[mapserver-commits] r12338 - in trunk/mapserver/mapcache: . src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:18:00 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:18:00 -0700 (Fri, 26 Aug 2011)
New Revision: 12338
trunk/mapserver/mapcache/configure.in
trunk/mapserver/mapcache/src/mod_geocache.c
add missing file
thomas.bonfort | 2011-03-11 17:01:42 +0100 (Fri, 11 Mar 2011)
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2011-08-26 11:17:55 UTC (rev 12337)
+++ trunk/mapserver/mapcache/configure.in 2011-08-26 11:18:00 UTC (rev 12338)
@@ -578,6 +578,14 @@
LOCKMECH_CHECK
+AC_ARG_ENABLE(version_string,
+ AC_HELP_STRING([--enable-version-string],[add mod-geocache version string to the apache server header]),
+ [enable_version_string=yes]
+if test "$enable_version_string" != "yes"; then
+ MISC_ENABLED="-DDISABLE_VERSION_STRING $MISC_ENABLED"
+fi
AC_ARG_ENABLE(module,
AC_HELP_STRING([--enable-module],[Enable apache module building]),
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:17:55 UTC (rev 12337)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:18:00 UTC (rev 12338)
@@ -338,6 +338,9 @@
#endif
apr_pool_cleanup_register(p,cfg->mutex,
(void*)apr_global_mutex_destroy, apr_pool_cleanup_null);
+#ifndef DISABLE_VERSION_STRING
+ ap_add_version_component(p, GEOCACHE_USERAGENT);
+#endif
return OK;
More information about the mapserver-commits
