[mapserver-commits] r12364 - trunk/mapserver/mapcache/src
Fri Aug 26 07:19:54 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:19:54 -0700 (Fri, 26 Aug 2011)
New Revision: 12364
   trunk/mapserver/mapcache/src/service_demo.c
add ogc proxy support to wms service. needs documenting !
thomas.bonfort | 2011-05-19 16:46:10 +0200 (Thu, 19 May 2011)
Modified: trunk/mapserver/mapcache/src/service_demo.c
--- trunk/mapserver/mapcache/src/service_demo.c	2011-08-26 11:19:48 UTC (rev 12363)
+++ trunk/mapserver/mapcache/src/service_demo.c	2011-08-26 11:19:54 UTC (rev 12364)
@@ -24,6 +24,7 @@
 static char *demo_head =
       "<html xmlns=\"http://www.w3.org/1999/xhtml\">\n"
       "  <head>\n"
+      "    <title>mod-geocache demo service</title>\n"
       "    <style type=\"text/css\">\n"
       "    #map {\n"
       "    width: 100%;\n"
@@ -33,21 +34,142 @@
       "    </style>\n"
       "    <script src=\"http://www.openlayers.org/api/OpenLayers.js\"></script>\n"
       "    <script type=\"text/javascript\">\n"
+      "%s\n"
       "var map;\n"
       "function init(){\n"
-      "    map = new OpenLayers.Map( 'map' );\n";
+      "    map = new OpenLayers.Map( 'map', {\n"
+      "        displayProjection: new OpenLayers.Projection(\"EPSG:4326\")\n"
+      "    } );\n";
-static char *demo_layer =
-      "    var %s_%s_layer = new OpenLayers.Layer.WMS( \"%s-%s\",\n"
+static char *demo_ve_extra =
+      "function QuadTree(tx, ty, zoom) {\n"
+      "    var tname = '';\n"
+      "    var i, j, mask, digit;\n"
+      "    var zero = '0'.charCodeAt(0);\n"
+      "\n"
+      "    if (ty < 0) ty = 2 - ty;\n"
+      "    ty = (Math.pow(2,zoom) - 1) - ty;\n"
+      "\n"
+      "    for (i=zoom, j=0; i>0; i--, j++) {\n"
+      "        digit = 0;\n"
+      "        mask = 1 << (i-1);\n"
+      "        if (tx & mask) digit += 1;\n"
+      "        if (ty & mask) digit += 2;\n"
+      "        tname += String.fromCharCode(zero + digit);\n"
+      "    }\n"
+      "    return tname;\n"
+      "}\n"
+      "    function WGSQuadTree(tx, ty, zoom) {\n"
+      "        var i, n;\n"
+      "\n"
+      "        ty = (Math.pow(2,zoom-1) - 1) - ty;\n"
+      "\n"
+      "        for (i=zoom; i>0; i--) {\n"
+      "            if (i == 1)\n"
+      "                n = Math.floor(tx/2)*4 + tx%2 + (ty%2)*2;\n"
+      "            else\n"
+      "                n = (ty%2)*2 + tx%2;\n"
+      "            if (n<0 || n>9)\n"
+      "                return '';\n"
+      "            tname = String.fromCharCode(zero + n) + tname;\n"
+      "            tx = Math.floor(tx/2);\n"
+      "            ty = Math.floor(ty/2);\n"
+      "        }\n"
+      "    }\n"
+      "function get_ve_url (bounds) {\n"
+      "    var xoriginShift, yoriginShift, id;\n"
+      "    if (this.sphericalMercator) {\n"
+      "        xoriginShift = 2 * Math.PI * 6378137.0 / 2.0; // meters\n"
+      "        yoriginShift = xoriginShift;\n"
+      "    }\n"
+      "    else {\n"
+      "        xoriginShift = 180.0;\n"
+      "        yoriginShift = 90;\n"
+      "    }\n"
+      "\n"
+      "    var res = this.map.getResolution();\n"
+      "    var x = Math.floor(Math.ceil(((bounds.left + bounds.right)/2.0 + xoriginShift) / res / this.tileSize.w) - 1);\n"
+      "    var y = Math.floor(Math.ceil(((bounds.top + bounds.bottom)/2.0 + yoriginShift) / res / this.tileSize.h) - 1);\n"
+      "    var z = this.map.getZoom();\n"
+      "        id = QuadTree(x, y, z);\n"
+      "    }\n"
+      "    else {\n"
+      "        id = WGSQuadTree(x, y, z);\n"
+      "    }\n"
+      "    var path = '?LAYER=' + this.options.layername + '&tile=' + id;\n"
+      "    var url = this.url;\n"
+      "    if (url instanceof Array) {\n"
+      "        url = this.selectUrl(path, url);\n"
+      "    }\n"
+      "    return url + path;\n"
+      "}\n";
+static char *demo_layer_wms =
+      "    var %s_%s_wms_layer = new OpenLayers.Layer.WMS( \"%s-%s-WMS\",\n"
       "        \"%s\",{layers: '%s'},\n"
       "        { gutter:0,buffer:0,isBaseLayer:true,transitionEffect:'resize',\n"
       "          resolutions:[%s],\n"
       "          units:\"%s\",\n"
       "          maxExtent: new OpenLayers.Bounds(%f,%f,%f,%f),\n"
-      "          projection: new OpenLayers.Projection(\"%s\")\n"
+      "          projection: new OpenLayers.Projection(\"%s\".toUpperCase()),\n"
+      "          sphericalMercator: %s\n"
       "        }\n"
-      "    );\n";
+      "    );\n"
+      "    map.addLayer(%s_%s_wms_layer)\n\n";
+static char *demo_layer_tms =
+      "    var %s_%s_tms_layer = new OpenLayers.Layer.TMS( \"%s-%s-TMS\",\n"
+      "        \"%s\",\n"
+      "        { layername: '%s@%s', type: \"%s\", serviceVersion:\"1.0.0\",\n"
+      "          gutter:0,buffer:0,isBaseLayer:true,transitionEffect:'resize',\n"
+      "          tileOrigin: new OpenLayers.LonLat(%f,%f),\n"
+      "          resolutions:[%s],\n"
+      "          units:\"%s\",\n"
+      "          maxExtent: new OpenLayers.Bounds(%f,%f,%f,%f),\n"
+      "        }\n"
+      "    );\n"
+      "    map.addLayer(%s_%s_tms_layer)\n\n";
+static char *demo_layer_wmts =
+      "    var %s_%s_wmts_layer = new OpenLayers.Layer.WMTS({\n"
+      "        name: \"%s-%s-WMTS\",\n"
+      "        url: \"%s\",\n"
+      "        layer: '%s',\n"
+      "        matrixSet: '%s',\n"
+      "        format: '%s',\n"
+      "        style: 'default',\n"
+      "      }\n"
+      "    );\n"
+      "    map.addLayer(%s_%s_wmts_layer)\n\n";
+static char *demo_layer_ve =
+      "    var %s_%s_ve_layer = new OpenLayers.Layer.TMS( \"%s-%s-VE\",\n"
+      "        \"%s\",\n"
+      "        { layername: '%s@%s',\n"
+      "          getURL: get_ve_url,\n"
+      "        }\n"
+      "    );\n"
+      "    map.addLayer(%s_%s_ve_layer)\n\n";
+#ifdef USE_CAIRO
 static char *demo_layer_singletile =
       "    var %s_%s_slayer = new OpenLayers.Layer.WMS( \"%s-%s (singleTile)\",\n"
@@ -56,10 +178,29 @@
       "          units:\"%s\",\n"
       "          singleTile:true,\n"
       "        }\n"
-      "    );\n";
+      "    );\n"
+      "    map.addLayer(%s_%s_slayer)\n\n";
+#endif
+static char *demo_footer =
+      "%s"
+      "    if(!map.getCenter())\n"
+      "     map.zoomToMaxExtent();\n"
+      "    map.addControl(new OpenLayers.Control.LayerSwitcher());\n"
+      "    map.addControl(new OpenLayers.Control.MousePosition());\n"
+      "}\n"
+      "    </script>\n"
+      "  </head>\n"
+      "\n"
+      "<body onload=\"init()\">\n"
+      "    <div id=\"map\">\n"
+      "    </div>\n"
+      "</body>\n"
+      "</html>\n";
  * \brief parse a demo request
  * \private \memberof geocache_service_demo
@@ -114,9 +255,9 @@
 void _create_demo_wms(geocache_context *ctx, geocache_request_get_capabilities *req,
          const char *url_prefix) {
    req->mime_type = apr_pstrdup(ctx->pool,"text/html");
-   char *caps = apr_pstrdup(ctx->pool,demo_head);
+   char *caps = apr_psprintf(ctx->pool,demo_head, "");
+   char *ol_layer;
    apr_hash_index_t *tileindex_index = apr_hash_first(ctx->pool,ctx->config->tilesets);
-   char *layers="";
    while(tileindex_index) {
       geocache_tileset *tileset;
       const void *key; apr_ssize_t keylen;
@@ -125,34 +266,42 @@
       for(j=0;j<tileset->grid_links->nelts;j++) {
          char *resolutions="";
          char *unit="dd";
+         char *smerc = "false";
          geocache_grid *grid = APR_ARRAY_IDX(tileset->grid_links,j,geocache_grid_link*)->grid;
          if(grid->unit == GEOCACHE_UNIT_METERS) {
             unit="m";
          } else if(grid->unit == GEOCACHE_UNIT_FEET) {
             unit="ft";
-         layers = apr_psprintf(ctx->pool,"%s,%s_%s_layer",layers,tileset->name,grid->name);
-         resolutions = apr_psprintf(ctx->pool,"%s%.20f",resolutions,grid->levels[0]->resolution);
+         if(strstr(grid->srs, ":900913") || strstr(grid->srs, ":3857")) {
+            smerc = "true";
+         resolutions = apr_psprintf(ctx->pool,"%s%.20f",resolutions,grid->levels[0]->resolution);
          for(i=1;i<grid->nlevels;i++) {
             resolutions = apr_psprintf(ctx->pool,"%s,%.20f",resolutions,grid->levels[i]->resolution);
-         char *ol_layer = apr_psprintf(ctx->pool,demo_layer,
+         ol_layer = apr_psprintf(ctx->pool,demo_layer_wms,
                tileset->name,
                grid->name,
                tileset->name,
                grid->name,
                apr_pstrcat(ctx->pool,url_prefix,"/wms?",NULL),
-               tileset->name,resolutions,unit,
+               tileset->name,
+               resolutions,
+               unit,
                grid->extent[0],
                grid->extent[1],
                grid->extent[2],
                grid->extent[3],
-               grid->srs);
+               grid->srs,
+               smerc,
+               tileset->name,
+               grid->name);
          caps = apr_psprintf(ctx->pool,"%s%s",caps,ol_layer);
 #ifdef USE_CAIRO
-         layers = apr_psprintf(ctx->pool,"%s,%s_%s_slayer",layers,tileset->name,grid->name);
          ol_layer = apr_psprintf(ctx->pool,demo_layer_singletile,
                tileset->name,
                grid->name,
@@ -164,33 +313,201 @@
                grid->extent[1],
                grid->extent[2],
                grid->extent[3],
-               grid->srs);
+               grid->srs,
+               smerc,
+               tileset->name,
+               grid->name);
 #endif
       tileindex_index = apr_hash_next(tileindex_index);
-   /*skip leading comma */
-   layers++;
-   caps = apr_psprintf(ctx->pool,"%s"
-         "    map.addLayers([%s]);\n"
-               "    if(!map.getCenter())\n"
-               "     map.zoomToMaxExtent();\n"
-               "    map.addControl(new OpenLayers.Control.LayerSwitcher());\n"
-               "    map.addControl(new OpenLayers.Control.MousePosition());\n"
-               "}\n"
-               "    </script>\n"
-               "  </head>\n"
-               "\n"
-               "<body onload=\"init()\">\n"
-               "    <div id=\"map\">\n"
-               "    </div>\n"
-               "</body>\n"
-               "</html>\n",caps,layers);
+   caps = apr_psprintf(ctx->pool,demo_footer,caps);
    req->capabilities = caps;
+void _create_demo_tms(geocache_context *ctx, geocache_request_get_capabilities *req,
+         const char *url_prefix) {
+   req->mime_type = apr_pstrdup(ctx->pool,"text/html");
+   char *ol_layer;
+   apr_hash_index_t *tileindex_index = apr_hash_first(ctx->pool,ctx->config->tilesets);
+   while(tileindex_index) {
+      geocache_tileset *tileset;
+      const void *key; apr_ssize_t keylen;
+      apr_hash_this(tileindex_index,&key,&keylen,(void**)&tileset);
+      int i,j;
+      char *extension = "png";
+      if (tileset->format && tileset->format->extension)
+         extension = tileset->format->extension;
+      for(j=0;j<tileset->grid_links->nelts;j++) {
+         char *resolutions="";
+         char *unit="dd";
+         geocache_grid *grid = APR_ARRAY_IDX(tileset->grid_links,j,geocache_grid_link*)->grid;
+         if(grid->unit == GEOCACHE_UNIT_METERS) {
+            unit="m";
+         } else if(grid->unit == GEOCACHE_UNIT_FEET) {
+            unit="ft";
+            smerc = "true";
+         for(i=1;i<grid->nlevels;i++) {
+            resolutions = apr_psprintf(ctx->pool,"%s,%.20f",resolutions,grid->levels[i]->resolution);
+         ol_layer = apr_psprintf(ctx->pool, demo_layer_tms,
+            tileset->name,
+            grid->name,
+            tileset->name,
+            grid->name,
+            apr_pstrcat(ctx->pool,url_prefix,"/tms/",NULL),
+            tileset->name,
+            grid->name,
+            extension,
+            grid->extent[0],
+            grid->extent[1],
+            resolutions,
+            unit,
+            grid->extent[0],
+            grid->extent[1],
+            grid->extent[2],
+            grid->extent[3],
+            grid->srs,
+            smerc,
+            tileset->name,
+            grid->name);
+         caps = apr_psprintf(ctx->pool,"%s%s",caps,ol_layer);
+      tileindex_index = apr_hash_next(tileindex_index);
+   req->capabilities = caps;
+void _create_demo_wmts(geocache_context *ctx, geocache_request_get_capabilities *req,
+   char *ol_layer;
+      int i,j;
+      char *mime_type = "image/png";
+      if (tileset->format && tileset->format->mime_type)
+         mime_type = tileset->format->mime_type;
+         char *unit="dd";
+            unit="m";
+            unit="ft";
+            smerc = "true";
+         ol_layer = apr_psprintf(ctx->pool, demo_layer_wmts,
+            tileset->name,
+            grid->name,
+            tileset->name,
+            grid->name,
+            apr_pstrcat(ctx->pool,url_prefix,"/wmts/",NULL),
+            tileset->name,
+            grid->name,
+            mime_type,
+            resolutions,
+            unit,
+            grid->extent[0],
+            grid->extent[1],
+            grid->extent[2],
+            grid->extent[3],
+            grid->srs,
+            smerc,
+            tileset->name,
+            grid->name);
+void _create_demo_ve(geocache_context *ctx, geocache_request_get_capabilities *req,
+   char *caps = apr_psprintf(ctx->pool,demo_head, demo_ve_extra);
+   char *ol_layer;
+      int i,j;
+         char *unit="dd";
+            unit="m";
+            unit="ft";
+            smerc = "true";
+         ol_layer = apr_psprintf(ctx->pool, demo_layer_ve,
+            tileset->name,
+            grid->name,
+            tileset->name,
+            grid->name,
+            apr_pstrcat(ctx->pool,url_prefix,"/ve",NULL),
+            tileset->name,
+            grid->name,
+            resolutions,
+            unit,
+            grid->extent[0],
+            grid->extent[1],
+            grid->extent[2],
+            grid->extent[3],
+            grid->srs,
+            smerc,
+            tileset->name,
+            grid->name);
 void _create_capabilities_demo(geocache_context *ctx, geocache_request_get_capabilities *req,
       char *url, char *path_info, geocache_cfg *cfg) {
    geocache_request_get_capabilities_demo *request = (geocache_request_get_capabilities_demo*)req;
@@ -205,11 +522,14 @@
       switch(request->service->type) {
          case GEOCACHE_SERVICE_WMS:
             return _create_demo_wms(ctx,req,onlineresource);
-         case GEOCACHE_SERVICE_GMAPS:
          case GEOCACHE_SERVICE_TMS:
+            return _create_demo_tms(ctx,req,onlineresource);
          case GEOCACHE_SERVICE_WMTS:
+            return _create_demo_wmts(ctx,req,onlineresource);
+         case GEOCACHE_SERVICE_VE:
+            return _create_demo_ve(ctx,req,onlineresource);
          case GEOCACHE_SERVICE_KML:
-         case GEOCACHE_SERVICE_VE:
+         case GEOCACHE_SERVICE_GMAPS:
             req->mime_type = apr_pstrdup(ctx->pool,"text/plain");
             req->capabilities = apr_pstrdup(ctx->pool,"not implemented");
             return;
