[mapserver-commits] r12414 - in trunk/mapserver/mapcache: include src
Fri Aug 26 07:23:43 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:23:43 -0700 (Fri, 26 Aug 2011)
New Revision: 12414
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/dimension.c
   trunk/mapserver/mapcache/src/service_wms.c
updated config file
thomas.bonfort | 2011-08-02 10:48:40 +0200 (Tue, 02 Aug 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:23:38 UTC (rev 12413)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:23:43 UTC (rev 12414)
@@ -1347,13 +1347,14 @@
     * \brief parse the value given in the configuration
-   void (*parse)(geocache_context *context, geocache_dimension *dim, const char *entry);
+   void (*parse)(geocache_context *context, geocache_dimension *dim, ezxml_t node);
 struct geocache_dimension_values {
    geocache_dimension dimension;
    int nvalues;
    char **values;
+   int case_sensitive;
 struct geocache_dimension_regex {
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:23:38 UTC (rev 12413)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:23:43 UTC (rev 12414)
@@ -264,7 +264,7 @@
          return;
-      dimension->parse(ctx,dimension,dimension_node->txt);
+      dimension->parse(ctx,dimension,dimension_node);
       GC_CHECK_ERROR(ctx);
       APR_ARRAY_PUSH(dimensions,geocache_dimension*) = dimension;
Modified: trunk/mapserver/mapcache/src/dimension.c
--- trunk/mapserver/mapcache/src/dimension.c	2011-08-26 11:23:38 UTC (rev 12413)
+++ trunk/mapserver/mapcache/src/dimension.c	2011-08-26 11:23:43 UTC (rev 12414)
@@ -54,7 +54,9 @@
    return ret;
-static void _geocache_dimension_intervals_parse(geocache_context *ctx, geocache_dimension *dim, const char *entry) {
+static void _geocache_dimension_intervals_parse(geocache_context *ctx, geocache_dimension *dim,
+      ezxml_t node) {
+   const char *entry = node->txt;
    int count = 1;
    if(!entry || !*entry) {
       ctx->set_error(ctx,400,"failed to parse dimension values: none supplied");
@@ -121,7 +123,9 @@
    return ret;
-static void _geocache_dimension_regex_parse(geocache_context *ctx, geocache_dimension *dim, const char *entry) {
+static void _geocache_dimension_regex_parse(geocache_context *ctx, geocache_dimension *dim,
+      ezxml_t node) {
       ctx->set_error(ctx,400,"failed to parse dimension regex: none supplied");
       return;
@@ -154,8 +158,13 @@
    int i;
    geocache_dimension_values *dimension = (geocache_dimension_values*)dim;
    for(i=0;i<dimension->nvalues;i++) {
-      if(!strcmp(*value,dimension->values[i]))
-         return GEOCACHE_SUCCESS;
+      if(dimension->case_sensitive) {
+         if(!strcmp(*value,dimension->values[i]))
+            return GEOCACHE_SUCCESS;
+      } else {
+         if(!strcasecmp(*value,dimension->values[i]))
    return GEOCACHE_FAILURE;
@@ -171,13 +180,21 @@
    return ret;
-static void _geocache_dimension_values_parse(geocache_context *ctx, geocache_dimension *dim, const char *entry) {
+static void _geocache_dimension_values_parse(geocache_context *ctx, geocache_dimension *dim,
+      ezxml_t node) {
    int count = 1;
       return;
+   const char *case_sensitive = ezxml_attr(node,"case_sensitive");
+   if(case_sensitive && !strcasecmp(case_sensitive,"true")) {
+      dimension->case_sensitive = 1;
    char *values = apr_pstrdup(ctx->pool,entry);
    char *key,*last;
    for(key=values;*key;key++) if(*key == ',') count++;
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c	2011-08-26 11:23:38 UTC (rev 12413)
+++ trunk/mapserver/mapcache/src/service_wms.c	2011-08-26 11:23:43 UTC (rev 12414)
@@ -781,7 +781,7 @@
          dimension->name = apr_pstrdup(ctx->pool,name);
-         dimension->parse(ctx,dimension,param_node->txt);
+         dimension->parse(ctx,dimension,param_node);
          APR_ARRAY_PUSH(rule->match_params,geocache_dimension*) = dimension;
