[mapserver-commits] r12449 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:27:22 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:27:22 -0700 (Fri, 26 Aug 2011)
New Revision: 12449
Removed:
trunk/mapserver/mapcache/src/ngtembed.c
Deleted: trunk/mapserver/mapcache/src/ngtembed.c
--- trunk/mapserver/mapcache/src/ngtembed.c 2011-08-26 11:27:18 UTC (rev 12448)
+++ trunk/mapserver/mapcache/src/ngtembed.c 2011-08-26 11:27:22 UTC (rev 12449)
@@ -1,121 +0,0 @@
- * ngtembed - A tool for converting template files to embedded cstrings
-#include <stdlib.h>
-#include <limits.h>
-#include "ngtemplate.h"
- * Breaks up the input into multiple quoted lines, making sure each line doesn't go over the 80 column
- * limit. This is for aesthetic reasons as well as because there are compilers that can't tolerate
- * incredibly long source lines
-static void _breakup_lines_modifier_cb(const char* name, const char* args, const char* marker, const char* value, stringbuilder* out_sb) {
- char* p;
- p = (char*)value;
- int i;
- i = 0;
- while(*p) {
- sb_append_ch(out_sb, *p++);
- // Attempt to keep everything under 80 cols by splitting up lines
- if (i++ > 70 && *p && *(p-1) != '\\') {
- i = 0;
- sb_append_str(out_sb, "\"\n \"");
- sb_append_ch(out_sb, '\0');
- * ngt_embed - Turn one or more template files into C code for embedding into programs
-int ngt_embed(const char* code_template, FILE* out, int argc, char** argv) {
- int i;
- ngt_template* tpl;
- ngt_dictionary* dict;
- char* output;
- char file[PATH_MAX];
- char name[PATH_MAX];
- if (argc == 1) {
- fprintf(stderr, "USAGE: ngtembed file1[=name1] file2[=name2] ... fileN[=nameN] [>out_file]\n");
- return -1;
- tpl = ngt_new();
- dict = ngt_dictionary_new();
- ngt_add_modifier(tpl, "breakup_lines", _breakup_lines_modifier_cb);
- ngt_set_delimiters(tpl, "@", "@");
- ngt_set_dictionary(tpl, dict);
- tpl->template = (char*)code_template;
- for (i = 1; i < argc; i++) {
- char* p;
- int m, has_name;
- p = argv[i];
- m = 0;
- has_name = 0;
- while (*p) {
- if (m < PATH_MAX && *p == '=') {
- // Setting an explicit name. Throw out what we've done so far
- has_name = 1;
- m = 0;
- p++;
- continue;
- if (*p == '.' || *p == '\\' || *p == '/') {
- name[m] = '_';
- } else {
- name[m] = *p;
- if (!has_name) {
- file[m] = *p;
- file[m+1] = '\0';
- p++;
- m++;
- name[m] = '\0';
- if (m) {
- stringbuilder* sb;
- FILE* fd;
- int ch;
- fd = fopen(file, "r");
- if (!fd) {
- fprintf(stderr, "Could not open '%s' for reading\n", file);
- return -1;
- ngt_dictionary* section = ngt_dictionary_new();
- ngt_set_string(section, "TemplateName", name);
- sb = sb_new();
- while ((ch = fgetc(fd)) != EOF) {
- sb_append_ch(sb, (char)ch);
- ngt_set_string(section, "TemplateBody", sb_cstring(sb));
- sb_destroy(sb, 1);
- ngt_add_dictionary(dict, "Template", section, NGT_SECTION_VISIBLE);
- fclose(fd);
- ngt_expand(tpl, &output);
- fprintf(out, "%s\n", output);
- ngt_destroy(tpl);
- ngt_dictionary_destroy(dict);
- free(output);
\ No newline at end of file
More information about the mapserver-commits
