[mapserver-commits] r12420 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:24:16 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:24:16 -0700 (Fri, 26 Aug 2011)
New Revision: 12420
trunk/mapserver/mapcache/src/geocache_seed.c
fix dimension handling in parser
thomas.bonfort | 2011-08-03 15:28:50 +0200 (Wed, 03 Aug 2011)
Modified: trunk/mapserver/mapcache/src/geocache_seed.c
--- trunk/mapserver/mapcache/src/geocache_seed.c 2011-08-26 11:24:11 UTC (rev 12419)
+++ trunk/mapserver/mapcache/src/geocache_seed.c 2011-08-26 11:24:16 UTC (rev 12420)
@@ -4,6 +4,7 @@
#include <apr_getopt.h>
#include <signal.h>
#include <time.h>
+#include <sys/time.h>
#include <apr_time.h>
#include <apr_queue.h>
@@ -21,15 +22,14 @@
int maxzoom=0;
geocache_grid_link *grid_link;
int nthreads=1;
+int quiet = 0;
int sig_int_received = 0;
int error_detected = 0;
apr_queue_t *work_queue;
apr_time_t age_limit = 0;
-int curz;
-int seededtilestot, seededtiles;
-time_t lastlogtime,starttime;
+int seededtilestot=0, seededtiles=0, queuedtilestot=0;
+struct timeval lastlogtime,starttime;
typedef enum {
GEOCACHE_CMD_SEED,
@@ -61,6 +61,7 @@
{ "ogr-where", 'w', TRUE, "filter to apply on layer features"},
#endif
{ "help", 'h', FALSE, "show help" },
+ { "quiet", 'q', FALSE, "don't show progress info" },
{ NULL, 0, 0, NULL },
@@ -117,8 +118,39 @@
#endif
+int lastmsglen = 0;
+void progresslog(int x, int y, int z) {
+ if(quiet) return;
+ char msg[1024];
+ if(queuedtilestot>nthreads) {
+ seededtilestot = queuedtilestot - nthreads;
+ struct timeval now_t;
+ gettimeofday(&now_t,NULL);
+ float duration = ((now_t.tv_sec-lastlogtime.tv_sec)*1000000+(now_t.tv_usec-lastlogtime.tv_usec))/1000000.0;
+ float totalduration = ((now_t.tv_sec-starttime.tv_sec)*1000000+(now_t.tv_usec-starttime.tv_usec))/1000000.0;
+ if(duration>=1) {
+ int ntilessincelast = seededtilestot-seededtiles;
+ sprintf(msg,"seeding level %d: %f metatiles/sec (avg since start: %f)",z,ntilessincelast/duration,
+ seededtilestot/totalduration);
+ lastlogtime=now_t;
+ seededtiles=seededtilestot;
+ } else {
+ sprintf(msg,"seeding level %d",z);
+ if(lastmsglen) {
+ char erasestring[1024];
+ sprintf(erasestring,"\r%%%ds\r",lastmsglen);
+ printf(erasestring," ");
+ lastmsglen = strlen(msg);
+ printf("%s",msg);
+ fflush(NULL);
void cmd_thread() {
int z = minzoom;
int x = grid_link->grid_limits[z][0];
@@ -133,7 +165,7 @@
if(sig_int_received || error_detected) { //stop if we were asked to stop by hitting ctrl-c
//remove all items from the queue
void *entry;
- while (apr_queue_trypop(work_queue,&entry)!=APR_EAGAIN) {}
+ while (apr_queue_trypop(work_queue,&entry)!=APR_EAGAIN) {queuedtilestot--;}
break;
int should_seed = 0;
@@ -190,6 +222,8 @@
cmd->z = z;
cmd->command = GEOCACHE_CMD_SEED;
apr_queue_push(work_queue,cmd);
+ queuedtilestot++;
+ progresslog(x,y,z);
//compute next x,y,z
x += tileset->metasize_x;
@@ -292,9 +326,9 @@
ctx.global_lock_release = dummy_lock_release;
apr_getopt_init(&opt, ctx.pool, argc, argv);
- curz=-1;
- seededtiles=seededtilestot=0;
- starttime = lastlogtime = time(NULL);
+ seededtiles=seededtilestot=queuedtilestot=0;
+ gettimeofday(&starttime,NULL);
+ lastlogtime=starttime;
apr_table_t *dimensions = apr_table_make(ctx.pool,3);
char *dimkey = NULL,*dimvalue = NULL,*key,*last,*optargcpy = NULL;
int keyidx;
@@ -305,6 +339,9 @@
case 'h':
return usage(argv[0],NULL);
break;
+ case 'q':
+ quiet = 1;
+ break;
case 'c':
configfile = optarg;
break;
@@ -577,8 +614,12 @@
printf("%s",ctx.get_error_message(&ctx));
- if(seededtilestot>0)
- printf("seeded %d tiles at %g tiles/sec\n",seededtilestot, seededtilestot/((double)(time(NULL)-starttime)));
+ if(seededtilestot>0) {
+ float duration = ((now_t.tv_sec-starttime.tv_sec)*1000000+(now_t.tv_usec-starttime.tv_usec))/1000000.0;
+ printf("\nseeded %d tiles at %g tiles/sec\n",seededtilestot, seededtilestot/duration);
return 0;
More information about the mapserver-commits
