[mapserver-commits] r12311 - in trunk/mapserver/mapcache: include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:16:01 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:16:01 -0700 (Fri, 26 Aug 2011)
New Revision: 12311
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/grid.c
trunk/mapserver/mapcache/src/service_kml.c
trunk/mapserver/mapcache/src/service_wms.c
trunk/mapserver/mapcache/src/service_wmts.c
trunk/mapserver/mapcache/src/tileset.c
add delete function to memcache cache backend
thomas.bonfort | 2011-02-14 13:30:23 +0100 (Mon, 14 Feb 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:16:01 UTC (rev 12311)
@@ -841,9 +841,9 @@
char *name;
- * the extent of the tileset that can be cached
+ * the extent of the tileset in lonlat
- double restricted_extent[4];
+ double wgs84bbox[4];
* list of grids that will be cached
@@ -881,12 +881,6 @@
geocache_image_format *format;
- * the format to use when storing a tile coming from a source
- * if NULL, store what the source has produced without processing
- geocache_image_format *cache_format;
* a list of parameters that can be forwarded from the client to the geocache_tileset::source
apr_array_header_t *dimensions;
@@ -988,15 +982,7 @@
geocache_tileset* geocache_tileset_create(geocache_context *ctx);
- * \brief compute the bounding box of a tile
- * @param tile the input tile
- * @param bbox the bounding box to populate
-void geocache_tileset_tile_bbox(geocache_tile *tile, double *bbox);
* lock the tile
@@ -1035,6 +1021,8 @@
const char* geocache_grid_get_crs(geocache_context *ctx, geocache_grid *grid);
const char* geocache_grid_get_srs(geocache_context *ctx, geocache_grid *grid);
+void geocache_grid_get_extent(geocache_context *ctx, geocache_grid *grid,
+ int x, int y, int z, double *bbox);
* \brief compute x y value for given lon/lat (dx/dy) and given zoomlevel
* @param ctx
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:16:01 UTC (rev 12311)
@@ -569,6 +569,7 @@
geocache_tileset *tileset = NULL;
ezxml_t cur_node;
char* value;
+ int havewgs84bbox=0;
name = (char*)ezxml_attr(node,"name");
if(!name || !strlen(name)) {
ctx->set_error(ctx, 400, "mandatory attribute \"name\" not found in <tileset>");
@@ -584,6 +585,31 @@
tileset = geocache_tileset_create(ctx);
tileset->name = name;
+ if ((cur_node = ezxml_child(node,"metadata")) != NULL) {
+ parseMetadata(ctx, cur_node, tileset->metadata);
+ GC_CHECK_ERROR(ctx);
+ if ((value = (char*)apr_table_get(tileset->metadata,"wgs84boundingbox")) != NULL) {
+ double *values;
+ int nvalues;
+ value = apr_pstrdup(ctx->pool,value);
+ if(GEOCACHE_SUCCESS != geocache_util_extract_double_list(ctx, value, ' ', &values, &nvalues) ||
+ nvalues != 4) {
+ ctx->set_error(ctx, 400, "failed to parse extent array %s."
+ "(expecting 4 space separated numbers, got %d (%f %f %f %f)"
+ "eg <wgs84bbox>-180 -90 180 90</wgs84bbox>",
+ value,nvalues,values[0],values[1],values[2],values[3]);
+ return;
+ tileset->wgs84bbox[0] = values[0];
+ tileset->wgs84bbox[1] = values[1];
+ tileset->wgs84bbox[2] = values[2];
+ tileset->wgs84bbox[3] = values[3];
+ havewgs84bbox = 1;
for(cur_node = ezxml_child(node,"grid"); cur_node; cur_node = cur_node->next) {
int i;
@@ -603,6 +629,7 @@
for(i=0;i<grid->nlevels;i++) {
gridlink->grid_limits[i] = apr_pcalloc(ctx->pool,4*sizeof(int));
+ double *extent;
restrictedExtent = (char*)ezxml_attr(cur_node,"restricted_extent");
if(restrictedExtent) {
int nvalues;
@@ -615,19 +642,22 @@
restrictedExtent);
return;
- geocache_grid_compute_limits(grid,gridlink->restricted_extent,gridlink->grid_limits);
+ extent = gridlink->restricted_extent;
} else {
- geocache_grid_compute_limits(grid,grid->extent,gridlink->grid_limits);
+ extent = grid->extent;
+ geocache_grid_compute_limits(grid,extent,gridlink->grid_limits);
+ /* compute wgs84 bbox if it wasn't supplied already */
+ if(!havewgs84bbox && !strcasecmp(grid->srs,"epsg:4326")) {
+ tileset->wgs84bbox[0] = extent[0];
+ tileset->wgs84bbox[1] = extent[1];
+ tileset->wgs84bbox[2] = extent[2];
+ tileset->wgs84bbox[3] = extent[3];
APR_ARRAY_PUSH(tileset->grid_links,geocache_grid_link*) = gridlink;
- if ((cur_node = ezxml_child(node,"metadata")) != NULL) {
- parseMetadata(ctx, cur_node, tileset->metadata);
- GC_CHECK_ERROR(ctx);
if ((cur_node = ezxml_child(node,"dimensions")) != NULL) {
parseDimensions(ctx, cur_node, tileset);
@@ -764,6 +794,14 @@
ctx->set_error(ctx, 400, "tileset \"%s\" has no grids configured."
" You must add a <grid> tag.", tileset->name);
return;
+ } else if(!havewgs84bbox) {
+#ifdef USE_PROJ
+ geocache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,0,geocache_grid_link*);
+ double *extent = sgrid->grid->extent;
+ if(sgrid->restricted_extent) {
+ extent = sgrid->restricted_extent;
+#endif
if(!tileset->format && (
Modified: trunk/mapserver/mapcache/src/grid.c
--- trunk/mapserver/mapcache/src/grid.c 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/src/grid.c 2011-08-26 11:16:01 UTC (rev 12311)
@@ -26,6 +26,20 @@
return grid;
+ * \brief compute the extent of a given tile in the grid given its x, y, and z.
+ * \returns \extent the tile's extent
+ int x, int y, int z, double *bbox) {
+ double res = grid->levels[z]->resolution;
+ bbox[0] = grid->extent[0] + (res * x * grid->tile_sx);
+ bbox[1] = grid->extent[1] + (res * y * grid->tile_sy);
+ bbox[2] = grid->extent[0] + (res * (x + 1) * grid->tile_sx);
+ bbox[3] = grid->extent[1] + (res * (y + 1) * grid->tile_sy);
const char* geocache_grid_get_crs(geocache_context *ctx, geocache_grid *grid) {
char *epsgnum;
Modified: trunk/mapserver/mapcache/src/service_kml.c
--- trunk/mapserver/mapcache/src/service_kml.c 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/src/service_kml.c 2011-08-26 11:16:01 UTC (rev 12311)
@@ -32,7 +32,8 @@
request->request.mime_type = apr_pstrdup(ctx->pool,"application/vnd.google-earth.kml+xml");
- geocache_tileset_tile_bbox(request->tile,bbox);
+ geocache_grid_get_extent(ctx,request->tile->grid_link->grid,
+ request->tile->x, request->tile->y, request->tile->z, bbox);
caps = apr_psprintf(ctx->pool,"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n"
@@ -73,7 +74,8 @@
t->x = (request->tile->x << 1) +i;
t->y = (request->tile->y << 1) +j;
t->z = request->tile->z + 1;
- geocache_tileset_tile_bbox(t,bb);
+ geocache_grid_get_extent(ctx,t->grid_link->grid,
+ t->x, t->y, t->z, bb);
caps = apr_psprintf(ctx->pool,"%s"
" <NetworkLink>\n"
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:16:01 UTC (rev 12311)
@@ -176,23 +176,26 @@
dimensions = apr_pstrcat(ctx->pool,dimensions,"</Dimension>\n",NULL);
+ if(tileset->wgs84bbox[0] != tileset->wgs84bbox[2]) {
+ char *wgs84bbox = apr_psprintf(ctx->pool,"<LatLonBoundingBox minx=\"%f\" miny=\"%f\" maxx=\"%f\" maxy=\"%f\"/>\n",
+ tileset->wgs84bbox[0], tileset->wgs84bbox[1],
+ tileset->wgs84bbox[2], tileset->wgs84bbox[3]);
+ srss = apr_pstrcat(ctx->pool,srss,wgs84bbox,NULL);
for(i=0;i<tileset->grid_links->nelts;i++) {
- geocache_grid *grid = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*)->grid;
+ geocache_grid_link *gridlink = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
+ double *extent = gridlink->grid->extent;
+ if(gridlink->restricted_extent)
char *bbox = apr_psprintf(ctx->pool,wms_bbox,
- grid->srs,
- grid->extent[0],
- grid->extent[1],
- grid->extent[2],
- grid->extent[3],
- grid->srs);
+ gridlink->grid->srs,
+ extent[0],
+ extent[1],
+ extent[2],
+ extent[3],
+ gridlink->grid->srs);
srss = apr_pstrcat(ctx->pool,srss,bbox,NULL);
- if(!strcasecmp(grid->srs,"epsg:4326")) {
- char *wgs84bbox = apr_psprintf(ctx->pool,"<LatLonBoundingBox minx=\"%f\" miny=\"%f\" maxx=\"%f\" maxy=\"%f\"/>",
- grid->extent[0], grid->extent[1],
- grid->extent[2], grid->extent[3]);
- srss = apr_pstrcat(ctx->pool,srss,wgs84bbox,NULL);
char *layercaps = apr_psprintf(ctx->pool,wms_layer,
tileset->name,
Modified: trunk/mapserver/mapcache/src/service_wmts.c
--- trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:16:01 UTC (rev 12311)
@@ -157,6 +157,16 @@
char *tmsets = "";
char *bboxes = "";
+ bboxes = apr_psprintf(ctx->pool,
+ " <ows:WGS84BoundingBox>\n"
+ " <ows:LowerCorner>%f %f</ows:LowerCorner>\n"
+ " <ows:UpperCorner>%f %f</ows:UpperCorner>\n"
+ " </ows:WGS84BoundingBox>\n",
char *matrixlimits = "";
geocache_grid_link *grid_link = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:15:54 UTC (rev 12310)
+++ trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:16:01 UTC (rev 12311)
@@ -101,7 +101,8 @@
for(i=0;i<ntiles;i++) {
geocache_tile *tile = tiles[i];
double tileresolution = tile->grid_link->grid->levels[tile->z]->resolution;
- geocache_tileset_tile_bbox(tile,tilebbox);
+ geocache_grid_get_extent(ctx,tile->grid_link->grid,
+ tile->x, tile->y, tile->z, tilebbox);
geocache_image *im = geocache_imageio_decode(ctx,tile->data);
cairo_surface_t* srcsurface= cairo_image_surface_create_for_data(im->data, CAIRO_FORMAT_ARGB32,
im->w, im->h,im->stride);
@@ -198,16 +199,6 @@
- * compute the bounding box of a given tile
-void geocache_tileset_tile_bbox(geocache_tile *tile, double *bbox) {
- double res = tile->grid_link->grid->levels[tile->z]->resolution;
- bbox[0] = tile->grid_link->grid->extent[0] + (res * tile->x * tile->grid_link->grid->tile_sx);
- bbox[1] = tile->grid_link->grid->extent[1] + (res * tile->y * tile->grid_link->grid->tile_sy);
- bbox[2] = tile->grid_link->grid->extent[0] + (res * (tile->x + 1) * tile->grid_link->grid->tile_sx);
- bbox[3] = tile->grid_link->grid->extent[1] + (res * (tile->y + 1) * tile->grid_link->grid->tile_sy);
* allocate and initialize a new tileset
More information about the mapserver-commits
