[mapserver-commits] r12391 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:21:48 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:21:48 -0700 (Fri, 26 Aug 2011)
New Revision: 12391
trunk/mapserver/mapcache/src/cache_disk.c
add configurable resample mode when merging tiles.
closes issue 88.
thomas.bonfort | 2011-07-02 15:20:29 +0200 (Sat, 02 Jul 2011)
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:21:44 UTC (rev 12390)
+++ trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:21:48 UTC (rev 12391)
@@ -238,7 +238,7 @@
ret = apr_file_remove(filename,ctx->pool);
if(ret != APR_SUCCESS) {
ctx->set_error(ctx, 500, "failed to remove existing file %s: %s",filename, apr_strerror(ret,errmsg,120));
- return; /* we could not create the file */
+ return; /* we could not delete the file */
@@ -262,9 +262,10 @@
if(APR_SUCCESS != (ret = apr_dir_make_recursive(
blankdirname,
APR_OS_DEFAULT,ctx->pool))) {
- ctx->set_error(ctx, 500, "failed to create directory %s for blank tiles",blankdirname, apr_strerror(ret,errmsg,120));
- ctx->global_lock_release(ctx);
- return;
+ if(!APR_STATUS_IS_EEXIST(ret)) {
+ ctx->set_error(ctx, 500, "failed to create directory %s for blank tiles",blankdirname, apr_strerror(ret,errmsg,120));
+ return;
if((ret = apr_file_open(&f, blankname,
APR_FOPEN_CREATE|APR_FOPEN_WRITE|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
More information about the mapserver-commits
