[mapserver-commits] r12434 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:25:26 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:25:26 -0700 (Fri, 26 Aug 2011)
New Revision: 12434
trunk/mapserver/mapcache/src/imageio_png.c
update install instructions
thomas.bonfort | 2011-08-16 11:44:11 +0200 (Tue, 16 Aug 2011)
Modified: trunk/mapserver/mapcache/src/imageio_png.c
--- trunk/mapserver/mapcache/src/imageio_png.c 2011-08-26 11:25:21 UTC (rev 12433)
+++ trunk/mapserver/mapcache/src/imageio_png.c 2011-08-26 11:25:26 UTC (rev 12434)
@@ -57,7 +57,7 @@
png_ptr = png_create_read_struct(PNG_LIBPNG_VER_STRING, NULL, NULL, NULL);
if (!png_ptr) {
ctx->set_error(ctx, 500, "failed to allocate png_struct structure");
- return NULL;
+ return;
info_ptr = png_create_info_struct(png_ptr);
@@ -65,21 +65,21 @@
png_destroy_read_struct(&png_ptr, NULL, NULL);
ctx->set_error(ctx, 500, "failed to allocate png_info structure");
- return NULL;
+ return;
if (setjmp(png_jmpbuf(png_ptr)))
ctx->set_error(ctx, 500, "failed to setjmp(png_jmpbuf(png_ptr))");
png_destroy_read_struct(&png_ptr, &info_ptr, NULL);
- return NULL;
+ return;
png_set_read_fn(png_ptr,&b,_geocache_imageio_png_read_func);
png_read_info(png_ptr,info_ptr);
if(!png_get_IHDR(png_ptr, info_ptr, &width, &height,&bit_depth, &color_type,NULL,NULL,NULL)) {
ctx->set_error(ctx, 500, "failed to read png header");
- return NULL;
+ return;
img->w = width;
@@ -104,19 +104,11 @@
png_set_add_alpha(png_ptr, 0xff, PNG_FILLER_AFTER);
png_read_update_info(png_ptr, info_ptr);
-#ifdef DEBUG
- if(img->stride != png_get_rowbytes(png_ptr, info_ptr)) {
- ctx->set_error(ctx, 500, "### BUG ### failed to decompress PNG to RGBA");
- return NULL;
-#endif
png_read_image(png_ptr, row_pointers);
png_read_end(png_ptr,NULL);
- return img;
More information about the mapserver-commits
