[mapserver-commits] r12440 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:26:16 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:26:15 -0700 (Fri, 26 Aug 2011)
New Revision: 12440
trunk/mapserver/mapcache/src/cache_sqlite.c
restore missing Last-Modified header
thomas.bonfort | 2011-08-25 14:59:05 +0200 (Thu, 25 Aug 2011)
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:26:11 UTC (rev 12439)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:26:15 UTC (rev 12440)
@@ -20,6 +20,7 @@
#include <apr_strings.h>
#include <string.h>
#include <errno.h>
+#include <unistd.h>
#include <sqlite3.h>
@@ -64,20 +65,29 @@
flags = SQLITE_OPEN_READWRITE|SQLITE_OPEN_CREATE;
char *dbfile = _get_dbname(ctx,(geocache_cache_sqlite*)tile->tileset->cache,tile->tileset,tile->grid_link->grid);
- sqlite3_open_v2(dbfile,&handle,flags,NULL);
+ int ret = sqlite3_open_v2(dbfile,&handle,flags,NULL);
+ if(ret != SQLITE_OK) {
+ ctx->set_error(ctx,500,"failed to connect to sqlite db %s: %s",dbfile,sqlite3_errmsg(handle));
+ return NULL;
+ sqlite3_busy_timeout(handle,3000);
return handle;
static int _geocache_cache_sqlite_has_tile(geocache_context *ctx, geocache_tile *tile) {
- int ret;
char *sql;
if(tile->dimensions) {
sql = "SELECT 1 from tiles where x=? and y=? and z=? and dim=?";
} else {
sql = "SELECT 1 from tiles where x=? and y=? and z=?";
- sqlite3* handle = _get_conn(ctx,tile,0);
+ sqlite3* handle = _get_conn(ctx,tile,1);
+ if(GC_HAS_ERROR(ctx)) {
+ sqlite3_close(handle);
+ return GEOCACHE_FALSE;
sqlite3_stmt *stmt;
sqlite3_prepare(handle,sql,-1,&stmt,NULL);
sqlite3_bind_int(stmt,1,tile->x);
@@ -87,9 +97,13 @@
const char *dim = _get_tile_dimkey(ctx,tile);
sqlite3_bind_text(stmt,4,dim,-1,SQLITE_STATIC);
- if(sqlite3_step(stmt) == SQLITE_DONE) {
+ int ret = sqlite3_step(stmt);
+ if(ret != SQLITE_DONE && ret != SQLITE_ROW) {
+ ctx->set_error(ctx,500,"sqlite backend failed on has_tile: %s",sqlite3_errmsg(handle));
+ if(ret == SQLITE_DONE) {
ret = GEOCACHE_FALSE;
- } else {
+ } else if(ret == SQLITE_ROW){
ret = GEOCACHE_TRUE;
sqlite3_finalize(stmt);
@@ -99,6 +113,7 @@
static void _geocache_cache_sqlite_delete(geocache_context *ctx, geocache_tile *tile) {
+ GC_CHECK_ERROR(ctx);
char *sql;
sql = "DELETE from tiles where x=? and y=? and z=? and dim=?";
@@ -114,14 +129,21 @@
const char* dim = _get_tile_dimkey(ctx,tile);
- sqlite3_step(stmt);
+ ctx->set_error(ctx,500,"sqlite backend failed on delete: %s",sqlite3_errmsg(handle));
static int _geocache_cache_sqlite_get(geocache_context *ctx, geocache_tile *tile) {
+ return GEOCACHE_FAILURE;
sqlite3_stmt *stmt;
char *sql;
@@ -137,9 +159,16 @@
+ if(ret!=SQLITE_DONE && ret != SQLITE_ROW) {
+ ctx->set_error(ctx,500,"sqlite backend failed on get: %s",sqlite3_errmsg(handle));
+ sqlite3_finalize(stmt);
return GEOCACHE_CACHE_MISS;
} else {
const void *blob = sqlite3_column_blob(stmt,0);
@@ -155,6 +184,7 @@
static void _geocache_cache_sqlite_set(geocache_context *ctx, geocache_tile *tile) {
sqlite3_stmt *stmt;
char *sql;
@@ -171,7 +201,10 @@
sqlite3_bind_text(stmt,5,dim,-1,SQLITE_STATIC);
+ ctx->set_error(ctx,500,"sqlite backend failed on set: %s",sqlite3_errmsg(handle));
More information about the mapserver-commits
