[mapserver-commits] r12302 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:15:12 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:15:12 -0700 (Fri, 26 Aug 2011)
New Revision: 12302
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/errors.h
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/imageio_jpeg.c
trunk/mapserver/mapcache/src/imageio_png.c
trunk/mapserver/mapcache/src/mod_geocache.c
add forwarding for full wms
thomas.bonfort | 2011-02-10 08:39:28 +0100 (Thu, 10 Feb 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:15:12 UTC (rev 12302)
@@ -333,7 +333,7 @@
NOTE: when adding a <grid> element, you *MUST* make sure that the source you have selected is able to
return images in the grid's srs.
- <grid>WGS84</grid>
+ <grid restricted_extent="-10 40 10 50">WGS84</grid>
<grid>google</grid>
<!-- metadata
@@ -479,7 +479,7 @@
recommended to use a png format with "fast"compression here, unless you have plenty
of server cpu power and or limited bandwidth
- <merge_format>PNGQ_FAST</merge_format>
+ <merge_format>JPEG</merge_format>
<!-- services
services that will be responded to by mod-geocache
@@ -508,4 +508,16 @@
<demo>true</demo>
</services>
+ <!-- errors
+ configure how error will be reported back to a client:
+ - log : no error is reported back, except an http error code.
+ - report : return the error message to the client in textual format
+ - empty_img : return an empty image to the client. the actual error code is in the X-Geocache-Error http header
+ - report_img : return an image with the error text included inside. not implemented yet.
+ the default setting is to report the error message back to the user. In production, you might want to set this to "log"
+ if you're paranoid, or to "empty_img" if you want to play nice with non-conforming clients.
+ <errors>empty_img</errors>
</geocache>
Modified: trunk/mapserver/mapcache/include/errors.h
--- trunk/mapserver/mapcache/include/errors.h 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/include/errors.h 2011-08-26 11:15:12 UTC (rev 12302)
@@ -27,7 +27,9 @@
typedef enum {
GEOCACHE_REPORT_LOG,
GEOCACHE_REPORT_MSG,
- GEOCACHE_REPORT_IMG
+ GEOCACHE_REPORT_ERROR_IMG,
+ GEOCACHE_REPORT_EMPTY_IMG,
+ GEOCACHE_REPORT_CUSTOM_IMG
} geocache_error_reporting;
#endif /* ERRORS_H_ */
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:15:12 UTC (rev 12302)
@@ -685,6 +685,7 @@
* how should error messages be reported to the user
geocache_error_reporting reporting;
+ geocache_buffer *empty_image;
apr_table_t *metadata;
@@ -1019,6 +1020,9 @@
/**< pointer to a function that returns a geocache_buffer containing the given image encoded
* in the specified format
+ geocache_buffer* (*create_empty_image)(geocache_context *ctx, geocache_image_format *format,
+ size_t width, size_t height, unsigned int color);
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:15:12 UTC (rev 12302)
@@ -840,6 +840,16 @@
+static void createEmptyImages(geocache_context *ctx, geocache_cfg *cfg) {
+ unsigned int color=0;
+ if(!strstr(cfg->merge_format->mime_type,"png")) {
+ color = 0xffffffff;
+ cfg->empty_image = cfg->merge_format->create_empty_image(ctx, cfg->merge_format,
+ 256,256, color);
+ GC_CHECK_ERROR(ctx);
void geocache_configuration_parse(geocache_context *ctx, const char *filename, geocache_cfg *config) {
ezxml_t doc, node;
doc = ezxml_parse_file(filename);
@@ -904,9 +914,31 @@
node->txt);
goto cleanup;
+ config->merge_format = format;
+ if ((node = ezxml_child(doc,"errors")) != NULL) {
+ if(!strcmp(node->txt,"log")) {
+ config->reporting = GEOCACHE_REPORT_LOG;
+ } else if(!strcmp(node->txt,"report")) {
+ config->reporting = GEOCACHE_REPORT_MSG;
+ } else if(!strcmp(node->txt,"empty_img")) {
+ config->reporting = GEOCACHE_REPORT_EMPTY_IMG;
+ createEmptyImages(ctx, config);
+ if(GC_HAS_ERROR(ctx)) goto cleanup;
+ } else if(!strcmp(node->txt, "report_img")) {
+ config->reporting = GEOCACHE_REPORT_ERROR_IMG;
+ ctx->set_error(ctx,501,"<errors>: report_img not implemented");
+ goto cleanup;
+ } else {
+ ctx->set_error(ctx,400,"<errors>: unknown value %s (allowed are log, report, empty_img, report_img)",
+ node->txt);
+ goto cleanup;
cleanup:
ezxml_free(doc);
return;
Modified: trunk/mapserver/mapcache/src/imageio_jpeg.c
--- trunk/mapserver/mapcache/src/imageio_jpeg.c 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/src/imageio_jpeg.c 2011-08-26 11:15:12 UTC (rev 12302)
@@ -252,13 +252,45 @@
+static geocache_buffer* _geocache_imageio_jpg_create_empty(geocache_context *ctx, geocache_image_format *format,
+ size_t width, size_t height, unsigned int color) {
+ geocache_image_format_jpeg *f = (geocache_image_format_jpeg*)format;
+ apr_pool_t *pool = NULL;
+ if(apr_pool_create(&pool,ctx->pool) != APR_SUCCESS) {
+ ctx->set_error(ctx,500,"png create empty: failed to create temp memory pool");
+ return NULL;
+ geocache_image *empty = geocache_image_create(ctx);
+ if(GC_HAS_ERROR(ctx)) {
+ return NULL;
+ empty->data = (unsigned char*)apr_pcalloc(pool,width*height*4*sizeof(unsigned char));
+ int i;
+ for(i=0;i<width*height;i++) {
+ ((unsigned int*)empty->data)[i] = color;
+ empty->w = width;
+ empty->h = height;
+ empty->stride = width * 4;
+ /*temp switch format compression*/
+ int tmpquality = f->quality;
+ f->quality = 1;
+ geocache_buffer *buf = format->write(ctx,empty,format);
+ apr_pool_destroy(pool);
+ f->quality = tmpquality;
+ return buf;
geocache_image_format* geocache_imageio_create_jpeg_format(apr_pool_t *pool, char *name, int quality ) {
geocache_image_format_jpeg *format = apr_pcalloc(pool, sizeof(geocache_image_format_jpeg));
format->format.name = name;
format->format.extension = apr_pstrdup(pool,"jpg");
format->format.mime_type = apr_pstrdup(pool,"image/jpeg");
format->format.metadata = apr_table_make(pool,3);
+ format->format.create_empty_image = _geocache_imageio_jpg_create_empty;
format->format.write = _geocache_imageio_jpeg_encode;
format->quality = quality;
return (geocache_image_format*)format;
Modified: trunk/mapserver/mapcache/src/imageio_png.c
--- trunk/mapserver/mapcache/src/imageio_png.c 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/src/imageio_png.c 2011-08-26 11:15:12 UTC (rev 12302)
@@ -1067,7 +1067,39 @@
return buffer;
+static geocache_buffer* _geocache_imageio_png_create_empty(geocache_context *ctx, geocache_image_format *format,
+ geocache_image_format_png *f = (geocache_image_format_png*)format;
+ return NULL;
+ return NULL;
+ int i;
+ empty->w = width;
+ geocache_compression_type tmpcomp = f->compression_level;
+ f->compression_level = GEOCACHE_COMPRESSION_BEST;
+ f->compression_level = tmpcomp;
+ return buf;
geocache_image_format* geocache_imageio_create_png_format(apr_pool_t *pool, char *name, geocache_compression_type compression) {
geocache_image_format_png *format = apr_pcalloc(pool, sizeof(geocache_image_format_png));
@@ -1076,6 +1108,7 @@
format->compression_level = compression;
format->format.write = _geocache_imageio_png_encode;
+ format->format.create_empty_image = _geocache_imageio_png_create_empty;
@@ -1086,6 +1119,7 @@
format->format.format.mime_type = apr_pstrdup(pool,"image/png");
format->format.compression_level = compression;
format->format.format.write = _geocache_imageio_png_q_encode;
+ format->format.format.create_empty_image = _geocache_imageio_png_create_empty;
format->format.format.metadata = apr_table_make(pool,3);
format->ncolors = ncolors;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:15:06 UTC (rev 12301)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:15:12 UTC (rev 12302)
@@ -68,7 +68,19 @@
ap_set_content_type(apache_ctx->request, "text/plain");
ap_rprintf(apache_ctx->request,"error: %s",msg);
return OK;
- } else {
+ } else if(ctx->config && ctx->config->reporting == GEOCACHE_REPORT_EMPTY_IMG) {
+ if(ctx->config->empty_image) { /*should never fail*/
+ apache_ctx->request->status = code;
+ ap_set_content_length(apache_ctx->request, ctx->config->empty_image->size);
+ apr_table_set(apache_ctx->request->headers_out, "X-Geocache-Error", msg);
+ ap_set_content_type(apache_ctx->request, ctx->config->merge_format->mime_type);
+ ap_rwrite((void*)ctx->config->empty_image->buf, ctx->config->empty_image->size, apache_ctx->request);
+ return OK;
+ } else {
+ return code;
+ else {
return code;
More information about the mapserver-commits
