[mapserver-commits] r12332 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:17:33 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:17:33 -0700 (Fri, 26 Aug 2011)
New Revision: 12332
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/grid.c
trunk/mapserver/mapcache/src/service_wms.c
fix computation of matrixset topleftcorner
closes issue 60.
thomas.bonfort | 2011-03-08 14:43:25 +0100 (Tue, 08 Mar 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:17:27 UTC (rev 12331)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:17:33 UTC (rev 12332)
@@ -29,11 +29,20 @@
the spatial reference this tileset is in. a WMS client will need this for
- getMap requests.
+ getMap requests. This is the srs that will be sent to the WMS source during
+ a request, make sure that this srs is supported by the wms.
<srs>epsg:4326</srs>
+ equivalent values for the SRS that can be requested by a client.
+ this value is essentially here to be able to support:
+ - epsg:900913 and epsg:3857 for the googleMapsCompatible gridset
+ - epsg:2154 and IGNF:LAMB93
+ <srsalias>epsg:foobar</srsalias>
width and height of tiles. 256x256 is the usual size
<size>256 256</size>
@@ -87,38 +96,6 @@
</grid>
<grid>
- <name>google</name>
- <metadata>
- <title>GoogleMapsCompatible</title>
- <WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
- </metadata>
- <extent>-20037508.3427892480,-20037508.3427892480,20037508.3427892480,20037508.3427892480</extent>
- <srs>epsg:900913</srs>
- <size>256 256</size>
- <resolutions>
- 156543.0339280410
- 78271.51696402048
- 39135.75848201023
- 19567.87924100512
- 9783.939620502561
- 4891.969810251280
- 2445.984905125640
- 1222.992452562820
- 611.4962262814100
- 305.7481131407048
- 152.8740565703525
- 76.43702828517624
- 38.21851414258813
- 19.10925707129406
- 9.554628535647032
- 4.777314267823516
- 2.388657133911758
- 1.194328566955879
- 0.5971642834779395
- </resolutions>
- </grid>
- <grid>
<name>GoogleMapsCompatible</name>
<metadata>
@@ -126,6 +103,7 @@
</metadata>
<srs>epsg:3857</srs>
+ <srsalias>epsg:900913</srsalias>
<resolutions>
156543.0339280410
@@ -296,7 +274,7 @@
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>default</LAYERS>
- <MAP>/Users/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
+ <MAP>/home/tbonfort/dev/mapserver-utils/osm-mapserver.map</MAP>
</params>
</getmap>
</source>
@@ -362,7 +340,7 @@
return images in the grid's srs.
<grid restricted_extent="-10 40 10 50">WGS84</grid>
- <grid>google</grid>
+ <grid>GoogleMapsCompatible</grid>
<!-- metadata
optional metadata tags used for responding to GetCapabilities request.
@@ -483,7 +461,7 @@
<cache>disk</cache>
<format>PNG</format>
<grid>WGS84</grid>
<metatile>5 5</metatile>
<metabuffer>10</metabuffer>
</tileset>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:17:27 UTC (rev 12331)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:17:33 UTC (rev 12332)
@@ -854,6 +854,7 @@
char *name;
int nlevels;
char *srs;
+ apr_array_header_t *srs_aliases;
double extent[4];
geocache_unit unit;
int tile_sx, tile_sy; /**<width and height of a tile in pixels */
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:17:27 UTC (rev 12331)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:17:33 UTC (rev 12332)
@@ -121,6 +121,7 @@
grid = geocache_grid_create(pool);
grid->name = apr_pstrdup(pool,"GoogleMapsCompatible");
grid->srs = apr_pstrdup(pool,"epsg:3857");
+ APR_ARRAY_PUSH(grid->srs_aliases,char*) = apr_pstrdup(pool,"epsg:900913");
apr_table_add(grid->metadata,"title","GoogleMapsCompatible");
apr_table_add(grid->metadata,"profile","global-mercator");
apr_table_add(grid->metadata,"wellKnownScaleSet","urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible");
@@ -140,28 +141,6 @@
geocache_configuration_add_grid(cfg,grid,"GoogleMapsCompatible");
- grid = geocache_grid_create(pool);
- grid->name = apr_pstrdup(pool,"google");
- grid->srs = apr_pstrdup(pool,"epsg:900913");
- apr_table_add(grid->metadata,"profile","global-mercator");
- apr_table_add(grid->metadata,"title","GoogleMapsCompatible");
- apr_table_add(grid->metadata,"wellKnownScaleSet","urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible");
- grid->tile_sx = grid->tile_sy = 256;
- grid->nlevels = 19;
- grid->extent[0] = google_extent[0];
- grid->extent[1] = google_extent[1];
- grid->extent[2] = google_extent[2];
- grid->extent[3] = google_extent[3];
- grid->unit = GEOCACHE_UNIT_METERS;
- grid->levels = (geocache_grid_level**)apr_pcalloc(pool,
- grid->nlevels*sizeof(geocache_grid_level*));
- for(i=0; i<grid->nlevels; i++) {
- geocache_grid_level *level = (geocache_grid_level*)apr_pcalloc(pool,sizeof(geocache_grid_level));
- level->resolution = google_resolutions[i];
- grid->levels[i] = level;
- geocache_configuration_add_grid(cfg,grid,"google");
return cfg;
@@ -323,6 +302,11 @@
if ((cur_node = ezxml_child(node,"srs")) != NULL) {
grid->srs = apr_pstrdup(ctx->pool,cur_node->txt);
+ for(cur_node = ezxml_child(node,"srsalias"); cur_node; cur_node = cur_node->next) {
+ value = apr_pstrdup(ctx->pool,cur_node->txt);
+ APR_ARRAY_PUSH(grid->srs_aliases,char*) = value;
if ((cur_node = ezxml_child(node,"size")) != NULL) {
Modified: trunk/mapserver/mapcache/src/grid.c
--- trunk/mapserver/mapcache/src/grid.c 2011-08-26 11:17:27 UTC (rev 12331)
+++ trunk/mapserver/mapcache/src/grid.c 2011-08-26 11:17:33 UTC (rev 12332)
@@ -23,6 +23,7 @@
geocache_grid* geocache_grid_create(apr_pool_t *pool) {
geocache_grid* grid = (geocache_grid*)apr_pcalloc(pool, sizeof(geocache_grid));
grid->metadata = apr_table_make(pool,3);
+ grid->srs_aliases = apr_array_make(pool,0,sizeof(char*));
return grid;
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:17:27 UTC (rev 12331)
+++ trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:17:33 UTC (rev 12332)
@@ -347,7 +347,17 @@
geocache_grid_link *grid_link = NULL;
for(i=0;i<tileset->grid_links->nelts;i++){
geocache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
- if(strcasecmp(sgrid->grid->srs,srs)) continue;
+ /* look for a grid with a matching srs */
+ if(strcasecmp(sgrid->grid->srs,srs)) {
+ /* look if the grid has some srs aliases */
+ int s;
+ for(s=0;s<sgrid->grid->srs_aliases->nelts;s++) {
+ char *srsalias = APR_ARRAY_IDX(sgrid->grid->srs_aliases,s,char*);
+ if(!strcasecmp(srsalias,srs)) break;
+ if(s==sgrid->grid->srs_aliases->nelts)
+ continue; /* no srs alias matches the requested srs */
grid_link = sgrid;
break;
More information about the mapserver-commits
