lockname,tile->grid_link->grid->name,NULL);
+         num_encode(ctx->pool,mt->tile.x), num_encode(ctx->pool,mt->tile.y),
+         num_encode(ctx->pool,mt->tile.z), mt->tile.tileset->name);
+   if(mt->tile.tileset->grid_links->nelts > 1) {
+      lockname = apr_pstrcat(ctx->pool,lockname,mt->tile.grid_link->grid->name,NULL);
-   if(tile->dimensions && !apr_is_empty_table(tile->dimensions)) {
-      const apr_array_header_t *elts = apr_table_elts(tile->dimensions);
+   if(mt->tile.dimensions && !apr_is_empty_table(mt->tile.dimensions)) {
+      const apr_array_header_t *elts = apr_table_elts(mt->tile.dimensions);
       int i;
       for(i=0;i<elts->nelts;i++) {
          apr_table_entry_t entry = APR_ARRAY_IDX(elts,i,apr_table_entry_t);
@@ -74,24 +74,21 @@
    return lockname;
- * \brief lock the given tile so other processes know it is being processed
+ * \brief lock the given metatile so other processes know it is being processed
  * this function call is protected by a mutex
  * this function creates a named semaphore and aquires a lock on it
- * \sa geocache_cache::tile_lock()
- * \sa geocache_cache::tile_lock_exists()
- * \private \memberof geocache_cache_disk
-void geocache_tileset_tile_lock(geocache_context *ctx, geocache_tile *tile) {
-   char *lockname = geocache_tileset_tile_lock_key(ctx,tile);
+void geocache_tileset_metatile_lock(geocache_context *ctx, geocache_metatile *mt) {
+   char *lockname = geocache_tileset_metatile_lock_key(ctx,mt);
    sem_t *lock;
    if ((lock = sem_open(lockname, O_CREAT|O_EXCL, 0644, 1)) == SEM_FAILED) {
       ctx->set_error(ctx,500, "failed to create posix semaphore %s: %s",lockname, strerror(errno));
       return;
    sem_wait(lock);
-   tile->lock = lock;
+   mt->lock = lock;
@@ -102,17 +99,17 @@
  * \sa geocache_cache::tile_unlock()
-void geocache_tileset_tile_unlock(geocache_context *ctx, geocache_tile *tile) {
-   sem_t *lock = (sem_t*) tile->lock;
-   const char *lockname = geocache_tileset_tile_lock_key(ctx,tile);
-   if (!tile->lock) {
+void geocache_tileset_metatile_unlock(geocache_context *ctx, geocache_metatile *mt) {
+   sem_t *lock = (sem_t*) mt->lock;
+   const char *lockname = geocache_tileset_metatile_lock_key(ctx,mt);
+   if (!mt->lock) {
       ctx->set_error(ctx,500,"###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", lockname);
       return;
    sem_post(lock);
    sem_close(lock);
    sem_unlink(lockname);
-   tile->lock = NULL;
+   mt->lock = NULL;
@@ -123,11 +120,11 @@
-int geocache_tileset_tile_lock_exists(geocache_context *ctx, geocache_tile *tile) {
+int geocache_tileset_metatile_lock_exists(geocache_context *ctx, geocache_metatile *mt) {
    char *lockname;
-   if (tile->lock)
+   if (mt->lock)
       return GEOCACHE_TRUE;
-   lockname = geocache_tileset_tile_lock_key(ctx, tile);
+   lockname = geocache_tileset_metatile_lock_key(ctx, mt);
    sem_t *lock = sem_open(lockname, 0, 0644, 1) ;
    if (lock == SEM_FAILED) {
       if(errno == ENOENT) {
@@ -148,16 +145,16 @@
  * this function will not return until the lock on the tile has been removed
  * \sa geocache_cache::tile_lock_wait()
-void geocache_tileset_tile_lock_wait(geocache_context *ctx, geocache_tile *tile) {
+void geocache_tileset_metatile_lock_wait(geocache_context *ctx, geocache_metatile *mt) {
   char *lockname;
   sem_t *lock;
 #ifdef DEBUG
-  if (tile->lock) {
+  if (mt->lock) {
     ctx->set_error(ctx, 500, "### BUG ### waiting for a lock we have created ourself");
     return;
 #endif
   if( lock == SEM_FAILED ) {
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:13:35 UTC (rev 12282)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:13:40 UTC (rev 12283)
@@ -63,37 +63,6 @@
- * for each of the metatile's tiles, ask the underlying cache to lock it
-void _geocache_tileset_metatile_lock(geocache_context *ctx, geocache_metatile *mt) {
-   int i;
-   for(i=0; i<mt->ntiles; i++) {
-      geocache_tile *tile = &(mt->tiles[i]);
-      geocache_tileset_tile_lock(ctx, tile);
-      if(GC_HAS_ERROR(ctx)) {
-         /* undo successful locks */
-         int j;
-         for(j=0;j<i;j++) {
-            tile = &(mt->tiles[j]);
-            geocache_tileset_tile_unlock(ctx,tile);
-         return;
- * for each of the metatile's tiles, ask the underlying cache to unlock it
-void _geocache_tileset_metatile_unlock(geocache_context *ctx, geocache_metatile *mt) {
-   int i;
-      geocache_tileset_tile_unlock(ctx, tile);
  * compute the metatile that should be rendered for the given tile
 static geocache_metatile* _geocache_tileset_metatile_get(geocache_context *ctx, geocache_tile *tile) {
@@ -240,12 +209,13 @@
       ctx->global_lock_aquire(ctx);
       GC_CHECK_ERROR(ctx);
+      mt = _geocache_tileset_metatile_get(ctx, tile);
-      isLocked = geocache_tileset_tile_lock_exists(ctx, tile);
+      isLocked = geocache_tileset_metatile_lock_exists(ctx, mt);
       if(isLocked == GEOCACHE_FALSE) {
-         /* no other thread is doing the rendering, we aquire and lock a list of tiles to render */
-         mt = _geocache_tileset_metatile_get(ctx, tile);
-         _geocache_tileset_metatile_lock(ctx, mt);
+         /* no other thread is doing the rendering, we aquire and lock the metatile */
+         geocache_tileset_metatile_lock(ctx, mt);
       ctx->global_lock_release(ctx);
@@ -257,7 +227,7 @@
          ctx->log(ctx, GEOCACHE_DEBUG, "cache wait: tileset %s - tile %d %d %d",
                tile->tileset->name,tile->x, tile->y,tile->z);
 #endif
-         geocache_tileset_tile_lock_wait(ctx,tile);
+         geocache_tileset_metatile_lock_wait(ctx,mt);
       } else {
          /* no other thread is doing the rendering, do it ourselves */
@@ -270,7 +240,7 @@
          /* remove the lockfiles */
-         _geocache_tileset_metatile_unlock(ctx,mt);
+         geocache_tileset_metatile_unlock(ctx,mt);
