[mapserver-commits] r12345 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:18:30 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:18:30 -0700 (Fri, 26 Aug 2011)
New Revision: 12345
trunk/mapserver/mapcache/src/service_wmts.c
Integrated changes for the demo service to display maps using OpenLayers
for services wms, tms, wmts, and ve.
imaptools at gmail.com | 2011-03-31 21:06:57 +0200 (Thu, 31 Mar 2011)
Modified: trunk/mapserver/mapcache/src/service_wmts.c
--- trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:18:26 UTC (rev 12344)
+++ trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:18:30 UTC (rev 12345)
@@ -17,75 +17,56 @@
#include "geocache.h"
#include <apr_strings.h>
#include <math.h>
+#include "ezxml.h"
/** \addtogroup services */
-static const char *wmts_0 =
- "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n"
- "<Capabilities xmlns=\"http://www.opengis.net/wmts/1.0\"\n"
- "xmlns:ows=\"http://www.opengis.net/ows/1.1\"\n"
- "xmlns:xlink=\"http://www.w3.org/1999/xlink\"\n"
- "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"\n"
- "xmlns:gml=\"http://www.opengis.net/gml\" xsi:schemaLocation=\"http://www.opengis.net/wmts/1.0 http://schemas.opengis.net/wmts/1.0/wmtsGetCapabilities_response.xsd\"\n"
- "version=\"1.0.0\">\n"
- "<ows:ServiceIdentification>\n"
- " <ows:Title>%s</ows:Title>\n"
- " <ows:ServiceType>OGC WMTS</ows:ServiceType>\n"
- " <ows:ServiceTypeVersion>1.0.0</ows:ServiceTypeVersion>\n"
- "</ows:ServiceIdentification>\n"
- "<ows:ServiceProvider>\n"
- " <ows:ProviderName>%s</ows:ProviderName>\n"
- " <ows:ProviderSite xlink:href=\"%s/wmts?\" />\n"
- " <ows:ServiceContact>\n"
- " <ows:IndividualName>%s</ows:IndividualName>\n"
- " </ows:ServiceContact>\n"
- "</ows:ServiceProvider>\n"
- "<ows:OperationsMetadata>\n"
- " <ows:Operation name=\"GetCapabilities\">\n"
- " <ows:DCP>\n"
- " <ows:HTTP>\n"
- " <ows:Get xlink:href=\"%s/wmts?\">\n"
- " <ows:Constraint name=\"GetEncoding\">\n"
- " <ows:AllowedValues>\n"
- " <ows:Value>KVP</ows:Value>\n"
- " </ows:AllowedValues>\n"
- " </ows:Constraint>\n"
- " </ows:Get>\n"
- " </ows:HTTP>\n"
- " </ows:DCP>\n"
- " </ows:Operation>\n"
- " <ows:Operation name=\"GetTile\">\n"
- " <ows:DCP>\n"
- " <ows:HTTP>\n"
- " </ows:Get>\n"
- " </ows:HTTP>\n"
- " </ows:DCP>\n"
- " <ows:Operation name=\"GetFeatureInfo\">\n"
- " <ows:DCP>\n"
- " <ows:HTTP>\n"
- " </ows:Get>\n"
- " </ows:HTTP>\n"
- " </ows:DCP>\n"
- "</ows:OperationsMetadata>\n"
- "<Contents>\n";
+static ezxml_t _wmts_capabilities() {
+ ezxml_t node = ezxml_new("Capabilities");
+ ezxml_set_attr(node,"xmlns","http://www.opengis.net/wmts/1.0");
+ ezxml_set_attr(node,"xmlns:ows","http://www.opengis.net/ows/1.1");
+ ezxml_set_attr(node,"xmlns:xlink","http://www.w3.org/1999/xlink");
+ ezxml_set_attr(node,"xmlns:xsi","http://www.w3.org/2001/XMLSchema-instance");
+ ezxml_set_attr(node,"xmlns:gml","http://www.opengis.net/gml");
+ ezxml_set_attr(node,"xsi:schemaLocation","http://www.opengis.net/wmts/1.0 http://schemas.opengis.net/wmts/1.0/wmtsGetCapabilities_response.xsd");
+ ezxml_set_attr(node,"version","1.0.0");
+ return node;
+static ezxml_t _wmts_service_identification(geocache_context *ctx, const char *title) {
+ ezxml_t node = ezxml_new("ows:ServiceIdentification");
+ ezxml_set_txt(ezxml_add_child(node,"ows:Title",0),title);
+ ezxml_set_txt(ezxml_add_child(node,"ows:ServiceType",0),"OGC WMTS");
+ ezxml_set_txt(ezxml_add_child(node,"ows:ServiceTypeVersion",0),"1.0.0");
+ return node;
+static ezxml_t _wmts_operations_metadata(geocache_context *ctx, const char *onlineresource, const char *operationstr) {
+ ezxml_t node = ezxml_new("ows:OperationsMetadata");
+ ezxml_t operation = ezxml_add_child(node,"ows:Operation",0);
+ ezxml_set_attr(operation,"name",operationstr);
+ ezxml_t dcp = ezxml_add_child(operation,"ows:DCP",0);
+ ezxml_t http = ezxml_add_child(dcp,"ows:HTTP",0);
+ ezxml_t get = ezxml_add_child(http,"ows:Get",0);
+ ezxml_set_attr(get,"xlink:href",apr_pstrcat(ctx->pool,onlineresource,"/wmts?",NULL));
+ ezxml_t constraint = ezxml_add_child(get,"ows:Constraint",0);
+ ezxml_set_attr(constraint,"name","GetEncoding");
+ ezxml_t allowedvalues = ezxml_add_child(constraint,"ows:AllowedValues",0);
+ ezxml_set_txt(ezxml_add_child(allowedvalues,"ows:Value",0),"KVP");
+ return node;
+static ezxml_t _wmts_service_provider(geocache_context *ctx, const char *onlineresource, const char *contact) {
+ ezxml_t node = ezxml_new("ows:ServiceProvider");
+ ezxml_set_txt(ezxml_add_child(node,"ProviderName",0),contact);
+ ezxml_set_txt(ezxml_add_child(node,"ProviderSite",0),onlineresource);
+ return node;
static const char *wmts_matrix =
" <TileMatrix>\n"
" <ows:Identifier>%d</ows:Identifier>\n"
@@ -99,7 +80,7 @@
void _create_capabilities_wmts(geocache_context *ctx, geocache_request_get_capabilities *req, char *url, char *path_info, geocache_cfg *cfg) {
geocache_request_get_capabilities_wmts *request = (geocache_request_get_capabilities_wmts*)req;
- char *caps;
+ ezxml_t caps;
#ifdef DEBUG
if(request->request.request.type != GEOCACHE_REQUEST_GET_CAPABILITIES) {
ctx->set_error(ctx,500,"wrong wmts capabilities request");
@@ -120,11 +101,14 @@
request->request.mime_type = apr_pstrdup(ctx->pool,"application/xml");
- caps = apr_psprintf(ctx->pool,wmts_0,
- title, "providername_todo", onlineresource, "individualname_todo",
- onlineresource,onlineresource,onlineresource,onlineresource);
+ caps = _wmts_capabilities();
+ ezxml_insert(_wmts_service_identification(ctx,title),caps,0);
+ ezxml_insert(_wmts_service_provider(ctx,onlineresource,"contact_todo"),caps,0);
+ ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetCapabilities"),caps,0);
+ ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetTile"),caps,0);
+ ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetFeatureInfo"),caps,0);
apr_hash_index_t *layer_index = apr_hash_first(ctx->pool,cfg->tilesets);
while(layer_index) {
int i;
@@ -132,139 +116,115 @@
const void *key; apr_ssize_t keylen;
apr_hash_this(layer_index,&key,&keylen,(void**)&tileset);
+ ezxml_t layer = ezxml_add_child(caps,"Layer",0);
const char *title = apr_table_get(tileset->metadata,"title");
- if(!title) {
- title = "no title set, add some in metadata";
+ if(title) {
+ ezxml_set_txt(ezxml_add_child(layer,"ows:Title",0),title);
const char *abstract = apr_table_get(tileset->metadata,"abstract");
- if(!abstract) {
- abstract = "no abstract set, add some in metadata";
+ if(abstract) {
+ ezxml_set_txt(ezxml_add_child(layer,"ows:Abstract",0),abstract);
- char *dimensions="";
+ ezxml_set_txt(ezxml_add_child(layer,"ows:Identifier",0),tileset->name);
+ ezxml_t style = ezxml_add_child(layer,"Style",0);
+ ezxml_set_attr(style,"isDefault","true");
+ ezxml_set_txt(ezxml_add_child(style,"ows:Identifier",0),"default");
+ ezxml_set_txt(ezxml_add_child(layer,"Format",0),tileset->format->mime_type);
char *dimensionstemplate="";
if(tileset->dimensions) {
for(i=0;i<tileset->dimensions->nelts;i++) {
geocache_dimension *dimension = APR_ARRAY_IDX(tileset->dimensions,i,geocache_dimension*);
- dimensions = apr_psprintf(ctx->pool,"%s"
- " <Dimension>\n"
- " <ows:Identifier>%s</ows:Identifier>\n"
- " <Default>%s</Default>\n",
- dimensions,
- dimension->name,
- dimension->default_value);
+ ezxml_t dim = ezxml_add_child(layer,"Dimension",0);
+ ezxml_set_txt(ezxml_add_child(dim,"ows:Identifier",0),dimension->name);
+ ezxml_set_txt(ezxml_add_child(dim,"Default",0),dimension->default_value);
if(dimension->unit) {
- dimensions = apr_pstrcat(ctx->pool,dimensions,
- " <UOM>",dimension->unit,"</UOM>\n",NULL);
+ ezxml_set_txt(ezxml_add_child(dim,"UOM",0),dimension->unit);
const char **values = dimension->print_ogc_formatted_values(ctx,dimension);
const char **value = values;
while(*value) {
- dimensions = apr_pstrcat(ctx->pool,dimensions," <Value>",*value,"</Value>\n",NULL);
+ ezxml_set_txt(ezxml_add_child(dim,"Value",0),*value);
value++;
- dimensions = apr_pstrcat(ctx->pool,dimensions," </Dimension>\n",NULL);
dimensionstemplate = apr_pstrcat(ctx->pool,dimensionstemplate,"{",dimension->name,"}/",NULL);
- char *tmsets = "";
- char *bboxes = "";
- char *infoformats = "";
+ if(tileset->source->info_formats) {
+ int i;
+ for(i=0;i<tileset->source->info_formats->nelts;i++) {
+ char *iformat = APR_ARRAY_IDX(tileset->source->info_formats,i,char*);
+ ezxml_set_txt(ezxml_add_child(layer,"InfoFormat",0),iformat);
+ ezxml_t resourceurl = ezxml_add_child(layer,"ResourceURL",0);
+ ezxml_set_attr(resourceurl,"format",iformat);
+ ezxml_set_attr(resourceurl,"resourcetype","FeatureInfo");
+ ezxml_set_attr(resourceurl,"template",
+ apr_pstrcat(ctx->pool,onlineresource,"/wmts/1.0.0/",tileset->name,"/default/",
+ dimensionstemplate,"{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.",apr_psprintf(ctx->pool,"%d",i),NULL));
+ ezxml_set_attr(resourceurl,"format",tileset->format->mime_type);
+ ezxml_set_attr(resourceurl,"resourceType","tile");
+ dimensionstemplate,"{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.",tileset->format->extension,NULL));
if(tileset->wgs84bbox[0] != tileset->wgs84bbox[2]) {
- bboxes = apr_psprintf(ctx->pool,
- " <ows:WGS84BoundingBox>\n"
- " <ows:LowerCorner>%f %f</ows:LowerCorner>\n"
- " <ows:UpperCorner>%f %f</ows:UpperCorner>\n"
- " </ows:WGS84BoundingBox>\n",
- tileset->wgs84bbox[0], tileset->wgs84bbox[1],
- tileset->wgs84bbox[2], tileset->wgs84bbox[3]);
+ ezxml_t bbox = ezxml_add_child(layer,"ows:WGS84BoundingBox",0);
+ ezxml_set_txt(ezxml_add_child(bbox,"ows:LowerCorner",0),
+ apr_psprintf(ctx->pool,"%f %f",tileset->wgs84bbox[0], tileset->wgs84bbox[1]));
+ ezxml_set_txt(ezxml_add_child(bbox,"ows:UpperCorner",0),
+ apr_psprintf(ctx->pool,"%f %f",tileset->wgs84bbox[2], tileset->wgs84bbox[3]));
for(i=0;i<tileset->grid_links->nelts;i++) {
- char *matrixlimits = "";
geocache_grid_link *grid_link = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
+ ezxml_t tmsetlnk = ezxml_add_child(layer,"TileMatrixSetLink",0);
+ ezxml_set_txt(ezxml_add_child(tmsetlnk,"TileMatrixSet",0),grid_link->grid->name);
if(grid_link->restricted_extent) {
+ ezxml_t limits = ezxml_add_child(tmsetlnk,"TileMatrixSetLimits",0);
int j;
- matrixlimits = " <TileMatrixSetLimits>";
for(j=0;j<grid_link->grid->nlevels;j++) {
- matrixlimits = apr_psprintf(ctx->pool,"%s\n"
- " <TileMatrixLimits>\n"
- " <TileMatrix>%s:%d</TileMatrix>\n"
- " <MinTileRow>%d</MinTileRow>\n"
- " <MaxTileRow>%d</MaxTileRow>\n"
- " <MinTileCol>%d</MinTileCol>\n"
- " <MaxTileCol>%d</MaxTileCol>\n"
- " </TileMatrixLimits>",
- matrixlimits,
- grid_link->grid->name,j,
- grid_link->grid_limits[j][0],
- grid_link->grid_limits[j][2]-1,
- grid_link->grid_limits[j][1],
- grid_link->grid_limits[j][3]-1);
+ ezxml_t matrixlimits = ezxml_add_child(limits,"TileMatrixLimits",0);
+ ezxml_set_txt(ezxml_add_child(matrixlimits,"TileMatrix",0),
+ apr_psprintf(ctx->pool,"%s:%d",grid_link->grid->name,j));
+ ezxml_set_txt(ezxml_add_child(matrixlimits,"MinTileRow",0),
+ apr_psprintf(ctx->pool,"%d",grid_link->grid_limits[j][0]));
+ ezxml_set_txt(ezxml_add_child(matrixlimits,"MaxTileRow",0),
+ apr_psprintf(ctx->pool,"%d",grid_link->grid_limits[j][2]-1));
+ ezxml_set_txt(ezxml_add_child(matrixlimits,"MinTileCol",0),
+ apr_psprintf(ctx->pool,"%d",grid_link->grid_limits[j][1]));
+ ezxml_set_txt(ezxml_add_child(matrixlimits,"MaxTileCol",0),
+ apr_psprintf(ctx->pool,"%d",grid_link->grid_limits[j][3]-1));
- matrixlimits = apr_pstrcat(ctx->pool,matrixlimits,"\n </TileMatrixSetLimits>\n",NULL);
- tmsets = apr_pstrcat(ctx->pool,tmsets,
- " <TileMatrixSetLink>\n"
- " <TileMatrixSet>",
- "</TileMatrixSet>\n",
- matrixlimits,
- " </TileMatrixSetLink>\n",
- NULL);
- double *bbox = grid_link->restricted_extent?grid_link->restricted_extent:grid_link->grid->extent;
- bboxes = apr_psprintf(ctx->pool,"%s"
- " <ows:BoundingBox>\n"
- " <ows:CRS>%s</ows:CRS>\n"
- " </ows:BoundingBox>\n",
- bboxes,
- geocache_grid_get_crs(ctx,grid_link->grid),
- bbox[0],bbox[1],
- bbox[2],bbox[3]);
- if(tileset->source->info_formats) {
- int i;
- for(i=0;i<tileset->source->info_formats->nelts;i++) {
- char *iformat = APR_ARRAY_IDX(tileset->source->info_formats,i,char*);
- infoformats = apr_psprintf(ctx->pool,"%s"
- " <InfoFormat>%s</InfoFormat>\n"
- " <ResourceURL format=\"%s\" resourceType=\"FeatureInfo\""
- " template=\"%s/wmts/1.0.0/%s/default/%s{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}/{J}/{I}.%d\"/>\n",
- infoformats,iformat,iformat,onlineresource,tileset->name,dimensionstemplate,i);
+ double *gbbox = grid_link->restricted_extent?grid_link->restricted_extent:grid_link->grid->extent;
+ ezxml_t bbox = ezxml_add_child(layer,"ows:BoundingBox",0);
+ ezxml_set_txt(ezxml_add_child(bbox,"ows:CRS",0),geocache_grid_get_crs(ctx,grid_link->grid));
+ apr_psprintf(ctx->pool,"%f %f",gbbox[0], gbbox[1]));
+ apr_psprintf(ctx->pool,"%f %f",gbbox[2], gbbox[3]));
- caps = apr_psprintf(ctx->pool,"%s"
- " <Layer>\n"
- " <ows:Abstract>%s</ows:Abstract>\n"
- " <Style isDefault=\"true\">\n"
- " <ows:Identifier>default</ows:Identifier>\n"
- " </Style>\n"
- "%s" /*dimensions*/
- " <Format>%s</Format>\n"
- "%s" /*infoFormats*/
- "%s" /*TileMatrixsetLinks*/
- "%s" /*BoundinBoxes*/
- " <ResourceURL format=\"%s\" resourceType=\"tile\""
- " template=\"%s/wmts/1.0.0/%s/default/%s{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.%s\"/>\n"
- " </Layer>\n",caps,title,abstract,
- tileset->name,dimensions,tileset->format->mime_type,infoformats,tmsets,bboxes,
- tileset->format->mime_type,onlineresource,
- tileset->name, dimensionstemplate,tileset->format->extension);
layer_index = apr_hash_next(layer_index);
apr_hash_index_t *grid_index = apr_hash_first(ctx->pool,cfg->grids);
- while(grid_index) {
+ while(0 && grid_index) {
geocache_grid *grid;
char *epsgnum;
@@ -273,7 +233,6 @@
const char *WellKnownScaleSet;
apr_hash_this(grid_index,&key,&keylen,(void**)&grid);
- /*locate the number after epsg: in the grd srs*/
epsgnum = strchr(grid->srs,':');
if(!epsgnum) {
epsgnum = grid->srs;
@@ -308,9 +267,11 @@
caps = apr_pstrcat(ctx->pool,caps," </TileMatrixSet>\n",NULL);
grid_index = apr_hash_next(grid_index);
- caps = apr_pstrcat(ctx->pool,caps,"</Contents>\n</Capabilities>\n",NULL);
- request->request.capabilities = caps;
+ char *tmpcaps = ezxml_toxml(caps);
+ ezxml_free(caps);
+ request->request.capabilities = apr_pstrdup(ctx->pool,tmpcaps);
+ free(tmpcaps);
More information about the mapserver-commits
