[mapserver-commits] r12473 - trunk/mapserver/mapcache/src
Fri Aug 26 07:29:44 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:29:44 -0700 (Fri, 26 Aug 2011)
New Revision: 12473
   trunk/mapserver/mapcache/src/cache_sqlite.c
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c	2011-08-26 11:29:40 UTC (rev 12472)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c	2011-08-26 11:29:44 UTC (rev 12473)
@@ -369,7 +369,7 @@
       return NULL;
    cache->create_stmt.sql = apr_pstrdup(ctx->pool,
-         "CREATE TABLE  IF NOT EXISTS tiles (zoom_level integer, tile_column integer, tile_row integer, tile_data blob, primary key(tile_row, tile_column, zoom_level)); create table if not exists metadata(foo integer);");
+         "CREATE TABLE  IF NOT EXISTS tiles (zoom_level integer, tile_column integer, tile_row integer, tile_data blob, primary key(tile_row, tile_column, zoom_level)); create table if not exists metadata(name text, value text);");
    cache->exists_stmt.sql = apr_pstrdup(ctx->pool,
          "select 1 from tiles where tile_column=?:x and tile_row=:y and zoom_level=:z");
    cache->get_stmt.sql = apr_pstrdup(ctx->pool,
