[mapserver-commits] r12462 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:28:36 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:28:36 -0700 (Fri, 26 Aug 2011)
New Revision: 12462
trunk/mapserver/mapcache/Makefile.inc.in
trunk/mapserver/mapcache/geocache.json
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/cache_sqlite.c
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/configuration_json.c
trunk/mapserver/mapcache/src/configuration_xml.c
trunk/mapserver/mapcache/src/dimension.c
trunk/mapserver/mapcache/src/image.c
trunk/mapserver/mapcache/src/imageio.c
trunk/mapserver/mapcache/src/mod_geocache.c
trunk/mapserver/mapcache/src/service_wms.c
trunk/mapserver/mapcache/src/tileset.c
Modified: trunk/mapserver/mapcache/Makefile.inc.in
--- trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/Makefile.inc.in 2011-08-26 11:28:36 UTC (rev 12462)
@@ -54,7 +54,7 @@
MISC_ENABLED=@MISC_ENABLED@ -DTHREADED_MPM=$(shell $(HTTPD) -V | grep "Server MPM" | grep -q "Prefork"; echo $$?)
-INCLUDES=-I../include $(MISC_ENABLED) $(CURL_CFLAGS) $(PNG_INC) $(JPEG_INC) $(GDAL_INC) $(GEOS_INC) $(APR_INC) $(APU_INC) $(MEMCACHE_ENABLED) $(PCRE_CFLAGS) $(PCRE_ENABLED) $(OGR_ENABLED) $(GEOS_ENABLED) $(SQLITE_ENABLED) $(SQLITE_INC) $(PIXMAN_ENABLED) $(PIXMAN_ENABLED) $(PIXMAN_INC)
+INCLUDES=-I../include $(MISC_ENABLED) $(CURL_CFLAGS) $(PNG_INC) $(JPEG_INC) $(GDAL_INC) $(GEOS_INC) $(APR_INC) $(APU_INC) $(MEMCACHE_ENABLED) $(PCRE_CFLAGS) $(PCRE_ENABLED) $(OGR_ENABLED) $(GEOS_ENABLED) $(SQLITE_ENABLED) $(SQLITE_INC) $(PIXMAN_ENABLED) $(PIXMAN_INC)
LIBS=$(CURL_LIBS) $(PNG_LIB) $(JPEG_LIB) $(APR_LIBS) $(APU_LIBS) $(PCRE_LIBS) $(SQLITE_LIB) $(PIXMAN_LIB)
SEEDER_EXTRALIBS=$(GDAL_LIB) $(GEOS_LIB)
Modified: trunk/mapserver/mapcache/geocache.json
--- trunk/mapserver/mapcache/geocache.json 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/geocache.json 2011-08-26 11:28:36 UTC (rev 12462)
@@ -53,11 +53,11 @@
"sources": [
- "name":"test",
+ "name":"vmap0",
"type":"wms",
"props": {
"http": {
- "url":"http://localhost/xxxccv",
+ "url":"http://vmap0.tiles.osgeo.org/wms/vmap0",
"headers": {
"User-Agent":"mod-geocache/trunk",
"Referer":"http://foosite"
@@ -65,7 +65,8 @@
"getmap": {
"params":{
- "LAYERS":"basic"
+ "LAYERS":"basic",
+ "FORMAT":"image/png"
"getfeatureinfo": {
@@ -105,14 +106,14 @@
"tilesets": [
"name": "test",
- "source": "test",
+ "source": "vmap0",
"grids": [
"WGS84",
{ "ref":"g", "extent":[10,10,20,20]}
"wgs84_extent":[-180,-90,180,90],
"format": "png",
- "cache": "disk",
+ "cache": "sqlite",
"metatile": {
"size":[5,5],
"buffer":10
@@ -122,11 +123,13 @@
"auto": false
"dimensions": [
- "watermark":"/path/to/logo.png"
+ ,"watermark":"/home/tbonfort/dev/mod-geocache/static/watermark.png"
"services": [
+ { "type":"demo" },
+ { "type":"wms" }
"config": {
"error_reporting":"message",
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:28:36 UTC (rev 12462)
@@ -1155,7 +1155,10 @@
geocache_tileset* geocache_tileset_create(geocache_context *ctx);
+void geocache_tileset_configuration_check(geocache_context *ctx, geocache_tileset *tileset);
+void geocache_tileset_add_watermark(geocache_context *ctx, geocache_tileset *tileset, const char *filename);
* lock the tile
@@ -1307,6 +1310,7 @@
geocache_image* _geocache_imageio_png_decode(geocache_context *ctx, geocache_buffer *buffer);
+void geocache_image_create_empty(geocache_context *ctx, geocache_cfg *cfg);
* @param r
* @param buffer
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -282,6 +282,7 @@
geocache_cache *cache, geocache_cfg *cfg) {
sqlite3 *db;
char *errmsg;
+ int ret;
apr_hash_index_t *tileindex_index = apr_hash_first(ctx->pool,cfg->tilesets);
@@ -297,10 +298,15 @@
char *dbname = _get_dbname(ctx,(geocache_cache_sqlite*)cache,tileset,grid);
sqlite3_open(dbname, &db);
if(tileset->dimensions) {
- sqlite3_exec(db, "create table if not exists tiles(x integer, y integer, z integer, data blob, dim text, ctime datetime, atime datetime, hitcount integer default 0, primary key(x,y,z,dim))", 0, 0, &errmsg);
+ ret = sqlite3_exec(db, "create table if not exists tiles(x integer, y integer, z integer, data blob, dim text, ctime datetime, atime datetime, hitcount integer default 0, primary key(x,y,z,dim))", 0, 0, &errmsg);
} else {
- sqlite3_exec(db, "create table if not exists tiles(x integer, y integer, z integer, data blob, ctime datetime, atime datetime, hitcount integer default 0, primary key (x,y,z))", 0, 0, &errmsg);
+ ret = sqlite3_exec(db, "create table if not exists tiles(x integer, y integer, z integer, data blob, ctime datetime, atime datetime, hitcount integer default 0, primary key (x,y,z))", 0, 0, &errmsg);
+ if(ret != SQLITE_OK) {
+ ctx->set_error(ctx,500,"sqlite backend failed to create tiles table: %s",sqlite3_errmsg(db));
+ sqlite3_close(db);
+ return;
sqlite3_close(db);
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -24,6 +24,7 @@
} else {
geocache_configuration_parse_xml(ctx,filename,config);
+ GC_CHECK_ERROR(ctx);
if(!config->lockdir || !strlen(config->lockdir)) {
config->lockdir = apr_pstrdup(ctx->pool, "/tmp");
Modified: trunk/mapserver/mapcache/src/configuration_json.c
--- trunk/mapserver/mapcache/src/configuration_json.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/configuration_json.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -272,6 +272,59 @@
+static void parse_dimension_json(geocache_context *ctx, cJSON *node, geocache_tileset *tileset) {
+ char *type = NULL;
+ cJSON *tmp;
+ geocache_dimension *dimension;
+ tmp = cJSON_GetObjectItem(node,"type");
+ if(tmp) type = tmp->valuestring;
+ if(!type || !strlen(type)) {
+ ctx->set_error(ctx, 400, "mandatory \"type\" not found in dimension for tileset %s", tileset->name);
+ return;
+ if(!strcmp(type,"values")) {
+ dimension = geocache_dimension_values_create(ctx->pool);
+ } else if(!strcmp(type,"regex")) {
+ dimension = geocache_dimension_regex_create(ctx->pool);
+ } else if(!strcmp(type,"intervals")) {
+ dimension = geocache_dimension_intervals_create(ctx->pool);
+ } else if(!strcmp(type,"time")) {
+ ctx->set_error(ctx,501,"time dimension type not implemented yet");
+ return;
+ dimension = geocache_dimension_time_create(ctx->pool);
+ } else {
+ ctx->set_error(ctx,400,"unknown dimension type \"%s\"",type);
+ return;
+ tmp = cJSON_GetObjectItem(node,"unit");
+ if(tmp &&tmp->valuestring) {
+ dimension->unit = apr_pstrdup(ctx->pool,tmp->valuestring);
+ tmp = cJSON_GetObjectItem(node,"name");
+ if(tmp && tmp->valuestring) {
+ dimension->name = apr_pstrdup(ctx->pool,tmp->valuestring);
+ tmp = cJSON_GetObjectItem(node,"default");
+ dimension->default_value = apr_pstrdup(ctx->pool,tmp->valuestring);
+ tmp = cJSON_GetObjectItem(node,"props");
+ if(!tmp || tmp->type != cJSON_Object) {
+ ctx->set_error(ctx, 400, "mandatory \"props\" not found in dimension %s for tileset %s",
+ dimension->name, tileset->name);
+ return;
+ } else {
+ dimension->configuration_parse_json(ctx,dimension,tmp);
static void parse_tileset_json(geocache_context *ctx, cJSON *node, geocache_cfg *cfg) {
char *name = NULL;
cJSON *tmp;
@@ -305,11 +358,156 @@
+ tmp = cJSON_GetObjectItem(node,"grids");
+ if(tmp && cJSON_GetArraySize(tmp)) {
+ tileset->grid_links = apr_array_make(ctx->pool,1,sizeof(geocache_grid_link*));
+ int i;
+ for(i=0;i<cJSON_GetArraySize(tmp);i++) {
+ cJSON *jgrid = cJSON_GetArrayItem(tmp,i);
+ cJSON *jchild;
+ char *gridname;
+ geocache_grid_link *gridlink = apr_pcalloc(ctx->pool,sizeof(geocache_grid_link));
+ switch(jgrid->type) {
+ case cJSON_String:
+ gridname = jgrid->valuestring;
+ break;
+ case cJSON_Object:
+ jchild = cJSON_GetObjectItem(jgrid,"ref");
+ if(!jchild || jchild->type != cJSON_String || !jchild->valuestring) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" references grid with no \"ref\"",name);
+ return;
+ gridname = jchild->valuestring;
+ jchild = cJSON_GetObjectItem(jgrid,"extent");
+ if(jchild) {
+ gridlink->restricted_extent = apr_pcalloc(ctx->pool,4*sizeof(double));
+ parse_extent_json(ctx,jchild,gridlink->restricted_extent);
+ break;
+ default:
+ ctx->set_error(ctx, 400, "tileset grid can either be a string or a {\"ref\":\"gridname\",\"extent\":{minx,miny,maxx,maxy} for tileset %s",name);
+ return;
+ geocache_grid *grid = geocache_configuration_get_grid(cfg,gridname);
+ if(!grid) {
+ ctx->set_error(ctx, 400, "tileset %s references unknown grid \"%s\"",name,gridname);
+ return;
+ gridlink->grid = grid;
+ gridlink->grid_limits = apr_pcalloc(ctx->pool,grid->nlevels*sizeof(int*));
+ for(i=0;i<grid->nlevels;i++) {
+ gridlink->grid_limits[i] = apr_pcalloc(ctx->pool,4*sizeof(int));
+ double *extent;
+ if(gridlink->restricted_extent &&
+ gridlink->restricted_extent[2]>gridlink->restricted_extent[0] &&
+ gridlink->restricted_extent[3]>gridlink->restricted_extent[1]) {
+ extent = gridlink->restricted_extent;
+ } else {
+ extent = grid->extent;
+ geocache_grid_compute_limits(grid,extent,gridlink->grid_limits);
+ /* compute wgs84 bbox if it wasn't supplied already */
+ if(tileset->wgs84bbox[0] >= tileset->wgs84bbox[2] &&
+ !strcasecmp(grid->srs,"EPSG:4326")) {
+ tileset->wgs84bbox[0] = extent[0];
+ tileset->wgs84bbox[1] = extent[1];
+ tileset->wgs84bbox[2] = extent[2];
+ tileset->wgs84bbox[3] = extent[3];
+ APR_ARRAY_PUSH(tileset->grid_links,geocache_grid_link*) = gridlink;
+ } else {
+ ctx->set_error(ctx, 400, "tileset \"%s\" references no grids",name);
+ return;
+ tmp = cJSON_GetObjectItem(node,"cache");
+ if(!tmp || !tmp->valuestring) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" references no cache",name);
+ return;
+ } else {
+ tileset->cache = geocache_configuration_get_cache(cfg,tmp->valuestring);
+ if(!tileset->cache) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" references invalid cache \"%s\"",name,tmp->valuestring);
+ return;
+ tmp = cJSON_GetObjectItem(node,"source");
+ ctx->set_error(ctx, 400, "tileset \"%s\" references no source",name);
+ return;
+ } else {
+ tileset->source = geocache_configuration_get_source(cfg,tmp->valuestring);
+ if(!tileset->source) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" references invalid source \"%s\"",name,tmp->valuestring);
+ return;
+ tmp = cJSON_GetObjectItem(node,"format");
+ tileset->format = geocache_configuration_get_image_format(cfg,tmp->valuestring);
+ if(!tileset->format) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" references invalid format \"%s\"",name,tmp->valuestring);
+ return;
+ //dimensions
+ tmp = cJSON_GetObjectItem(node,"dimensions");
+ if(tmp) {
+ int i;
+ cJSON *item = cJSON_GetArrayItem(tmp,i);
+ parse_dimension_json(ctx,item,tileset);
+ //metatile
+ tmp = cJSON_GetObjectItem(node,"metatile");
+ if(tmp && tmp->type == cJSON_Object) {
+ cJSON *e = cJSON_GetObjectItem(tmp,"size");
+ if(e->type == cJSON_Array && cJSON_GetArraySize(e) == 2 ) {
+ tileset->metasize_x = cJSON_GetArrayItem(e,0)->valueint;
+ tileset->metasize_y = cJSON_GetArrayItem(e,1)->valueint;
+ e = cJSON_GetObjectItem(tmp,"buffer");
+ if(e && e->type == cJSON_Number) {
+ tileset->metabuffer = e->valueint;
+ //watermark
+ tmp = cJSON_GetObjectItem(node,"watermark");
+ geocache_tileset_add_watermark(ctx,tileset,tmp->valuestring);
+ //expire and auto_expire
+ tmp = cJSON_GetObjectItem(node,"expires");
+ cJSON *e = cJSON_GetObjectItem(tmp,"delay");
+ if(e->type == cJSON_Number) {
+ tileset->expires = e->valueint;
+ e = cJSON_GetObjectItem(tmp,"auto");
+ if(e->type == cJSON_True) {
+ tileset->auto_expire = tileset->expires;
+ geocache_tileset_configuration_check(ctx,tileset);
+ geocache_configuration_add_tileset(cfg,tileset,name);
static void parse_format_json(geocache_context *ctx, cJSON *node, geocache_cfg *cfg) {
char *name = NULL, *type = NULL;
@@ -427,7 +625,55 @@
geocache_configuration_add_image_format(cfg,format,name);
-static void parse_service_json(geocache_context *ctx, cJSON *node, geocache_cfg *cfg) {
+static void parse_service_json(geocache_context *ctx, cJSON *node, geocache_cfg *config) {
+ cJSON *tmp = cJSON_GetObjectItem(node,"type");
+ ctx->set_error(ctx, 400, "mandatory attribute \"type\" not found in service");
+ return;
+ tmp = cJSON_GetObjectItem(node,"enabled");
+ if(tmp && tmp->type == cJSON_False) {
+ return;
+ geocache_service *new_service;
+ if (!strcasecmp(type,"wms")) {
+ new_service = geocache_service_wms_create(ctx);
+ config->services[GEOCACHE_SERVICE_WMS] = new_service;
+ else if (!strcasecmp(type,"tms")) {
+ new_service = geocache_service_tms_create(ctx);
+ config->services[GEOCACHE_SERVICE_TMS] = new_service;
+ else if (!strcasecmp(type,"wmts")) {
+ new_service = geocache_service_wmts_create(ctx);
+ config->services[GEOCACHE_SERVICE_WMTS] = new_service;
+ else if (!strcasecmp(type,"kml")) {
+ new_service = geocache_service_kml_create(ctx);
+ config->services[GEOCACHE_SERVICE_KML] = new_service;
+ else if (!strcasecmp(type,"gmaps")) {
+ new_service = geocache_service_gmaps_create(ctx);
+ config->services[GEOCACHE_SERVICE_GMAPS] = new_service;
+ else if (!strcasecmp(type,"ve")) {
+ new_service = geocache_service_ve_create(ctx);
+ config->services[GEOCACHE_SERVICE_VE] = new_service;
+ else if (!strcasecmp(type,"demo")) {
+ new_service = geocache_service_demo_create(ctx);
+ config->services[GEOCACHE_SERVICE_DEMO] = new_service;
+ } else {
+ ctx->set_error(ctx,400,"unknown <service> type %s",type);
+ if(tmp && new_service->configuration_parse_json) {
+ new_service->configuration_parse_json(ctx,tmp,new_service);
@@ -479,6 +725,14 @@
if(GC_HAS_ERROR(ctx)) goto cleanup;
+ entry = cJSON_GetObjectItem(root,"formats");
+ if(entry) {
+ for(i=0;i<cJSON_GetArraySize(entry);i++) {
+ item = cJSON_GetArrayItem(entry,i);
+ parse_format_json(ctx,item,config);
+ if(GC_HAS_ERROR(ctx)) goto cleanup;
entry = cJSON_GetObjectItem(root,"tilesets");
if(entry) {
@@ -492,14 +746,6 @@
parse_keyvalues(ctx, entry, config->metadata);
- entry = cJSON_GetObjectItem(root,"formats");
- if(entry) {
- for(i=0;i<cJSON_GetArraySize(entry);i++) {
- item = cJSON_GetArrayItem(entry,i);
- parse_format_json(ctx,item,config);
- if(GC_HAS_ERROR(ctx)) goto cleanup;
entry = cJSON_GetObjectItem(root,"services");
if(entry) {
@@ -510,12 +756,46 @@
entry = cJSON_GetObjectItem(root,"config");
if(entry) {
+ /* directory where to store temporary lock files */
+ cJSON *tmp = cJSON_GetObjectItem(entry,"lock_dir");
+ config->lockdir = apr_pstrdup(ctx->pool,tmp->valuestring);
+ /* error reporting */
+ tmp = cJSON_GetObjectItem(entry,"errors");
+ if(!strcmp(tmp->valuestring,"log")) {
+ config->reporting = GEOCACHE_REPORT_LOG;
+ } else if(!strcmp(tmp->valuestring,"report")) {
+ config->reporting = GEOCACHE_REPORT_MSG;
+ } else if(!strcmp(tmp->valuestring,"empty_img")) {
+ config->reporting = GEOCACHE_REPORT_EMPTY_IMG;
+ geocache_image_create_empty(ctx, config);
+ } else if(!strcmp(tmp->valuestring, "report_img")) {
+ config->reporting = GEOCACHE_REPORT_ERROR_IMG;
+ ctx->set_error(ctx,501,"<errors>: report_img not implemented");
+ goto cleanup;
+ } else {
+ ctx->set_error(ctx,400,"<errors>: unknown value %s (allowed are log, report, empty_img, report_img)",
+ tmp->valuestring);
+ goto cleanup;
/* lock_dir, error_reporting */
+ /* final checks */
+ if(!config->lockdir) {
+ config->lockdir = apr_pstrdup(ctx->pool,"/tmp");
cleanup:
- cJSON_Delete(root);
+ //cJSON_Delete(root);
fclose(f);
- free(filedata);
+ //free(filedata);
Modified: trunk/mapserver/mapcache/src/configuration_xml.c
--- trunk/mapserver/mapcache/src/configuration_xml.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/configuration_xml.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -569,31 +569,7 @@
ctx->set_error(ctx,400, "watermark config entry empty");
return;
- apr_file_t *f;
- apr_finfo_t finfo;
- int rv;
- if(apr_file_open(&f, cur_node->txt, APR_FOPEN_READ|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
- APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
- ctx->set_error(ctx,500, "failed to open watermark image %s",cur_node->txt);
- return;
- rv = apr_file_info_get(&finfo, APR_FINFO_SIZE, f);
- if(!finfo.size) {
- ctx->set_error(ctx, 500, "watermark %s has no data",cur_node->txt);
- return;
- geocache_buffer *watermarkdata = geocache_buffer_create(finfo.size,ctx->pool);
- //manually add the data to our buffer
- apr_size_t size;
- apr_file_read(f,(void*)watermarkdata->buf,&size);
- watermarkdata->size = size;
- if(size != finfo.size) {
- ctx->set_error(ctx, 500, "failed to copy watermark image data, got %d of %d bytes",(int)size, (int)finfo.size);
- return;
- apr_file_close(f);
- tileset->watermark = geocache_imageio_decode(ctx,watermarkdata);
+ geocache_tileset_add_watermark(ctx,tileset,cur_node->txt);
@@ -642,55 +618,9 @@
tileset->format = format;
- if(!tileset->format && tileset->source->type == GEOCACHE_SOURCE_GDAL) {
- ctx->set_error(ctx,400, "tileset \"%s\" references a gdal source. <format> tag is missing and mandatory in this case",
- tileset->name);
- return;
- /* check we have all we want */
- if(tileset->cache == NULL) {
- /* TODO: we should allow tilesets with no caches */
- ctx->set_error(ctx, 400, "tileset \"%s\" has no cache configured."
- " You must add a <cache> tag.", tileset->name);
- return;
- if(tileset->source == NULL) {
- ctx->set_error(ctx, 400, "tileset \"%s\" has no source configured."
- " You must add a <source> tag.", tileset->name);
- return;
- if(apr_is_empty_array(tileset->grid_links)) {
- ctx->set_error(ctx, 400, "tileset \"%s\" has no grids configured."
- " You must add a <grid> tag.", tileset->name);
- return;
- } else if(!havewgs84bbox) {
-#ifdef USE_PROJ
- geocache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,0,geocache_grid_link*);
- double *extent = sgrid->grid->extent;
- if(sgrid->restricted_extent) {
- extent = sgrid->restricted_extent;
-#endif
- if(!tileset->format && (
- tileset->metasize_x != 1 ||
- tileset->metasize_y != 1 ||
- tileset->metabuffer != 0 ||
- tileset->watermark)) {
- if(tileset->watermark) {
- ctx->set_error(ctx,400,"tileset \"%s\" has no <format> configured, but it is needed for the watermark",
- tileset->name);
- return;
- } else {
- ctx->set_error(ctx,400,"tileset \"%s\" has no <format> configured, but it is needed for metatiling",
- tileset->name);
- return;
geocache_configuration_add_tileset(config,tileset,name);
return;
@@ -749,15 +679,6 @@
-static void createEmptyImages(geocache_context *ctx, geocache_cfg *cfg) {
- unsigned int color=0;
- if(!strstr(cfg->merge_format->mime_type,"png")) {
- color = 0xffffffff;
- cfg->empty_image = cfg->merge_format->create_empty_image(ctx, cfg->merge_format,
- 256,256, color);
- GC_CHECK_ERROR(ctx);
void geocache_configuration_parse_xml(geocache_context *ctx, const char *filename, geocache_cfg *config) {
ezxml_t doc, node;
@@ -895,7 +816,7 @@
} else if(!strcmp(node->txt,"empty_img")) {
- createEmptyImages(ctx, config);
} else if(!strcmp(node->txt, "report_img")) {
Modified: trunk/mapserver/mapcache/src/dimension.c
--- trunk/mapserver/mapcache/src/dimension.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/dimension.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -54,6 +54,10 @@
return ret;
+static void _geocache_dimension_intervals_parse_json(geocache_context *ctx, geocache_dimension *dim,
+ cJSON *node) {
static void _geocache_dimension_intervals_parse_xml(geocache_context *ctx, geocache_dimension *dim,
ezxml_t node) {
const char *entry = node->txt;
@@ -123,6 +127,38 @@
return ret;
+static void _geocache_dimension_regex_parse_json(geocache_context *ctx, geocache_dimension *dim,
+ cJSON *node) {
+ geocache_dimension_regex *dimension = (geocache_dimension_regex*)dim;
+ cJSON *tmp = cJSON_GetObjectItem(node,"regex");
+ if(tmp && tmp->valuestring && *(tmp->valuestring)) {
+ dimension->regex_string = apr_pstrdup(ctx->pool,tmp->valuestring);
+#ifdef USE_PCRE
+ const char *pcre_err;
+ int pcre_offset;
+ dimension->pcregex = pcre_compile(dimension->regex_string,0,&pcre_err, &pcre_offset,0);
+ if(!dimension->pcregex) {
+ ctx->set_error(ctx,400,"failed to compile regular expression \"%s\" for dimension \"%s\": %s",
+ dimension->regex_string,dim->name,pcre_err);
+ return;
+#else
+ int rc = regcomp(dimension->regex, dimension->regex_string, REG_EXTENDED);
+ if(rc) {
+ char errmsg[200];
+ regerror(rc,dimension->regex,errmsg,200);
+ dimension->regex_string,dim->name,errmsg);
+ return;
+#endif
+ if(!dimension->regex_string) {
+ ctx->set_error(ctx,400,"failed to parse dimension \"%s\" regex: none supplied", dim->name);
+ return;
static void _geocache_dimension_regex_parse_xml(geocache_context *ctx, geocache_dimension *dim,
ezxml_t node) {
@@ -180,6 +216,33 @@
return ret;
+static void _geocache_dimension_values_parse_json(geocache_context *ctx, geocache_dimension *dim,
+ cJSON *node) {
+ cJSON *tmp;
+ geocache_dimension_values *dimension = (geocache_dimension_values*)dim;
+ tmp = cJSON_GetObjectItem(node,"values");
+ if(tmp) {
+ int i;
+ dimension->values = (char**)apr_pcalloc(ctx->pool,cJSON_GetArraySize(tmp)*sizeof(char*));
+ if(!tmp->valuestring || !*(tmp->valuestring)) {
+ ctx->set_error(ctx,400,"invalid value for dimension %s",dim->name);
+ return;
+ dimension->values[dimension->nvalues]=apr_pstrdup(ctx->pool,tmp->valuestring);
+ dimension->nvalues++;
+ tmp = cJSON_GetObjectItem(node,"case_sensitive");
+ if(tmp && tmp->type == cJSON_True) {
+ dimension->case_sensitive = 1;
+ if(!dimension->nvalues) {
+ ctx->set_error(ctx, 400, "dimension \"%s\" has no values",dim->name);
+ return;
static void _geocache_dimension_values_parse_xml(geocache_context *ctx, geocache_dimension *dim,
ezxml_t node) {
int count = 1;
@@ -218,6 +281,7 @@
dimension->nvalues = 0;
dimension->dimension.validate = _geocache_dimension_values_validate;
dimension->dimension.configuration_parse_xml = _geocache_dimension_values_parse_xml;
+ dimension->dimension.configuration_parse_json = _geocache_dimension_values_parse_json;
dimension->dimension.print_ogc_formatted_values = _geocache_dimension_values_print;
return (geocache_dimension*)dimension;
@@ -238,6 +302,7 @@
dimension->nintervals = 0;
dimension->dimension.validate = _geocache_dimension_intervals_validate;
dimension->dimension.configuration_parse_xml = _geocache_dimension_intervals_parse_xml;
+ dimension->dimension.configuration_parse_json = _geocache_dimension_intervals_parse_json;
dimension->dimension.print_ogc_formatted_values = _geocache_dimension_intervals_print;
@@ -249,6 +314,7 @@
#endif
dimension->dimension.validate = _geocache_dimension_regex_validate;
dimension->dimension.configuration_parse_xml = _geocache_dimension_regex_parse_xml;
+ dimension->dimension.configuration_parse_json = _geocache_dimension_regex_parse_json;
dimension->dimension.print_ogc_formatted_values = _geocache_dimension_regex_print;
Modified: trunk/mapserver/mapcache/src/image.c
--- trunk/mapserver/mapcache/src/image.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/image.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -61,7 +61,7 @@
pixman_int_to_fixed(-startj),
pixman_int_to_fixed(-starti));
pixman_image_set_filter(si,PIXMAN_FILTER_NEAREST, NULL, 0);
- pixman_image_composite32 (PIXMAN_OP_OVER, si, si, bi,
+ pixman_image_composite (PIXMAN_OP_OVER, si, si, bi,
0, 0, 0, 0, 0, 0, base->w,base->h);
pixman_image_unref(si);
pixman_image_unref(bi);
Modified: trunk/mapserver/mapcache/src/imageio.c
--- trunk/mapserver/mapcache/src/imageio.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/imageio.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -57,6 +57,17 @@
+void geocache_image_create_empty(geocache_context *ctx, geocache_cfg *cfg) {
+ unsigned int color=0;
+ if(!strstr(cfg->merge_format->mime_type,"png")) {
+ color = 0xffffffff;
+ cfg->empty_image = cfg->merge_format->create_empty_image(ctx, cfg->merge_format,
+ 256,256, color);
void geocache_imageio_decode_to_image(geocache_context *ctx, geocache_buffer *buffer,
geocache_image *image) {
geocache_image_format_type type = geocache_imageio_header_sniff(ctx,buffer);
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -421,13 +421,12 @@
config->mutex = cfg->mutex;
-#ifdef EXPERIMENTAL_POST_CONFIG
/* fork a child process to let it accomplish post-configuration tasks with the uid of the runtime user */
apr_proc_t proc;
rv = apr_proc_fork(&proc, ptemp);
if (rv == APR_INCHILD) {
ap_unixd_setup_child();
- geocache_context *ctx = (geocache_context*)apache_server_context_create(s,ptemp);
+ geocache_context *ctx = (geocache_context*)apache_server_context_create(s,p);
for (sconf = s; sconf; sconf = sconf->next) {
geocache_server_cfg* config = ap_get_module_config(sconf->module_config, &geocache_module);
if(config->aliases) {
@@ -443,7 +442,7 @@
if(GC_HAS_ERROR(ctx)) {
ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "post config for %s failed: %s", alias,
ctx->get_error_message(ctx));
- exit(0);
+ exit(APR_EGENERAL);
entry = apr_hash_next(entry);
@@ -456,6 +455,7 @@
apr_proc_wait(&proc,&exitcode,&exitwhy,APR_WAIT);
if(exitwhy != APR_PROC_EXIT) {
ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "geocache post-config child terminated abnormally");
+ return APR_EGENERAL;
} else {
if(exitcode != 0) {
@@ -466,9 +466,6 @@
ap_log_error(APLOG_MARK, APLOG_CRIT, APR_EGENERAL, s, "failed to fork geocache post-config child");
-#else
- return OK;
-#endif
static void mod_geocache_child_init(apr_pool_t *pool, server_rec *s) {
@@ -604,12 +601,6 @@
return ctx->get_error_message(ctx);
-#ifndef EXPERIMENTAL_POST_CONFIG
- geocache_configuration_post_config(ctx,config);
- if(GC_HAS_ERROR(ctx)) {
- return ctx->get_error_message(ctx);
-#endif
ap_log_error(APLOG_MARK, APLOG_INFO, 0, cmd->server, "loaded geocache configuration file from %s on alias %s", config->configFile, alias);
if(!sconfig->aliases) {
sconfig->aliases = apr_hash_make(cmd->pool);
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -767,6 +767,11 @@
#endif
+void _configuration_parse_wms_json(geocache_context *ctx, cJSON *node, geocache_service *gservice) {
+ assert(gservice->type == GEOCACHE_SERVICE_WMS);
+ geocache_service_wms *wms = (geocache_service_wms*)gservice;
void _configuration_parse_wms_xml(geocache_context *ctx, ezxml_t node, geocache_service *gservice) {
@@ -842,6 +847,7 @@
service->service.parse_request = _geocache_service_wms_parse_request;
service->service.create_capabilities_response = _create_capabilities_wms;
service->service.configuration_parse_xml = _configuration_parse_wms_xml;
+ service->service.configuration_parse_json = _configuration_parse_wms_json;
return (geocache_service*)service;
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:28:26 UTC (rev 12461)
+++ trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:28:36 UTC (rev 12462)
@@ -18,7 +18,90 @@
#include <apr_strings.h>
#include <math.h>
+void geocache_tileset_configuration_check(geocache_context *ctx, geocache_tileset *tileset) {
+ /* check we have all we want */
+ if(tileset->cache == NULL) {
+ /* TODO: we should allow tilesets with no caches */
+ ctx->set_error(ctx, 400, "tileset \"%s\" has no cache configured.", tileset->name);
+ return;
+ if(tileset->source == NULL) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" has no source configured.", tileset->name);
+ return;
+ if(apr_is_empty_array(tileset->grid_links)) {
+ ctx->set_error(ctx, 400, "tileset \"%s\" has no grids configured", tileset->name);
+ return;
+#ifdef USE_PROJ
+ /* not implemented yet, will be used to automatically calculate wgs84bbox with proj */
+ else if(tileset->wgs84bbox[0]>=tileset->wgs84bbox[2]) {
+ geocache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,0,geocache_grid_link*);
+ double *extent = sgrid->grid->extent;
+ if(sgrid->restricted_extent) {
+ extent = sgrid->restricted_extent;
+#endif
+ if(!tileset->format && tileset->source->type == GEOCACHE_SOURCE_GDAL) {
+ ctx->set_error(ctx,400, "tileset \"%s\" references a gdal source. <format> tag is missing and mandatory in this case",
+ tileset->name);
+ return;
+ if(tileset->metabuffer < 0 || tileset->metasize_x < 1 || tileset->metasize_y < 1) {
+ ctx->set_error(ctx,400,"tileset \"%s\" has invalid metasize %d,%d or metabuffer %d",
+ tileset->name,tileset->metasize_x,tileset->metasize_y,tileset->metabuffer);
+ return;
+ if(!tileset->format && (
+ tileset->metasize_x != 1 ||
+ tileset->metasize_y != 1 ||
+ tileset->metabuffer != 0 ||
+ tileset->watermark)) {
+ if(tileset->watermark) {
+ ctx->set_error(ctx,400,"tileset \"%s\" has no <format> configured, but it is needed for the watermark",
+ tileset->name);
+ return;
+ } else {
+ ctx->set_error(ctx,400,"tileset \"%s\" has no <format> configured, but it is needed for metatiling",
+ tileset->name);
+ return;
+void geocache_tileset_add_watermark(geocache_context *ctx, geocache_tileset *tileset, const char *filename) {
+ apr_file_t *f;
+ apr_finfo_t finfo;
+ int rv;
+ if(apr_file_open(&f, filename, APR_FOPEN_READ|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
+ APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
+ ctx->set_error(ctx,500, "failed to open watermark image %s",filename);
+ return;
+ rv = apr_file_info_get(&finfo, APR_FINFO_SIZE, f);
+ if(!finfo.size) {
+ ctx->set_error(ctx, 500, "watermark %s has no data",filename);
+ return;
+ geocache_buffer *watermarkdata = geocache_buffer_create(finfo.size,ctx->pool);
+ //manually add the data to our buffer
+ apr_size_t size = finfo.size;
+ apr_file_read(f,watermarkdata->buf,&size);
+ watermarkdata->size = size;
+ if(size != finfo.size) {
+ ctx->set_error(ctx, 500, "failed to copy watermark image data, got %d of %d bytes",(int)size, (int)finfo.size);
+ return;
+ apr_file_close(f);
+ tileset->watermark = geocache_imageio_decode(ctx,watermarkdata);
void geocache_tileset_tile_validate(geocache_context *ctx, geocache_tile *tile) {
if(tile->z < 0 || tile->z >= tile->grid_link->grid->nlevels) {
ctx->set_error(ctx,404,"invalid tile z level");
More information about the mapserver-commits
