[mapserver-commits] r12293 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:14:29 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:14:29 -0700 (Fri, 26 Aug 2011)
New Revision: 12293
Added:
trunk/mapserver/mapcache/src/service_ve.c
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
refactor grid/map request processing
move core processing out of mod_geocache.c and fastcgi_geocache.c
thomas.bonfort | 2011-02-04 14:43:09 +0100 (Fri, 04 Feb 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:14:23 UTC (rev 12292)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:14:29 UTC (rev 12293)
@@ -466,6 +466,8 @@
<!-- OSGEO TMS -->
<tms>true</tms>
+ <ve>true</ve>
<kml>true</kml>
<!-- OGC WMTS -->
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:14:23 UTC (rev 12292)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:14:29 UTC (rev 12293)
@@ -77,6 +77,7 @@
typedef struct geocache_service_wms geocache_service_wms;
typedef struct geocache_service_wmts geocache_service_wmts;
typedef struct geocache_service_gmaps geocache_service_gmaps;
+typedef struct geocache_service_ve geocache_service_ve;
typedef struct geocache_service_tms geocache_service_tms;
typedef struct geocache_service_kml geocache_service_kml;
typedef struct geocache_service_demo geocache_service_demo;
@@ -361,12 +362,10 @@
struct geocache_request_get_capabilities_wms {
geocache_request_get_capabilities request;
- char *version;
struct geocache_request_get_capabilities_wmts {
- char *version;
@@ -374,11 +373,12 @@
/** \defgroup services Services*/
-#define GEOCACHE_SERVICES_COUNT 6
+#define GEOCACHE_SERVICES_COUNT 7
typedef enum {
GEOCACHE_SERVICE_WMS = 0, GEOCACHE_SERVICE_TMS, GEOCACHE_SERVICE_WMTS,
- GEOCACHE_SERVICE_DEMO, GEOCACHE_SERVICE_GMAPS, GEOCACHE_SERVICE_KML
+ GEOCACHE_SERVICE_DEMO, GEOCACHE_SERVICE_GMAPS, GEOCACHE_SERVICE_KML,
+ GEOCACHE_SERVICE_VE
} geocache_service_type;
#define GEOCACHE_UNITS_COUNT 3
@@ -455,6 +455,14 @@
geocache_service service;
+/**\class geocache_service_ve
+ * \brief a virtualearth service
+ * \implements geocache_service
+struct geocache_service_ve {
+ geocache_service service;
* \brief create and initialize a geocache_service_wms
* \memberof geocache_service_wms
@@ -462,6 +470,12 @@
geocache_service* geocache_service_wms_create(geocache_context *ctx);
+ * \brief create and initialize a geocache_service_ve
+ * \memberof geocache_service_ve
+geocache_service* geocache_service_ve_create(geocache_context *ctx);
* \brief create and initialize a geocache_service_gmaps
* \memberof geocache_service_gmaps
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:14:23 UTC (rev 12292)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:14:29 UTC (rev 12293)
@@ -786,6 +786,11 @@
config->services[GEOCACHE_SERVICE_WMTS] = geocache_service_wmts_create(ctx);
+ if ((node = ezxml_child(root,"ve")) != NULL) {
+ if(!node->txt || !*node->txt || strcmp(node->txt, "false")) {
+ config->services[GEOCACHE_SERVICE_VE] = geocache_service_ve_create(ctx);
if ((node = ezxml_child(root,"tms")) != NULL) {
config->services[GEOCACHE_SERVICE_TMS] = geocache_service_tms_create(ctx);
Added: trunk/mapserver/mapcache/src/service_ve.c
--- trunk/mapserver/mapcache/src/service_ve.c (rev 0)
+++ trunk/mapserver/mapcache/src/service_ve.c 2011-08-26 11:14:29 UTC (rev 12293)
@@ -0,0 +1,142 @@
+ * Copyright 2010 Thomas Bonfort
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#include "geocache.h"
+#include <apr_strings.h>
+#include <math.h>
+/** \addtogroup services */
+void _create_capabilities_ve(geocache_context *ctx, geocache_request_get_capabilities *req, char *url, char *path_info, geocache_cfg *cfg) {
+ ctx->set_error(ctx,501,"ve service does not support capapbilities");
+ * \brief parse a VE request
+ * \private \memberof geocache_service_ve
+ * \sa geocache_service::parse_request()
+void _geocache_service_ve_parse_request(geocache_context *ctx, geocache_service *this, geocache_request **request,
+ const char *cpathinfo, apr_table_t *params, geocache_cfg *config) {
+ const char *layer,*quadkey;
+ geocache_tileset *tileset = NULL;
+ geocache_grid_link *grid_link = NULL;
+ layer = apr_table_get(params,"layer");
+ if(layer) {
+ /*tileset not found directly, test if it was given as "name at grid" notation*/
+ char *tname = apr_pstrdup(ctx->pool,layer);
+ char *gname = tname;
+ int i;
+ while(*gname) {
+ if(*gname == '@') {
+ *gname = '\0';
+ gname++;
+ break;
+ gname++;
+ if(!gname) {
+ ctx->set_error(ctx,404, "received ve request with invalid layer %s", layer);
+ return;
+ tileset = geocache_configuration_get_tileset(config,tname);
+ if(!tileset) {
+ ctx->set_error(ctx,404, "received ve request with invalid layer %s", tname);
+ return;
+ for(i=0;i<tileset->grid_links->nelts;i++) {
+ geocache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
+ if(!strcmp(sgrid->grid->name,gname)) {
+ grid_link = sgrid;
+ break;
+ if(!grid_link) {
+ ctx->set_error(ctx,404, "received ve request with invalid grid %s", gname);
+ return;
+ } else {
+ ctx->set_error(ctx,400,"received ve request with no layer");
+ return;
+ quadkey = apr_table_get(params,"tile");
+ geocache_tile *tile = geocache_tileset_tile_create(ctx->pool,tileset,grid_link);
+ if(quadkey) {
+ int i;
+ tile->z = strlen(quadkey);
+ if(tile->z<1 || tile->z>=grid_link->grid->nlevels) {
+ ctx->set_error(ctx,404,"received ve request with invalid z level %d\n",tile->z);
+ return;
+ tile->x = tile->y = 0;
+ for(i=tile->z; i; i--) {
+ int mask = 1 << (i-1);
+ switch(quadkey[tile->z-i]) {
+ case '0':
+ break;
+ case '1':
+ tile->x |= mask;
+ break;
+ case '2':
+ tile->y |= mask;
+ break;
+ case '3':
+ tile->x |= mask;
+ tile->y |= mask;
+ break;
+ default:
+ ctx->set_error(ctx,404, "Invalid Quadkey sequence");
+ return;
+ } else {
+ ctx->set_error(ctx,400,"received ve request with no tile quadkey");
+ return;
+ geocache_request_get_tile *req = (geocache_request_get_tile*)apr_pcalloc(ctx->pool,sizeof(geocache_request_get_tile));
+ req->request.type = GEOCACHE_REQUEST_GET_TILE;
+ req->ntiles = 1;
+ req->tiles = (geocache_tile**)apr_pcalloc(ctx->pool,sizeof(geocache_tile*));
+ req->tiles[0] = tile;
+ req->tiles[0]->y = grid_link->grid->levels[tile->z]->maxy - tile->y - 1;
+ geocache_tileset_tile_validate(ctx,req->tiles[0]);
+ GC_CHECK_ERROR(ctx);
+ *request = (geocache_request*)req;
+ return;
+geocache_service* geocache_service_ve_create(geocache_context *ctx) {
+ geocache_service_ve* service = (geocache_service_ve*)apr_pcalloc(ctx->pool, sizeof(geocache_service_ve));
+ if(!service) {
+ ctx->set_error(ctx, 500, "failed to allocate ve service");
+ return NULL;
+ service->service.url_prefix = apr_pstrdup(ctx->pool,"ve");
+ service->service.type = GEOCACHE_SERVICE_VE;
+ service->service.parse_request = _geocache_service_ve_parse_request;
+ service->service.create_capabilities_response = _create_capabilities_ve;
+ return (geocache_service*)service;
+/* vim: ai ts=3 sts=3 et sw=3
More information about the mapserver-commits
