[mapserver-commits] r12480 - in trunk/mapserver/mapcache: . include
src static
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:30:25 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:30:24 -0700 (Fri, 26 Aug 2011)
New Revision: 12480
Added:
trunk/mapserver/mapcache/static/geocache.json
Removed:
trunk/mapserver/mapcache/geocache.json
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/cJSON.c
trunk/mapserver/mapcache/src/cache_disk.c
trunk/mapserver/mapcache/src/cache_memcache.c
trunk/mapserver/mapcache/src/cache_sqlite.c
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/configuration_json.c
trunk/mapserver/mapcache/src/dimension.c
trunk/mapserver/mapcache/src/http.c
trunk/mapserver/mapcache/src/service_wms.c
trunk/mapserver/mapcache/src/source_wms.c
Deleted: trunk/mapserver/mapcache/geocache.json
--- trunk/mapserver/mapcache/geocache.json 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/geocache.json 2011-08-26 11:30:24 UTC (rev 12480)
@@ -1,246 +0,0 @@
- "grids": [
- "name":"grid1",
- "extent":[0,3,4,4],
- "resolutions":[0,2],
- "size":[256,256],
- "metadata": {
- "title":"foo grid title",
- "fail":"sdffd"
- "units":"m",
- "srs":"EPSG:4325",
- "srsaliases":["EPSG:2345","foo"]
- "caches": [
- "name":"disk",
- "type":"disk",
- "props": {
- "base_dir":"/tmp",
- "symlink_blank":true
- "name":"tmpl",
- "type":"disk",
- "props": {
- "template":"/tmp/templ-test/{tileset}-{grid}-{dim}/{z}/{y}/{x}.{ext}"
- "name":"memcache",
- "type":"memcache",
- "props": {
- "servers": [
- "host":"localhost",
- "port":11211
- "name":"sqlite",
- "type":"sqlite3",
- "props": {
- "dbname_template":"/tmp/{tileset}-{grid}.sqlite",
- "hit_stats":false
- "name":"mbtiles",
- "type":"mbtiles",
- "props": {
- "dbname_template":"/tmp/{tileset}-{grid}.mbtiles",
- "hit_stats":false
- "sources": [
- "name":"vmap0",
- "type":"wms",
- "props": {
- "http": {
- "url":"http://vmap0.tiles.osgeo.org/wms/vmap0",
- "headers": {
- "User-Agent":"mod-geocache/trunk",
- "Referer":"http://foosite"
- "getmap": {
- "params":{
- "LAYERS":"basic",
- "FORMAT":"image/png"
- "getfeatureinfo": {
- "params":{
- "QUERY_LAYERS":"basic"
- "info_formats":["text/html"]
- "name":"osm",
- "type":"wms",
- "props": {
- "http": {
- "url":"http://localhost/cgi-bin/mapserv"
- "getmap": {
- "params":{
- "LAYERS":"default",
- "FORMAT":"image/png",
- "MAP":"/Users/tbonfort/dev/mapserver-utils/osm-outlined,google.map"
- "formats": [
- "name":"jpg",
- "type":"jpg",
- "props": {
- "quality":85
- "name":"png",
- "type":"png",
- "props": {
- "colors":256,
- "compression":"best"
- "name":"mixed",
- "type":"mixed",
- "props": {
- "opaque":"jpg",
- "transparent":"png"
- "tilesets": [
- "name": "test",
- "source": "vmap0",
- "grids": [
- "WGS84",
- { "ref":"g", "extent":[10,10,20,20]}
- "wgs84_extent":[-180,-90,180,90],
- "format": "png",
- "cache": "disk",
- "metatile": {
- "size":[5,5],
- "buffer":10
- "expires": {
- "delay": 3600,
- "auto": false
- "dimensions": [
- "type":"values",
- "name":"dim1",
- "default":"val1",
- "props": {
- "values": [ "val1","val2","val3" ]
- //,"watermark":"/home/tbonfort/dev/mod-geocache/static/watermark.png"
- "name": "osm",
- "source": "osm",
- "grids": [
- "g"
- "format": "png",
- "cache": "mbtiles",
- "metatile": {
- "size":[5,5],
- "buffer":10
- "expires": {
- "delay": 3600,
- "auto": false
- "name": "ne",
- "source": "osm",
- "grids": [
- "g"
- "format": "png",
- "metatile": {
- "size":[5,5],
- "buffer":10
- "expires": {
- "delay": 3600,
- "auto": false
- "services": [
- { "type":"demo",
- "enabled":true
- { "type":"kml",
- "enabled":false
- { "type":"wmts",
- "enabled":true
- "type":"wms",
- "enabled":true,
- "props": {
- "forwarding_rules": [
- "name":"foo rule",
- "append_pathinfo":true,
- "http": {
- "url":"http://localhost/forwarded-by-mod-geocache/"
- "params": [
- "name":"SERVICE",
- "type":"values",
- "props": { "values":["WMS","WFS","SOS"] }
- "full_getmap": {
- "strategy":"assemble",
- "resample_mode":"bilinear",
- "format":"PNG8"
- "config": {
- "error_reporting":"message",
- "lock_dir":"/tmp",
- "default_format":"PNG8"
-/* vim: ai ts=2 sts=2 et sw=2 syntax=javascript
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:30:24 UTC (rev 12480)
@@ -512,7 +512,7 @@
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>default</LAYERS>
- <MAP>/Users/tbonfort/dev/mapserver-utils/osm.map</MAP>
+ <MAP>/gro1/mapserver-utils/osm.map</MAP>
</params>
</getmap>
</source>
@@ -602,8 +602,8 @@
the supplied image is read when the configuration is loaded.
if you make changes to the image, they will NOT be reflected on tiles already
stored in the cache, nor on newly stored tiles until the server is restarted
<watermark>/home/tbonfort/dev/mod-geocache/static/watermark.png</watermark>
<!-- format
(optional) format to use when storing a tile. this should be a format with high
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:30:24 UTC (rev 12480)
@@ -27,7 +27,11 @@
#include <apr_global_mutex.h>
#include "util.h"
#include "ezxml.h"
+#ifdef ENABLE_UNMAINTAINED_JSON_PARSER
#include "cJSON.h"
+#endif
#include "errors.h"
#if 0
@@ -271,12 +275,16 @@
void (*query_info)(geocache_context *ctx, geocache_feature_info *fi);
void (*configuration_parse_xml)(geocache_context *ctx, ezxml_t xml, geocache_source * source);
void (*configuration_parse_json)(geocache_context *ctx, cJSON *node, geocache_source * source);
+#endif
void (*configuration_check)(geocache_context *ctx, geocache_source * source);
geocache_http* geocache_http_configuration_parse_xml(geocache_context *ctx,ezxml_t node);
geocache_http* geocache_http_configuration_parse_json(geocache_context *ctx,cJSON *node);
+#endif
geocache_http* geocache_http_clone(geocache_context *ctx, geocache_http *orig);
struct geocache_http {
@@ -360,7 +368,9 @@
void (*tile_set)(geocache_context *ctx, geocache_tile * tile);
void (*configuration_parse_xml)(geocache_context *ctx, ezxml_t xml, geocache_cache * cache);
void (*configuration_parse_json)(geocache_context *ctx, cJSON *node, geocache_cache * cache);
+#endif
void (*configuration_post_config)(geocache_context *ctx, geocache_cache * cache, geocache_cfg *config);
@@ -619,7 +629,9 @@
* parse advanced configuration options for the selected service
void (*configuration_parse_xml)(geocache_context *ctx, ezxml_t xml, geocache_service * service, geocache_cfg *config);
void (*configuration_parse_json)(geocache_context *ctx, cJSON *node, geocache_service * service, geocache_cfg *config);
+#endif
/**\class geocache_service_wms
@@ -907,8 +919,10 @@
void geocache_configuration_parse(geocache_context *ctx, const char *filename, geocache_cfg *config);
void geocache_configuration_post_config(geocache_context *ctx, geocache_cfg *config);
void geocache_configuration_parse_json(geocache_context *ctx, const char *filename, geocache_cfg *config);
void parse_keyvalues(geocache_context *ctx, cJSON *node, apr_table_t *tbl);
+#endif
void geocache_configuration_parse_xml(geocache_context *ctx, const char *filename, geocache_cfg *config);
geocache_cfg* geocache_configuration_create(apr_pool_t *pool);
geocache_source* geocache_configuration_get_source(geocache_cfg *config, const char *key);
@@ -1467,7 +1481,9 @@
* \brief parse the value given in the configuration
void (*configuration_parse_xml)(geocache_context *context, geocache_dimension *dim, ezxml_t node);
void (*configuration_parse_json)(geocache_context *context, geocache_dimension *dim, cJSON *node);
+#endif
struct geocache_dimension_values {
Modified: trunk/mapserver/mapcache/src/cJSON.c
--- trunk/mapserver/mapcache/src/cJSON.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/cJSON.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -20,6 +20,8 @@
THE SOFTWARE.
/* cJSON */
/* JSON parser in C. */
@@ -517,3 +519,5 @@
cJSON *cJSON_CreateFloatArray(float *numbers,int count) {int i;cJSON *n=0,*p=0,*a=cJSON_CreateArray();for(i=0;a && i<count;i++){n=cJSON_CreateNumber(numbers[i]);if(!i)a->child=n;else suffix_object(p,n);p=n;}return a;}
cJSON *cJSON_CreateDoubleArray(double *numbers,int count) {int i;cJSON *n=0,*p=0,*a=cJSON_CreateArray();for(i=0;a && i<count;i++){n=cJSON_CreateNumber(numbers[i]);if(!i)a->child=n;else suffix_object(p,n);p=n;}return a;}
cJSON *cJSON_CreateStringArray(const char **strings,int count) {int i;cJSON *n=0,*p=0,*a=cJSON_CreateArray();for(i=0;a && i<count;i++){n=cJSON_CreateString(strings[i]);if(!i)a->child=n;else suffix_object(p,n);p=n;}return a;}
+#endif
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -415,6 +415,7 @@
* \private \memberof geocache_cache_disk
static void _geocache_cache_disk_configuration_parse_json(geocache_context *ctx, cJSON *node, geocache_cache *cache) {
cJSON *tmp;
geocache_cache_disk *dcache = (geocache_cache_disk*)cache;
@@ -445,6 +446,7 @@
+#endif
@@ -478,7 +480,9 @@
cache->cache.tile_set = _geocache_cache_disk_set;
cache->cache.configuration_post_config = _geocache_cache_disk_configuration_post_config;
cache->cache.configuration_parse_xml = _geocache_cache_disk_configuration_parse_xml;
cache->cache.configuration_parse_json = _geocache_cache_disk_configuration_parse_json;
+#endif
return (geocache_cache*)cache;
Modified: trunk/mapserver/mapcache/src/cache_memcache.c
--- trunk/mapserver/mapcache/src/cache_memcache.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/cache_memcache.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -165,6 +165,7 @@
* \private \memberof geocache_cache_memcache
static void _geocache_cache_memcache_configuration_parse_json(geocache_context *ctx, cJSON *node, geocache_cache *cache) {
geocache_cache_memcache *dcache = (geocache_cache_memcache*)cache;
cJSON *servers = cJSON_GetObjectItem(node,"servers");
@@ -205,10 +206,9 @@
return;
+#endif
@@ -296,7 +296,9 @@
cache->cache.tile_delete = _geocache_cache_memcache_delete;
cache->cache.configuration_post_config = _geocache_cache_memcache_configuration_post_config;
cache->cache.configuration_parse_xml = _geocache_cache_memcache_configuration_parse_xml;
cache->cache.configuration_parse_json = _geocache_cache_memcache_configuration_parse_json;
+#endif
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -232,6 +232,7 @@
sqlite3_close(handle);
static void _geocache_cache_sqlite_configuration_parse_json(geocache_context *ctx, cJSON *node, geocache_cache *cache) {
cJSON *tmp;
geocache_cache_sqlite *dcache = (geocache_cache_sqlite*)cache;
@@ -273,6 +274,7 @@
dcache->hitstat_stmt.sql = apr_pstrdup(ctx->pool,tmp->valuestring);
+#endif
static void _geocache_cache_sqlite_configuration_parse_xml(geocache_context *ctx, ezxml_t node, geocache_cache *cache) {
ezxml_t cur_node;
@@ -344,7 +346,9 @@
cache->cache.tile_set = _geocache_cache_sqlite_set;
cache->cache.configuration_post_config = _geocache_cache_sqlite_configuration_post_config;
cache->cache.configuration_parse_xml = _geocache_cache_sqlite_configuration_parse_xml;
cache->cache.configuration_parse_json = _geocache_cache_sqlite_configuration_parse_json;
+#endif
cache->create_stmt.sql = apr_pstrdup(ctx->pool,
"create table if not exists tiles(x integer, y integer, z integer, data blob, dim text, ctime datetime, atime datetime, hitcount integer default 0, primary key(x,y,z,dim))");
cache->exists_stmt.sql = apr_pstrdup(ctx->pool,
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -22,11 +22,15 @@
void geocache_configuration_parse(geocache_context *ctx, const char *filename, geocache_cfg *config) {
int len = strlen(filename);
const char *ext = &(filename[len-3]);
- if(strcasecmp(ext,"xml")) {
+ if(!strcasecmp(ext,"xml")) {
+#endif
+ geocache_configuration_parse_xml(ctx,filename,config);
+ } else {
geocache_configuration_parse_json(ctx,filename,config);
- } else {
- geocache_configuration_parse_xml(ctx,filename,config);
+#endif
GC_CHECK_ERROR(ctx);
if(!config->lockdir || !strlen(config->lockdir)) {
Modified: trunk/mapserver/mapcache/src/configuration_json.c
--- trunk/mapserver/mapcache/src/configuration_json.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/configuration_json.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -1,3 +1,5 @@
#include "geocache.h"
#include <errno.h>
#include <apr_strings.h>
@@ -828,3 +830,5 @@
fclose(f);
//free(filedata);
+#endif
Modified: trunk/mapserver/mapcache/src/dimension.c
--- trunk/mapserver/mapcache/src/dimension.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/dimension.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -54,9 +54,11 @@
return ret;
static void _geocache_dimension_intervals_parse_json(geocache_context *ctx, geocache_dimension *dim,
cJSON *node) {
+#endif
static void _geocache_dimension_intervals_parse_xml(geocache_context *ctx, geocache_dimension *dim,
ezxml_t node) {
@@ -127,6 +129,7 @@
return ret;
static void _geocache_dimension_regex_parse_json(geocache_context *ctx, geocache_dimension *dim,
cJSON *node) {
geocache_dimension_regex *dimension = (geocache_dimension_regex*)dim;
@@ -158,6 +161,7 @@
return;
+#endif
static void _geocache_dimension_regex_parse_xml(geocache_context *ctx, geocache_dimension *dim,
ezxml_t node) {
@@ -216,6 +220,7 @@
return ret;
static void _geocache_dimension_values_parse_json(geocache_context *ctx, geocache_dimension *dim,
cJSON *node) {
cJSON *tmp;
@@ -243,6 +248,7 @@
return;
+#endif
static void _geocache_dimension_values_parse_xml(geocache_context *ctx, geocache_dimension *dim,
ezxml_t node) {
@@ -282,7 +288,9 @@
dimension->nvalues = 0;
dimension->dimension.validate = _geocache_dimension_values_validate;
dimension->dimension.configuration_parse_xml = _geocache_dimension_values_parse_xml;
dimension->dimension.configuration_parse_json = _geocache_dimension_values_parse_json;
+#endif
dimension->dimension.print_ogc_formatted_values = _geocache_dimension_values_print;
return (geocache_dimension*)dimension;
@@ -303,7 +311,9 @@
dimension->nintervals = 0;
dimension->dimension.validate = _geocache_dimension_intervals_validate;
dimension->dimension.configuration_parse_xml = _geocache_dimension_intervals_parse_xml;
dimension->dimension.configuration_parse_json = _geocache_dimension_intervals_parse_json;
+#endif
dimension->dimension.print_ogc_formatted_values = _geocache_dimension_intervals_print;
@@ -315,7 +325,9 @@
#endif
dimension->dimension.validate = _geocache_dimension_regex_validate;
dimension->dimension.configuration_parse_xml = _geocache_dimension_regex_parse_xml;
dimension->dimension.configuration_parse_json = _geocache_dimension_regex_parse_json;
+#endif
dimension->dimension.print_ogc_formatted_values = _geocache_dimension_regex_print;
Modified: trunk/mapserver/mapcache/src/http.c
--- trunk/mapserver/mapcache/src/http.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/http.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -300,6 +300,7 @@
/* TODO: parse <proxy> and <auth> elements */
geocache_http* geocache_http_configuration_parse_json(geocache_context *ctx, cJSON *node) {
cJSON *tmp;
geocache_http *req = (geocache_http*)apr_pcalloc(ctx->pool,sizeof(geocache_http));
@@ -326,6 +327,7 @@
return req;
+#endif
geocache_http* geocache_http_clone(geocache_context *ctx, geocache_http *orig) {
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -774,6 +774,7 @@
#endif
void _configuration_parse_wms_json(geocache_context *ctx, cJSON *node, geocache_service *gservice, geocache_cfg *cfg) {
assert(gservice->type == GEOCACHE_SERVICE_WMS);
geocache_service_wms *wms = (geocache_service_wms*)gservice;
@@ -888,6 +889,7 @@
+#endif
void _configuration_parse_wms_xml(geocache_context *ctx, ezxml_t node, geocache_service *gservice, geocache_cfg *cfg) {
@@ -985,7 +987,9 @@
service->service.parse_request = _geocache_service_wms_parse_request;
service->service.create_capabilities_response = _create_capabilities_wms;
service->service.configuration_parse_xml = _configuration_parse_wms_xml;
service->service.configuration_parse_json = _configuration_parse_wms_json;
+#endif
service->getmap_strategy = GEOCACHE_GETMAP_ASSEMBLE;
service->resample_mode = GEOCACHE_RESAMPLE_BILINEAR;
return (geocache_service*)service;
Modified: trunk/mapserver/mapcache/src/source_wms.c
--- trunk/mapserver/mapcache/src/source_wms.c 2011-08-26 11:30:15 UTC (rev 12479)
+++ trunk/mapserver/mapcache/src/source_wms.c 2011-08-26 11:30:24 UTC (rev 12480)
@@ -91,6 +91,7 @@
* \private \memberof geocache_source_wms
* \sa geocache_source::configuration_parse()
void _geocache_source_wms_configuration_parse_json(geocache_context *ctx, cJSON *props, geocache_source *source) {
cJSON *tmp;
geocache_source_wms *src = (geocache_source_wms*)source;
@@ -130,10 +131,8 @@
tmp = cJSON_GetObjectItem(tmp,"params");
parse_keyvalues(ctx,tmp,src->getfeatureinfo_params);
+#endif
@@ -216,7 +215,9 @@
source->source.render_map = _geocache_source_wms_render_map;
source->source.configuration_check = _geocache_source_wms_configuration_check;
source->source.configuration_parse_xml = _geocache_source_wms_configuration_parse_xml;
source->source.configuration_parse_json = _geocache_source_wms_configuration_parse_json;
+#endif
source->source.query_info = _geocache_source_wms_query;
source->wms_default_params = apr_table_make(ctx->pool,4);;
source->getmap_params = apr_table_make(ctx->pool,4);
Added: trunk/mapserver/mapcache/static/geocache.json
--- trunk/mapserver/mapcache/static/geocache.json (rev 0)
+++ trunk/mapserver/mapcache/static/geocache.json 2011-08-26 11:30:24 UTC (rev 12480)
@@ -0,0 +1,246 @@
+ "grids": [
+ "name":"grid1",
+ "extent":[0,3,4,4],
+ "resolutions":[0,2],
+ "size":[256,256],
+ "metadata": {
+ "title":"foo grid title",
+ "fail":"sdffd"
+ "units":"m",
+ "srs":"EPSG:4325",
+ "srsaliases":["EPSG:2345","foo"]
+ "caches": [
+ "name":"disk",
+ "type":"disk",
+ "props": {
+ "base_dir":"/tmp",
+ "symlink_blank":true
+ "name":"tmpl",
+ "type":"disk",
+ "props": {
+ "template":"/tmp/templ-test/{tileset}-{grid}-{dim}/{z}/{y}/{x}.{ext}"
+ "name":"memcache",
+ "type":"memcache",
+ "props": {
+ "servers": [
+ "host":"localhost",
+ "port":11211
+ "name":"sqlite",
+ "type":"sqlite3",
+ "props": {
+ "dbname_template":"/tmp/{tileset}-{grid}.sqlite",
+ "hit_stats":false
+ "name":"mbtiles",
+ "type":"mbtiles",
+ "props": {
+ "dbname_template":"/tmp/{tileset}-{grid}.mbtiles",
+ "hit_stats":false
+ "sources": [
+ "name":"vmap0",
+ "type":"wms",
+ "props": {
+ "http": {
+ "url":"http://vmap0.tiles.osgeo.org/wms/vmap0",
+ "headers": {
+ "User-Agent":"mod-geocache/trunk",
+ "Referer":"http://foosite"
+ "getmap": {
+ "params":{
+ "LAYERS":"basic",
+ "FORMAT":"image/png"
+ "getfeatureinfo": {
+ "params":{
+ "QUERY_LAYERS":"basic"
+ "info_formats":["text/html"]
+ "name":"osm",
+ "type":"wms",
+ "props": {
+ "http": {
+ "url":"http://localhost/cgi-bin/mapserv"
+ "getmap": {
+ "params":{
+ "LAYERS":"default",
+ "FORMAT":"image/png",
+ "MAP":"/Users/tbonfort/dev/mapserver-utils/osm-outlined,google.map"
+ "formats": [
+ "name":"jpg",
+ "type":"jpg",
+ "props": {
+ "quality":85
+ "name":"png",
+ "type":"png",
+ "props": {
+ "colors":256,
+ "compression":"best"
+ "name":"mixed",
+ "type":"mixed",
+ "props": {
+ "opaque":"jpg",
+ "transparent":"png"
+ "tilesets": [
+ "name": "test",
+ "source": "vmap0",
+ "grids": [
+ "WGS84",
+ { "ref":"g", "extent":[10,10,20,20]}
+ "wgs84_extent":[-180,-90,180,90],
+ "format": "png",
+ "cache": "disk",
+ "metatile": {
+ "size":[5,5],
+ "buffer":10
+ "expires": {
+ "delay": 3600,
+ "auto": false
+ "dimensions": [
+ "type":"values",
+ "name":"dim1",
+ "default":"val1",
+ "props": {
+ "values": [ "val1","val2","val3" ]
+ //,"watermark":"/home/tbonfort/dev/mod-geocache/static/watermark.png"
+ "name": "osm",
+ "source": "osm",
+ "grids": [
+ "g"
+ "format": "png",
+ "cache": "mbtiles",
+ "metatile": {
+ "size":[5,5],
+ "buffer":10
+ "expires": {
+ "delay": 3600,
+ "auto": false
+ "name": "ne",
+ "source": "osm",
+ "grids": [
+ "g"
+ "format": "png",
+ "metatile": {
+ "size":[5,5],
+ "buffer":10
+ "expires": {
+ "delay": 3600,
+ "auto": false
+ "services": [
+ { "type":"demo",
+ "enabled":true
+ { "type":"kml",
+ "enabled":false
+ { "type":"wmts",
+ "enabled":true
+ "type":"wms",
+ "enabled":true,
+ "props": {
+ "forwarding_rules": [
+ "name":"foo rule",
+ "append_pathinfo":true,
+ "http": {
+ "url":"http://localhost/forwarded-by-mod-geocache/"
+ "params": [
+ "name":"SERVICE",
+ "type":"values",
+ "props": { "values":["WMS","WFS","SOS"] }
+ "full_getmap": {
+ "strategy":"assemble",
+ "resample_mode":"bilinear",
+ "format":"PNG8"
+ "config": {
+ "error_reporting":"message",
+ "lock_dir":"/tmp",
+ "default_format":"PNG8"
+/* vim: ai ts=2 sts=2 et sw=2 syntax=javascript
More information about the mapserver-commits
