[mapserver-commits] r12445 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:26:46 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:26:46 -0700 (Fri, 26 Aug 2011)
New Revision: 12445
trunk/mapserver/mapcache/Makefile.inc.in
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/Makefile
Modified: trunk/mapserver/mapcache/Makefile.inc.in
--- trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:26:40 UTC (rev 12444)
+++ trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:26:46 UTC (rev 12445)
@@ -55,7 +55,8 @@
MISC_ENABLED=@MISC_ENABLED@ -DTHREADED_MPM=$(shell $(HTTPD) -V | grep "Server MPM" | grep -q "Prefork"; echo $$?)
INCLUDES=-I../include $(MISC_ENABLED) $(CAIRO_ENABLED) $(CAIRO_INC) $(CURL_CFLAGS) $(PNG_INC) $(JPEG_INC) $(GDAL_INC) $(GEOS_INC) $(APR_INC) $(APU_INC) $(MEMCACHE_ENABLED) $(PCRE_CFLAGS) $(PCRE_ENABLED) $(OGR_ENABLED) $(GEOS_ENABLED) $(SQLITE_ENABLED)
-LIBS=$(CURL_LIBS) $(CAIRO_LIB) $(PNG_LIB) $(JPEG_LIB) $(GDAL_LIB) $(GEOS_LIB) $(APR_LIBS) $(APU_LIBS) $(PCRE_LIBS)
+LIBS=$(CURL_LIBS) $(CAIRO_LIB) $(PNG_LIB) $(JPEG_LIB) $(APR_LIBS) $(APU_LIBS) $(PCRE_LIBS)
+SEEDER_EXTRALIBS=$(GDAL_LIB) $(GEOS_LIB)
OBJS=$(shell find . -regex '^.*\.c$$' -print | grep -v geocache_seed.c | grep -v mod_geocache.c | grep -v fastcgi_geocache.c |sed "s/^\(.*\)\.c$$/\1.o/")
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:26:40 UTC (rev 12444)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:26:46 UTC (rev 12445)
@@ -27,11 +27,16 @@
#include <apr_global_mutex.h>
#include "util.h"
#include "ezxml.h"
+#include "ezxml.h"
#include "errors.h"
+#if 0
#ifdef USE_GDAL
#include <gdal.h>
#include <cpl_conv.h>
#endif
+#endif
#include <assert.h>
#include <apr_time.h>
@@ -79,7 +84,9 @@
typedef struct geocache_map geocache_map;
typedef struct geocache_proxied_response geocache_proxied_response;
typedef struct geocache_source_wms geocache_source_wms;
+#if 0
typedef struct geocache_source_gdal geocache_source_gdal;
+#endif
typedef struct geocache_cache_disk geocache_cache_disk;
typedef struct geocache_http geocache_http;
typedef struct geocache_request geocache_request;
@@ -288,6 +295,7 @@
geocache_http *http;
+#if 0
#ifdef USE_GDAL
/**\class geocache_source_gdal
* \brief GDAL geocache_source
@@ -301,6 +309,7 @@
#endif
+#endif
/** \defgroup cache Caches */
Modified: trunk/mapserver/mapcache/src/Makefile
--- trunk/mapserver/mapcache/src/Makefile 2011-08-26 11:26:40 UTC (rev 12444)
+++ trunk/mapserver/mapcache/src/Makefile 2011-08-26 11:26:46 UTC (rev 12445)
@@ -22,7 +22,7 @@
$(LIBTOOL) --mode=link --tag CC $(CC) -o geocache.fcgi $(CFLAGS) $(INCLUDES) $(FCGI_INC) fastcgi_geocache.c $(LOBJS) $(LIBS) $(FCGI_LIB)
geocache_seed: geocache_seed.c $(OBJS)
- $(LIBTOOL) --mode=link --tag CC $(CC) -o geocache_seed $(CFLAGS) $(INCLUDES) geocache_seed.c $(LOBJS) $(LIBS)
+ $(LIBTOOL) --mode=link --tag CC $(CC) -o geocache_seed $(CFLAGS) $(INCLUDES) geocache_seed.c $(LOBJS) $(LIBS) $(SEEDER_EXTRALIBS)
clean:
More information about the mapserver-commits
