[mapserver-commits] r12460 - in trunk/mapserver/mapcache: include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:28:23 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:28:23 -0700 (Fri, 26 Aug 2011)
New Revision: 12460
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/fastcgi_geocache.c
trunk/mapserver/mapcache/src/mod_geocache.c
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:28:18 UTC (rev 12459)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:28:23 UTC (rev 12460)
@@ -885,6 +885,7 @@
* @return
void geocache_configuration_parse(geocache_context *ctx, const char *filename, geocache_cfg *config);
+void geocache_configuration_post_config(geocache_context *ctx, geocache_cfg *config);
void geocache_configuration_parse_json(geocache_context *ctx, const char *filename, geocache_cfg *config);
void parse_keyvalues(geocache_context *ctx, cJSON *node, apr_table_t *tbl);
void geocache_configuration_parse_xml(geocache_context *ctx, const char *filename, geocache_cfg *config);
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:28:18 UTC (rev 12459)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:28:23 UTC (rev 12460)
@@ -64,7 +64,9 @@
apr_table_setn(config->metadata,"url",url);
+void geocache_configuration_post_config(geocache_context *ctx, geocache_cfg *config) {
apr_hash_index_t *cachei = apr_hash_first(ctx->pool,config->caches);
while(cachei) {
geocache_cache *cache;
@@ -74,7 +76,9 @@
GC_CHECK_ERROR(ctx);
cachei = apr_hash_next(cachei);
geocache_cfg* geocache_configuration_create(apr_pool_t *pool) {
geocache_grid *grid;
int i;
Modified: trunk/mapserver/mapcache/src/fastcgi_geocache.c
--- trunk/mapserver/mapcache/src/fastcgi_geocache.c 2011-08-26 11:28:18 UTC (rev 12459)
+++ trunk/mapserver/mapcache/src/fastcgi_geocache.c 2011-08-26 11:28:23 UTC (rev 12460)
@@ -224,6 +224,11 @@
c->log(c,500,"failed to parse %s: %s",conffile,c->get_error_message(c));
return 1;
+ geocache_configuration_post_config(ctx, cfg);
+ if(GC_HAS_ERROR(c)) {
+ c->log(c,500,"post-config failed for %s: %s",conffile,c->get_error_message(c));
+ return 1;
while (FCGX_Accept(&in, &out, &err, &envp) >= 0) {
apr_table_t *params;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:28:18 UTC (rev 12459)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:28:23 UTC (rev 12460)
@@ -384,11 +384,12 @@
return report_error(apache_ctx);
+#define ap_unixd_setup_child unixd_setup_child
static int mod_geocache_post_config(apr_pool_t *p, apr_pool_t *plog, apr_pool_t *ptemp, server_rec *s) {
- apr_status_t rc;
+ apr_status_t rc,rv;
geocache_server_cfg* cfg = ap_get_module_config(s->module_config, &geocache_module);
apr_lockmech_e lock_type = APR_LOCK_DEFAULT;
+ server_rec *sconf;
if(!cfg) {
ap_log_error(APLOG_MARK, APLOG_CRIT, 0, s, "configuration not found in server context");
@@ -415,17 +416,63 @@
#ifndef DISABLE_VERSION_STRING
ap_add_version_component(p, GEOCACHE_USERAGENT);
#endif
- for (s = s->next; s; s = s->next) {
- geocache_server_cfg* config = ap_get_module_config(s->module_config, &geocache_module);
+ for (sconf = s->next; sconf; sconf = sconf->next) {
+ geocache_server_cfg* config = ap_get_module_config(sconf->module_config, &geocache_module);
config->mutex = cfg->mutex;
+ /* fork a child process to let it accomplish post-configuration tasks with the uid of the runtime user */
+ apr_proc_t proc;
+ rv = apr_proc_fork(&proc, ptemp);
+ if (rv == APR_INCHILD) {
+ ap_unixd_setup_child();
+ geocache_context *ctx = (geocache_context*)apache_server_context_create(s,ptemp);
+ for (sconf = s; sconf; sconf = sconf->next) {
+ if(config->aliases) {
+ apr_hash_index_t *entry = apr_hash_first(ptemp,config->aliases);
- return OK;
+ /* loop through the configured configurations */
+ while (entry) {
+ const char *alias;
+ apr_ssize_t aliaslen;
+ geocache_cfg *c;
+ apr_hash_this(entry,(const void**)&alias,&aliaslen,(void**)&c);
+ geocache_configuration_post_config(ctx, c);
+ if(GC_HAS_ERROR(ctx)) {
+ ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "post config for %s failed: %s", alias,
+ ctx->get_error_message(ctx));
+ exit(0);
+ entry = apr_hash_next(entry);
+ exit(0);
+ } else if (rv == APR_INPARENT) {
+ apr_exit_why_e exitwhy;
+ int exitcode;
+ apr_proc_wait(&proc,&exitcode,&exitwhy,APR_WAIT);
+ if(exitwhy != APR_PROC_EXIT) {
+ ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "geocache post-config child terminated abnormally");
+ } else {
+ if(exitcode != 0) {
+ return APR_EGENERAL;
+ return OK;
+ } else {
+ ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "failed to fork geocache post-config child");
static void mod_geocache_child_init(apr_pool_t *pool, server_rec *s) {
- geocache_server_cfg* cfg = ap_get_module_config(s->module_config, &geocache_module);
- apr_global_mutex_child_init(&(cfg->mutex),cfg->mutex_name, pool);
+ while(s) {
+ geocache_server_cfg* cfg = ap_get_module_config(s->module_config, &geocache_module);
+ apr_global_mutex_child_init(&(cfg->mutex),cfg->mutex_name, pool);
+ s = s->next;
static int geocache_alias_matches(const char *uri, const char *alias_fakename)
More information about the mapserver-commits
