[mapserver-commits] r12360 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:19:36 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:19:35 -0700 (Fri, 26 Aug 2011)
New Revision: 12360
trunk/mapserver/mapcache/src/service_wmts.c
fix cairo configure script when passing the pkg-config .pc
thomas.bonfort | 2011-05-13 15:44:02 +0200 (Fri, 13 May 2011)
Modified: trunk/mapserver/mapcache/src/service_wmts.c
--- trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:19:32 UTC (rev 12359)
+++ trunk/mapserver/mapcache/src/service_wmts.c 2011-08-26 11:19:35 UTC (rev 12360)
@@ -45,8 +45,7 @@
static ezxml_t _wmts_operations_metadata(geocache_context *ctx, const char *onlineresource, const char *operationstr) {
- ezxml_t node = ezxml_new("ows:OperationsMetadata");
- ezxml_t operation = ezxml_add_child(node,"ows:Operation",0);
+ ezxml_t operation = ezxml_new("ows:Operation");
ezxml_set_attr(operation,"name",operationstr);
ezxml_t dcp = ezxml_add_child(operation,"ows:DCP",0);
ezxml_t http = ezxml_add_child(dcp,"ows:HTTP",0);
@@ -56,14 +55,14 @@
ezxml_set_attr(constraint,"name","GetEncoding");
ezxml_t allowedvalues = ezxml_add_child(constraint,"ows:AllowedValues",0);
ezxml_set_txt(ezxml_add_child(allowedvalues,"ows:Value",0),"KVP");
- return node;
+ return operation;
static ezxml_t _wmts_service_provider(geocache_context *ctx, const char *onlineresource, const char *contact) {
ezxml_t node = ezxml_new("ows:ServiceProvider");
- ezxml_set_txt(ezxml_add_child(node,"ProviderName",0),contact);
- ezxml_set_txt(ezxml_add_child(node,"ProviderSite",0),onlineresource);
+ ezxml_set_txt(ezxml_add_child(node,"ows:ProviderName",0),contact);
+ ezxml_set_attr(ezxml_add_child(node,"ows:ProviderSite",0),"xlink:href",onlineresource);
return node;
@@ -71,6 +70,8 @@
void _create_capabilities_wmts(geocache_context *ctx, geocache_request_get_capabilities *req, char *url, char *path_info, geocache_cfg *cfg) {
geocache_request_get_capabilities_wmts *request = (geocache_request_get_capabilities_wmts*)req;
ezxml_t caps;
+ ezxml_t contents;
+ ezxml_t operations_metadata;
#ifdef DEBUG
if(request->request.request.type != GEOCACHE_REQUEST_GET_CAPABILITIES) {
ctx->set_error(ctx,500,"wrong wmts capabilities request");
@@ -94,10 +95,13 @@
caps = _wmts_capabilities();
ezxml_insert(_wmts_service_identification(ctx,title),caps,0);
ezxml_insert(_wmts_service_provider(ctx,onlineresource,"contact_todo"),caps,0);
- ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetCapabilities"),caps,0);
- ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetTile"),caps,0);
- ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetFeatureInfo"),caps,0);
+ operations_metadata = ezxml_add_child(caps,"ows:OperationsMetadata",0);
+ ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetCapabilities"),operations_metadata,0);
+ ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetTile"),operations_metadata,0);
+ ezxml_insert(_wmts_operations_metadata(ctx,onlineresource,"GetFeatureInfo"),operations_metadata,0);
+ contents = ezxml_add_child(caps,"Contents",0);
apr_hash_index_t *layer_index = apr_hash_first(ctx->pool,cfg->tilesets);
while(layer_index) {
@@ -106,7 +110,7 @@
const void *key; apr_ssize_t keylen;
apr_hash_this(layer_index,&key,&keylen,(void**)&tileset);
- ezxml_t layer = ezxml_add_child(caps,"Layer",0);
+ ezxml_t layer = ezxml_add_child(contents,"Layer",0);
const char *title = apr_table_get(tileset->metadata,"title");
if(title) {
ezxml_set_txt(ezxml_add_child(layer,"ows:Title",0),title);
@@ -204,11 +208,11 @@
double *gbbox = grid_link->restricted_extent?grid_link->restricted_extent:grid_link->grid->extent;
ezxml_t bbox = ezxml_add_child(layer,"ows:BoundingBox",0);
- ezxml_set_txt(ezxml_add_child(bbox,"ows:CRS",0),geocache_grid_get_crs(ctx,grid_link->grid));
ezxml_set_txt(ezxml_add_child(bbox,"ows:LowerCorner",0),
apr_psprintf(ctx->pool,"%f %f",gbbox[0], gbbox[1]));
ezxml_set_txt(ezxml_add_child(bbox,"ows:UpperCorner",0),
apr_psprintf(ctx->pool,"%f %f",gbbox[2], gbbox[3]));
+ ezxml_set_attr(bbox,"crs",geocache_grid_get_crs(ctx,grid_link->grid));
layer_index = apr_hash_next(layer_index);
@@ -225,7 +229,7 @@
WellKnownScaleSet = apr_table_get(grid->metadata,"WellKnownScaleSet");
- ezxml_t tmset = ezxml_add_child(caps,"TileMatrixSet",0);
+ ezxml_t tmset = ezxml_add_child(contents,"TileMatrixSet",0);
ezxml_set_txt(ezxml_add_child(tmset,"ows:Identifier",0),grid->name);
ezxml_set_txt(ezxml_add_child(tmset,"ows:SupportedCRS",0),geocache_grid_get_crs(ctx,grid));
@@ -244,8 +248,8 @@
grid->extent[1] + glevel->maxy * glevel->resolution * grid->tile_sy));
ezxml_set_txt(ezxml_add_child(tm,"TileWidth",0),apr_psprintf(ctx->pool,"%d",grid->tile_sx));
ezxml_set_txt(ezxml_add_child(tm,"TileHeight",0),apr_psprintf(ctx->pool,"%d",grid->tile_sy));
- ezxml_set_txt(ezxml_add_child(tm,"MatrixWidth",0),apr_psprintf(ctx->pool,"%d",glevel->maxx));
- ezxml_set_txt(ezxml_add_child(tm,"MatrixHeight",0),apr_psprintf(ctx->pool,"%d",glevel->maxy));
+ ezxml_set_txt(ezxml_add_child(tm,"MatrixWidth",0),apr_psprintf(ctx->pool,"%d",glevel->maxx+1));
+ ezxml_set_txt(ezxml_add_child(tm,"MatrixHeight",0),apr_psprintf(ctx->pool,"%d",glevel->maxy+1));
grid_index = apr_hash_next(grid_index);
More information about the mapserver-commits
