[mapserver-commits] r12354 - trunk/mapserver/mapcache/src
Fri Aug 26 07:19:10 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:19:10 -0700 (Fri, 26 Aug 2011)
New Revision: 12354
Added:
   trunk/mapserver/mapcache/src/imageio_mixed.c
use uppercase EPSG instead of epsg (was failing in qgis parser)
thomas.bonfort | 2011-04-26 16:26:21 +0200 (Tue, 26 Apr 2011)
Added: trunk/mapserver/mapcache/src/imageio_mixed.c
--- trunk/mapserver/mapcache/src/imageio_mixed.c	                        (rev 0)
+++ trunk/mapserver/mapcache/src/imageio_mixed.c	2011-08-26 11:19:10 UTC (rev 12354)
@@ -0,0 +1,59 @@
+ *  Copyright 2010 Thomas Bonfort
+ *  Licensed under the Apache License, Version 2.0 (the "License");
+ *  you may not use this file except in compliance with the License.
+ *  You may obtain a copy of the License at
+ *      http://www.apache.org/licenses/LICENSE-2.0
+ *  Unless required by applicable law or agreed to in writing, software
+ *  distributed under the License is distributed on an "AS IS" BASIS,
+ *  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ *  See the License for the specific language governing permissions and
+ *  limitations under the License.
+#include "geocache.h"
+#include <apr_strings.h>
+/**\addtogroup imageio_mixed */
+ * \brief encode an image to mixed format
+ * depending on the transparency of the provided image, use either one
+ * of the two member encoding formats.
+ * Intended to be used for creating png when transparency is present, and jpeg
+ * when fully opaque
+ * \sa geocache_image_format::write()
+static geocache_buffer* _geocache_imageio_mixed_encode( geocache_context *ctx,
+      geocache_image *image, geocache_image_format *format) {
+   geocache_image_format_mixed *f = (geocache_image_format_mixed*)format;
+   if(geocache_image_has_alpha(image)) {
+      return f->transparent->write(ctx,image,f->transparent);
+   } else {
+      return f->opaque->write(ctx,image,f->opaque);
+geocache_image_format* geocache_imageio_create_mixed_format(apr_pool_t *pool,
+      char *name, geocache_image_format *transparent, geocache_image_format *opaque) {
+   geocache_image_format_mixed *format = apr_pcalloc(pool, sizeof(geocache_image_format_mixed));
+   format->format.name = name;
+   format->transparent = transparent;
+   format->opaque = opaque;
+   format->format.extension = apr_pstrdup(pool,"xxx");
+   format->format.mime_type = NULL;
+   format->format.write = _geocache_imageio_mixed_encode;
+   format->format.create_empty_image = transparent->create_empty_image;
+   format->format.metadata = apr_table_make(pool,3);
+   return (geocache_image_format*)format;
+/* vim: ai ts=3 sts=3 et sw=3
