[mapserver-commits] r12470 - in trunk/mapserver/mapcache: . src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:29:31 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:29:31 -0700 (Fri, 26 Aug 2011)
New Revision: 12470
trunk/mapserver/mapcache/configure.in
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/configuration_json.c
trunk/mapserver/mapcache/src/core.c
trunk/mapserver/mapcache/src/geocache_seed.c
trunk/mapserver/mapcache/src/tileset.c
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2011-08-26 11:29:19 UTC (rev 12469)
+++ trunk/mapserver/mapcache/configure.in 2011-08-26 11:29:31 UTC (rev 12470)
@@ -239,6 +239,44 @@
+AC_DEFUN([MEMCACHE_CHECK],[
+ AC_ARG_ENABLE(memcache,
+ AC_HELP_STRING([--enable-memcache],[Enable memcache backend]),
+ [enable_memcache=yes]
+ AC_SUBST(MEMCACHE_ENABLED)
+ if test "$enable_memcache" == "yes"; then
+ if test -z "$APUCONFIG"; then
+ AC_MSG_ERROR(memcache check failed: apu-config utility not found)
+ fi
+ OLDLDFLAGS="$LDFLAGS" ; LDFLAGS="$LDFLAGS `$APUCONFIG --ldflags --libs --link-ld`"
+ OLDCPPFLAGS="$CPPFLAGS" ; CPPFLAGS="$CPPFLAGS `$APUCONFIG --includes`"
+ #check we can link against the memcache functions (i.e. is apr-util recent enough)
+ AC_CHECK_LIB(aprutil-1, apr_memcache_hash,[MEMCACHE_ENABLED=[-DUSE_MEMCACHE]],)
+ if test -z "$APU_LIBS"; then
+ AC_CHECK_LIB(aprutil, apr_memcache_hash,[MEMCACHE_ENABLED=[-DUSE_MEMCACHE]],)
+ fi
+ if test -n "$MEMCACHE_ENABLED"; then
+ #we managed to link against the memcache functions. are the headers available?
+ AC_CHECK_HEADER([apr_memcache.h],,
+ AC_MSG_WARN([apr-util contains memcache functions, but the headers where not found. memcache cache backend disabled])
+ MEMCACHE_ENABLED=""
+ else
+ AC_MSG_WARN([supplied apr-util does not contain memcache functions. memcache cache backend disabled])
+ fi
+ CPPFLAGS="$OLDCPPFLAGS"
+ LDFLAGS="$OLDLDFLAGS"
+ fi
AC_DEFUN([APU_CHECK],[
AC_SUBST(APUCONFIG)
@@ -287,27 +325,12 @@
fi
fi
- AC_MSG_ERROR(apu-config utility not found)
+ AC_MSG_ERROR(apu-config utility not found)
else
- OLDLDFLAGS="$LDFLAGS" ; LDFLAGS="$LDFLAGS `$APUCONFIG --ldflags --libs --link-ld`"
- OLDCPPFLAGS="$CPPFLAGS" ; CPPFLAGS="$CPPFLAGS `$APUCONFIG --includes`"
- AC_CHECK_LIB(aprutil-1, apr_memcache_hash,[APU_LIBS=`$APUCONFIG --link-libtool`],)
- if test -z "$APU_LIBS"; then
- AC_CHECK_LIB(aprutil, apr_memcache_hash,[APU_LIBS=`$APUCONFIG --link-libtool`],
- [AC_MSG_ERROR([unable to link to apr-util])])
- fi
- if test -n "$APU_LIBS"; then
- AC_CHECK_HEADER([apr_memcache.h],[
- MEMCACHE_ENABLED=[-DUSE_MEMCACHE]
- APU_INC=`$APUCONFIG --includes`
- [AC_MSG_WARN([apr_memcache.h not found, memcache cache backend disabled])])
- fi
- CPPFLAGS="$OLDCPPFLAGS"
- LDFLAGS="$OLDLDFLAGS"
+ APU_LIBS=`$APUCONFIG --link-libtool`
+ APU_INC=`$APUCONFIG --includes`
fi
AC_SUBST(APUCONFIG)
- AC_SUBST(MEMCACHE_ENABLED)
AC_SUBST(APU_INC)
AC_SUBST(APU_LIBS)
@@ -789,6 +812,7 @@
APR_CHECK
APU_CHECK
+MEMCACHE_CHECK
SQLITE_CHECK
PKGCONFIG_CHECK
# CAIRO_CHECK
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:29:19 UTC (rev 12469)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:29:31 UTC (rev 12470)
@@ -15,6 +15,9 @@
#include "geocache.h"
+#include <apr_file_info.h>
+#include <apr_strings.h>
+#include <apr_file_io.h>
void geocache_configuration_parse(geocache_context *ctx, const char *filename, geocache_cfg *config) {
int len = strlen(filename);
Modified: trunk/mapserver/mapcache/src/configuration_json.c
--- trunk/mapserver/mapcache/src/configuration_json.c 2011-08-26 11:29:19 UTC (rev 12469)
+++ trunk/mapserver/mapcache/src/configuration_json.c 2011-08-26 11:29:31 UTC (rev 12470)
@@ -1,7 +1,7 @@
#include <errno.h>
static void parse_extent_json(geocache_context *ctx, cJSON *node, double *extent) {
int i = cJSON_GetArraySize(node);
if(i != 4) {
Modified: trunk/mapserver/mapcache/src/core.c
--- trunk/mapserver/mapcache/src/core.c 2011-08-26 11:29:19 UTC (rev 12469)
+++ trunk/mapserver/mapcache/src/core.c 2011-08-26 11:29:31 UTC (rev 12470)
@@ -14,6 +14,7 @@
* limitations under the License.
geocache_tile *geocache_core_get_tile(geocache_context *ctx, geocache_request_get_tile *req_tile) {
Modified: trunk/mapserver/mapcache/src/geocache_seed.c
--- trunk/mapserver/mapcache/src/geocache_seed.c 2011-08-26 11:29:19 UTC (rev 12469)
+++ trunk/mapserver/mapcache/src/geocache_seed.c 2011-08-26 11:29:31 UTC (rev 12470)
@@ -7,6 +7,7 @@
#include <sys/time.h>
#include <apr_time.h>
#include <apr_queue.h>
#if defined(USE_OGR) && defined(USE_GEOS)
#define USE_CLIPPERS
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:29:19 UTC (rev 12469)
+++ trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:29:31 UTC (rev 12470)
@@ -16,6 +16,8 @@
#include <math.h>
void geocache_tileset_configuration_check(geocache_context *ctx, geocache_tileset *tileset) {
More information about the mapserver-commits
