[mapserver-commits] r12357 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:19:24 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:19:23 -0700 (Fri, 26 Aug 2011)
New Revision: 12357
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/grid.c
trunk/mapserver/mapcache/src/service_demo.c
fix tms tileset href
closes issue 75.
thomas.bonfort | 2011-05-01 17:04:27 +0200 (Sun, 01 May 2011)
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:19:18 UTC (rev 12356)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:19:23 UTC (rev 12357)
@@ -299,6 +299,19 @@
GC_CHECK_ERROR(ctx);
+ if ((cur_node = ezxml_child(node,"units")) != NULL) {
+ if(!strcasecmp(cur_node->txt,"dd")) {
+ grid->unit = GEOCACHE_UNIT_DEGREES;
+ } else if(!strcasecmp(cur_node->txt,"m")) {
+ grid->unit = GEOCACHE_UNIT_METERS;
+ } else if(!strcasecmp(cur_node->txt,"ft")) {
+ grid->unit = GEOCACHE_UNIT_FEET;
+ } else {
+ ctx->set_error(ctx, 400, "unknown unit %s for grid %s (valid values are \"dd\", \"m\", and \"ft\"",
+ cur_node->txt, grid->name);
+ return;
if ((cur_node = ezxml_child(node,"srs")) != NULL) {
grid->srs = apr_pstrdup(ctx->pool,cur_node->txt);
Modified: trunk/mapserver/mapcache/src/grid.c
--- trunk/mapserver/mapcache/src/grid.c 2011-08-26 11:19:18 UTC (rev 12356)
+++ trunk/mapserver/mapcache/src/grid.c 2011-08-26 11:19:23 UTC (rev 12357)
@@ -24,6 +24,7 @@
geocache_grid* grid = (geocache_grid*)apr_pcalloc(pool, sizeof(geocache_grid));
grid->metadata = apr_table_make(pool,3);
grid->srs_aliases = apr_array_make(pool,0,sizeof(char*));
return grid;
Modified: trunk/mapserver/mapcache/src/service_demo.c
--- trunk/mapserver/mapcache/src/service_demo.c 2011-08-26 11:19:18 UTC (rev 12356)
+++ trunk/mapserver/mapcache/src/service_demo.c 2011-08-26 11:19:23 UTC (rev 12357)
@@ -42,6 +42,7 @@
" \"%s\",{layers: '%s'},\n"
" { gutter:0,buffer:0,isBaseLayer:true,transitionEffect:'resize',\n"
" resolutions:[%s],\n"
+ " units:\"%s\",\n"
" maxExtent: new OpenLayers.Bounds(%f,%f,%f,%f),\n"
" projection: new OpenLayers.Projection(\"%s\")\n"
" }\n"
@@ -52,6 +53,7 @@
" { gutter:0,ratio:1,isBaseLayer:true,transitionEffect:'resize',\n"
" singleTile:true,\n"
@@ -88,9 +90,16 @@
int i,j;
for(j=0;j<tileset->grid_links->nelts;j++) {
char *resolutions="";
+ char *unit="dd";
geocache_grid *grid = APR_ARRAY_IDX(tileset->grid_links,j,geocache_grid_link*)->grid;
+ if(grid->unit == GEOCACHE_UNIT_METERS) {
+ unit="m";
+ } else if(grid->unit == GEOCACHE_UNIT_FEET) {
+ unit="ft";
layers = apr_psprintf(ctx->pool,"%s,%s_%s_layer",layers,tileset->name,grid->name);
resolutions = apr_psprintf(ctx->pool,"%s%.20f",resolutions,grid->levels[0]->resolution);
for(i=1;i<grid->nlevels;i++) {
resolutions = apr_psprintf(ctx->pool,"%s,%.20f",resolutions,grid->levels[i]->resolution);
@@ -100,7 +109,7 @@
tileset->name,
grid->name,
apr_pstrcat(ctx->pool,onlineresource,"/wms?",NULL),
- tileset->name,resolutions,
+ tileset->name,resolutions,unit,
grid->extent[0],
grid->extent[1],
grid->extent[2],
@@ -116,7 +125,7 @@
tileset->name,
grid->name,
grid->extent[0],
grid->extent[1],
grid->extent[2],
More information about the mapserver-commits
